SDRAM Set
SDRAM Set
testmb1
Hi everybody
                      May I ask what is the purpose of the code in line 183? Can u explain the working theory in detail? Or is there any document for instruction, thanks.
Carlos_Mendoza
You can find more information about how to set up the burst length through the mode register in the SDRAM memory on the section 23.8.5 in the UM:
http://www.nxp.com/documents/user_manual/UM10503.pdf
Hope it helps!
Carlos Mendoza
Technical Support Engineer
