SD card support
SD card support
3,022 次查看
jimschimpf
Is there a library for the M0 processors (eg LPC11xx) that runs an SD card and supports the FAT file system ?
2,838 次查看
jimschimpf
Thank you I am studying your code, there is enough code that I hope I will be able to muddle through the Chinese.
--jim schimpf
2,839 次查看
jimschimpf
--jim schimpf
2,838 次查看
kerryzhou
Hi Jim
If your problem is solved, please help us mark the correct answer to close this question, thank you!
Kerry
2,836 次查看
kerryzhou
Hi Jim Schimpf,
   I have a LPC1114 project which contains SD and FATFS,  the comment is all wrote in Chinese, but it doesn't matter, you can refer to the code directly.
Wish it helps you!
If you still have problem, please contact me!
