while(true){
// Read LPC_USART->IIR
if(is_break){
// handle_break
// throwaway LPC_USART->RBR;
}else if(has_data){
while(// LSR shows Read Data Ready in the RBR) {
// Read byte from LPC_USART->RBR
while(true){
if(is_break){
// handle_break
}else if(has_data){
// Read one byte from LPC_USART->RBR
void uart_receive_handler(void)
uint32_t interrupt_status = 0;
uint32_t receive_status = 0;
uint32_t interrupt_active = 0;
uint32_t interrupt_type = 0;
uint8_t trashcan = 0;
while(TRUE) {
interrupt_status = LPC_USART->IIR;
interrupt_active = (interrupt_status & 1) == 0x0; // Funky because bit low means active
if( interrupt_active == FALSE ) {
break;
interrupt_type = (interrupt_status >> 1) & 0x7; // Grab bytes the three bytes, starting at bit 2
// If something other than a character
if(interrupt_type == 0x1) { // 0x1 == THRE
//Send more data
uart_transmit_next();
}else if(interrupt_type == 0x3) { // 0x3 == LSR
receive_status = LPC_USART->LSR;
// If break
if(receive_status & UART_LSR_BI) {
// Ship off what we have received
receive_complete();
// throw away blank break value by reading from fifo
trashcan = LPC_USART->RBR;
trashcan = trashcan; // hide "never used" compiler warning.
// Other errors
} else if(receive_status & (UART_LSR_FE|UART_LSR_OE|UART_LSR_PE|UART_LSR_RXFE)) {
// Throw away the rest of this packet.
clean_packet = FALSE;
}else{
// If data ready
// 0x2 = Data ready, 0x6 = leftover data ready (CTI)
} else if(interrupt_type == 0x2 || interrupt_type == 0x6) {
dmx_buffer_add_byte(&receive_local_buffer, LPC_USART->RBR);
if(dmx_buffer_is_full_rdm_packet(&receive_local_buffer)){
receive_complete();
receive_complete();
trashcan = LPC_USART->RBR; |
while(TRUE) {
break;
//Send more data
counters.interrupts +=1;
if(receive_status & UART_LSR_OE){
counters.lsr_oe += 1;
if(receive_status & UART_LSR_PE){
counters.lsr_pe += 1;
if(receive_status & UART_LSR_FE){
counters.lsr_fe += 1;
if(receive_status & UART_LSR_BI){
counters.lsr_bi += 1;
if(receive_status & UART_LSR_RXFE){
counters.lsr_rxfe += 1;
// If break
recieve_complete();
// Other errors
// If also data ready
if(receive_status & UART_LSR_RDR){
counters.lsr_rdr_alt += 1;
// If data ready
} else if(interrupt_type == 0x2 || interrupt_type == 0x6) { // 0x2 = Data ready, 0x6 = leftover data ready (CTI)
while(LPC_USART->LSR & UART_LSR_RDR) { // LSR shows Read Data Ready in the RBR
counters.lsr_rdr += 1;
recieve_complete();
