Release Build Error in MCUXpresso using LPC1788 board
vicky_sivapraka
         i'm new to MCUXpresso IDE using MCUXpresso IDE version 11.2.0.for LPC1788 based project. normally my code build fine in debug build configuration. when configure Release build it had build error.  checked  Properties->C/C++ Build->Settings->Tool Settings---under MCU C Compiler->Includes  added in my driver dir but the remain same.kindly give proper linker instruction that's would help me lot.
Release build error
Finished building: ../src/trial.c
Building target: trial.axf
Invoking: MCU Linker
arm-none-eabi-gcc -nostdlib -Xlinker --gc-sections -Xlinker -Map="trial.map" -Xlinker --cref -Xlinker -print-memory-usage -mcpu=cortex-m3 -mthumb -T "trial_Release.ld" -o "trial.axf" ./src/cr_startup_lpc177x_8x.o ./src/crp.o ./src/delay_.o ./src/trial.o -lCMSIS_CORE_LPC177x_8x
c:/nxp/mcuxpressoide_11.2.0_4120/ide/plugins/com.nxp.mcuxpresso.tools.win32_11.2.0.202001021529/tools/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lCMSIS_CORE_LPC177x_8x
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:32: trial.axf] Error 1
"make -r -j2 all" terminated with exit code 2. Build might be incomplete.
MCU C compiler
MCU assembler
ZhangJennie
Hi Vicky
I tested a lpcopen demo code, switched to release mode, built, I didn't see any error.
Please let me know which demo code can reproduce your issue? or how to reproduce your issue?
Have a nice day,
Jun Zhang
MichalH
NXP Apps Support
NXP Apps Support
Dear vignesh sivaprakash,
You have sent your question to a community space related to NXP FreeMASTER tool. As it is more general question on LPC1788 and MCUXpresso, I will try to redirect your question to LPC Microcontrollers forum.
Michal
