Regarding flash erase of LPC4330
3,405件の閲覧回数
venkatvallapane
I am having LPC4330 Xpresso board and LPC link2.
Don't know what I had done but now I am not able to download any code into flash.
And I am not able to erase the flash too.
I tried boot ISP, vector catch methods discussed in this forum but no help.
This is the message I get when I try to load program. Please help.
I tried with other flash drivers: LPC18_43_GENERIC.cfx and LPC18_43_SPIFI_16MB_64KB but same result.
I am trying one of LPCOpen examples for download. It worked before. I tried one of my own program and after that this happened. Now I am not able to load LPCOpen examples also.
If I don't enable vector catch, it reports erase successfully but I see that contents are still present in flash (resetting executes previous program).
Flash erase log:
Ni: LPCXpresso RedlinkMulti Driver v8.2 (Sep  5 2016 10:13:28 - crt_emu_cm_redlink build 725)
Pc: (  0) Reading remote configuration
Nc: Found chip XML file in /home/socoptimum/workspaces/lpc4330/dualcore_blinky/Debug/LPC4330.xml
Pc: (  5) Remote configuration complete
Nc: Probe Firmware: LPC-LINK2 CMSIS-DAP V5.173 (NXP Semiconductors)
Nc: Serial Number:  IWFWCVCV
Nc: VID:PID:  1FC9:0090
Nc: USB Path: /dev/hidraw1
Pc: ( 30) Emulator Connected
Pc: ( 40) Debug Halt
Pc: ( 50) CPU ID
Nc: Emu(0): Connected&Reset. DpID: 2BA01477. CpuID: 410FC240. Info: <None>
Nc: Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Nc: inspected v.2 External Flash Device on SPI /usr/local/lpcxpresso_8.2.2_650/lpcxpresso/bin/Flash/LPC18_43_SPIFI_16MB_64KB.cfx
Nc: image 'LPC18/43 Generic SPIFI Jun 21 2016 11:54:07'
Nc: Opening flash driver /usr/local/lpcxpresso_8.2.2_650/lpcxpresso/bin/Flash/LPC18_43_SPIFI_16MB_64KB.cfx
Nc: AFTER driver startup timeout
Wc: Driver Addresses
Wc:  Start:  10000000
Wc:  Entry:  10000035
Wc:  End:    10001F98
Wc:  Stack:  10081000
Wc:  Mailbox:10089000
Wc: Driver Register State
Wc:  R0:     10089000
Wc:  R1:     00000000
Wc:  R2:     00000000
Wc:  R3:     00000000
Wc:  R4:     00000000
Wc:  R5:     00000000
Wc:  R6:     00000000
Wc:  R7:     00000000
Wc:  R8:     00000000
Wc:  R9:     00000000
Wc:  R10:    00000000
Wc:  R11:    00000000
Wc:  R12:    00000000
Wc:  SP:     10080FE0
Wc:  LR:     FFFFFFF9 (exception from main thread)
Wc:  PC:     FFFFFFFE
Wc:  xPSR:   01000003
Wc:  MSP:    10080FE0
Wc:  PSP:    10081000
Wc:  CFBP:   00000001
Wc:Stacked Exception information
Wc:10080FFC:  xPSR:   01000000
Wc:10080FF8:  VECTPC: 10000034
Wc:10080FF4:  LR:     10000035
Wc:10080FF0:  R12:    00000000
Wc:10080FEC:  R3:     00000000
Wc:10080FE8:  R2:     00000000
Wc:10080FE4:  R1:     00000000
Wc:10080FE0:  R0:     10089000
Wc:Exception registers
Wc:E000ED04:  ICSR:   00400803 (ISRPEND, VECTPEND=0(none), RETTOBASE, VECTACTIVE=3(hard fault))
Wc:E000ED28:  MMFSR:  01 (IACCVIOL)
Wc:E000ED29:  BFSR:   00
Wc:E000ED2A:  UFSR:   0000
Wc:E000ED2C:  HFSR:   00000002 (VECTBL)
Wc:E000ED30:  DFSR:   00000000
Wc:E000ED3C:  AFSR:   00000000
Wc:E000ED24:  SHCSR:  00000000
Wc:E000ED34:  MMAR:   E000EDF8
Wc:E000ED38:  BFAR:   E000EDF8
Wc:VECTPC instructions near 10000034
Wc:10000030:  0000
Wc:10000032:  0000
Wc:10000034:  0004
Wc:10000036:  B672
Wc:10000038:  F000
Wc:1000003A:  F854
Nc: Flash Driver V.2 startup failed - rc Ef(34): Timed-out initializing flash.
Nc: NXP: LPC4330  Part ID: 0x00000000
Pc: ( 65) Chip Setup Complete
Nt: Connected: was_reset=false. was_stopped=true
Cr:v LPCXpresso Free License - Download limit is 256K
Pc: ( 70) License Check Complete
Wc:  Start:  10000000
Wc:  Entry:  10000035
Wc:  End:    10001F98
Wc:  Stack:  10081000
Wc:  R0:     10089000
Wc:  R1:     00000000
Wc:  R2:     00000000
Wc:  R3:     00000000
Wc:  R4:     00000000
Wc:  R5:     00000000
Wc:  R6:     00000000
Wc:  R7:     00000000
Wc:  R8:     00000000
Wc:  R9:     00000000
Wc:  R10:    00000000
Wc:  R11:    00000000
Wc:  R12:    00000000
Wc:  SP:     10080FE0
Wc:  PC:     FFFFFFFE
Wc:  xPSR:   01000003
Wc:  MSP:    10080FE0
Wc:  PSP:    10081000
Wc:  CFBP:   00000001
Wc:10000030:  0000
Wc:10000032:  0000
Wc:10000034:  0004
Wc:10000036:  B672
Wc:10000038:  F000
Wc:1000003A:  F854
Ed:04: Failed to erase flash: Ef(34): Timed-out initializing flash.
Pc: (100) Target Connection Failed
code download log:
VID:PID:  1FC9:0090
Vector catch on SYSRESETREQ signal
Debug protocol: SWD. RTCK: Disabled. Vector catch: Enabled.
inspected v.2 External Flash Device on SPI /usr/local/lpcxpresso_8.2.2_650/lpcxpresso/bin/Flash/LPC18_43_MX25L3235E.cfx
Opening flash driver /usr/local/lpcxpresso_8.2.2_650/lpcxpresso/bin/Flash/LPC18_43_MX25L3235E.cfx
Driver Addresses
Start:  10000000
Entry:  10000035
End:    10001F98
Stack:  10081000
Mailbox:10089000
R0:     10089000
R1:     00000000
R2:     00000000
R3:     00000000
R4:     00000000
R5:     00000000
R6:     00000000
R7:     00000000
R8:     00000000
R9:     00000000
R10:    00000000
R11:    00000000
R12:    00000000
SP:     10080FE0
PC:     FFFFFFFE
xPSR:   01000003
MSP:    10080FE0
PSP:    10081000
CFBP:   00000001
Exception registers
E000ED04:  ICSR:   00000803 (VECTPEND=0(none), RETTOBASE, VECTACTIVE=3(hard fault))
E000ED29:  BFSR:   00
10000030:  0000
10000032:  0000
10000034:  0004
10000036:  B672
10000038:  F000
1000003A:  F854
Connected: was_reset=true. was_stopped=false
Driver Addresses
Start:  10000000
Entry:  10000035
End:    10001F98
Stack:  10081000
Mailbox:10089000
R0:     10089000
R1:     00000000
R2:     00000000
R3:     00000000
R4:     00000000
R5:     00000000
R6:     00000000
R7:     00000000
R8:     00000000
R9:     00000000
R10:    00000000
R11:    00000000
R12:    00000000
SP:     10080FE0
PC:     FFFFFFFE
xPSR:   01000003
MSP:    10080FE0
PSP:    10081000
CFBP:   00000001
Exception registers
E000ED28:  MMFSR:  00
E000ED29:  BFSR:   00
10000030:  0000
10000032:  0000
10000034:  0004
10000036:  B672
10000038:  F000
1000003A:  F854
(100) Writing Flash ended with an error.
Target error from Commit Flash write: Ef(34): Timed-out initializing flash.
(crt_emu_cm_redlink) terminating on communication loss: Pipe has been closed by GDB.
5 返答(返信)
3,172件の閲覧回数
lpcxpresso_supp
If the suggestion from Carlos is unsuccessful, it would be useful to identify the actual SPIFI device fitted to this board. This can be read directly from the top of the 8 pin device located on the bottom right of the board (with the USB connectors to the left) or identified via LPCScrypt via the command 'querySPIFI.
Yours,
LPCXpresso Support
3,172件の閲覧回数
converse
Senior Contributor V
3,172件の閲覧回数
venkatvallapane
I tried boot ISP, vector catch methods but did not help.
There is already a blinky program in flash and that program I could run and debug.
I could not change anything in that flash now. Could not erase the flash or download new program.
Only blinky successfully downloads again (may be because writes are ignored and read comparison is successful).
Rgds,
Venkat.
3,172件の閲覧回数
Carlos_Mendoza
Hi Venkat,
Has your application code by any chance locked any of the sectors in the external SPIFI flash? You may be able to use LPCScrypt to erase whatever you have programmed into the SPIFI flash that has put the board into its current state.
LPCScrypt v1.8.0|NXP
Hope it helps!
Carlos Mendoza
Technical Support Engineer
3,172件の閲覧回数
venkatvallapane
Hi Carlos,
Thanks for the response. Meanwhile, I purchased new board. I will try your suggestion probably in next week.
Rgds,
Venkat.
