Reasons for LPC2210 internal reset
lmock
What error conditions in software can cause the LPC2210 to perform an internal reset?
We noticed it we manipulate the IRQ address the system seems to hang and then perform a reset. However in the manual for the LPC2210 it states the only two causes are watchdog (which we dont have enabled) and external reset.
Is it possible for exceptions in software to cause an internal reset?
Harry_Zhang
Hi @lmock
"Is it possible for exceptions in software to cause an internal reset?"
No, an exception in software on the LPC2210 cannot directly cause an internal reset.
But it can crash the CPU in a way that triggers an external reset (via hardware) or appears like a reset when you lose control flow.
Harry
lmock
We can see the application code resetting however we don't see any activity on the reset line.
If loss of control flow has occurred would this "look like a reset", without triggering a hardware reset (activity on the reset line)?
Harry_Zhang
Hi @lmock
Yes—loss of control flow can absolutely make the program re-enter Reset_Handler with no hardware reset and no activity on the reset pin.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2152141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EReasons%20for%20LPC2210%20internal%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhat%20error%20conditions%20in%20software%20can%20cause%20the%20LPC2210%20to%20perform%20an%20internal%20reset%3F%3C%2FP%3E%3CP%3EWe%20noticed%20it%20we%20manipulate%20the%20IRQ%20address%20the%20system%20seems%20to%20hang%20and%20then%20perform%20a%20reset.%20However%20in%20the%20manual%20for%20the%20LPC2210%20it%20states%20the%20only%20two%20causes%20are%20watchdog%20(which%20we%20dont%20have%20enabled)%20and%20external%20reset.%3C%2FP%3E%3CP%3EIs%20it%20possible%20for%20exceptions%20in%20software%20to%20cause%20an%20internal%20reset%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2152141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Elpc2000%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Reasons%20for%20LPC2210%20internal%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253790%22%20target%3D%22_blank%22%3E%40lmock%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EYes%E2%80%94loss%20of%20control%20flow%20can%20absolutely%20make%20the%20program%20re-enter%20Reset_Handler%20with%20no%20hardware%20reset%20and%20no%20activity%20on%20the%20reset%20pin.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EHarry%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Reasons%20for%20LPC2210%20internal%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EWe%20can%20see%20the%20application%20code%20resetting%20however%20we%20don't%20see%20any%20activity%20on%20the%20reset%20line.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIf%20loss%20of%20control%20flow%20has%20occurred%20would%20this%20%22look%20like%20a%20reset%22%2C%20without%20triggering%20a%20hardware%20reset%20(activity%20on%20the%20reset%20line)%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Reasons%20for%20LPC2210%20internal%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253790%22%20target%3D%22_blank%22%3E%40lmock%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22hover-sent%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22eJqmA4d9oB%22%20data-para-id%3D%221%22%3E%22Is%20it%20possible%20for%20exceptions%20in%20software%20to%20cause%20an%20internal%20reset%3F%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22hover-sent%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22eJqmA4d9oB%22%20data-para-id%3D%221%22%3ENo%2C%20an%20exception%20in%20software%20on%20the%20LPC2210%20cannot%20directly%20cause%20an%20internal%20reset.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%3D%3D%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3EBut%20it%20can%20crash%20the%20CPU%20in%20a%20way%20that%20triggers%20an%20external%20reset%20(via%20hardware)%20or%20appears%20like%20a%20reset%20when%20you%20lose%20control%20flow.%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%3D%3D%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%22JTVCJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjJlSnFtQTRkOW9CJTIyJTJDJTIycGFyYUlkeCUyMiUzQTElMkMlMjJzcmMlMjIlM0ElMjJObyUyQyUyMGFuJTIwZXhjZXB0aW9uJTIwaW4lMjBzb2Z0d2FyZSUyMG9uJTIwdGhlJTIwTFBDMjIxMCUyMGNhbm5vdCUyMGRpcmVjdGx5JTIwY2F1c2UlMjBhbiUyMGludGVybmFsJTIwcmVzZXQuJTIyJTJDJTIyZHN0JTIyJTNBJTIyJUU1JTkwJUE2JUVGJUJDJThDTFBDMjIxMCVFNCVCOCU4QSVFNyU5QSU4NCVFOCVCRCVBRiVFNCVCQiVCNiVFNSVCQyU4MiVFNSVCOCVCOCVFNCVCOCU4RCVFOCU4MyVCRCVFNyU5QiVCNCVFNiU4RSVBNSVFNSVBRiVCQyVFOCU4NyVCNCVFNSU4NiU4NSVFOSU4MyVBOCVFOSU4NyU4RCVFNyVCRCVBRSVFMyU4MCU4MiUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJtZXRhRGF0YSUyMiUzQSU1QiU1RCUyQyUyMnRleHQlMjIlM0ElMjJObyUyQyUyMGFuJTIwZXhjZXB0aW9uJTIwaW4lMjBzb2Z0d2FyZSUyMG9uJTIwdGhlJTIwTFBDMjIxMCUyMGNhbm5vdCUyMGRpcmVjdGx5JTIwY2F1c2UlMjBhbiUyMGludGVybmFsJTIwcmVzZXQuJTIyJTdEJTVEJTdEJTJDJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjJCWGQwbERtdnBCJTIyJTJDJTIycGFyYUlkeCUyMiUzQTIlMkMlMjJzcmMlMjIlM0ElMjJCdXQlMjBpdCUyMGNhbiUyMGNyYXNoJTIwdGhlJTIwQ1BVJTIwaW4lMjBhJTIwd2F5JTIwdGhhdCUyMHRyaWdnZXJzJTIwYW4lMjBleHRlcm5hbCUyMHJlc2V0JTIwKHZpYSUyMGhhcmR3YXJlKSUyMG9yJTIwYXBwZWFycyUyMGxpa2UlMjBhJTIwcmVzZXQlMjB3aGVuJTIweW91JTIwbG9zZSUyMGNvbnRyb2wlMjBmbG93LiUyMiUyQyUyMmRzdCUyMiUzQSUyMiVFNCVCRCU4NiVFNSVBRSU4MyVFNSU4RiVBRiVFOCU4MyVCRCVFNCVCQyU5QSVFNCVCRCVCRkNQVSVFNSVCNCVBOSVFNiVCQSU4MyVFRiVCQyU4QyVFNCVCQiU4RSVFOCU4MCU4QyVFOCVBNyVBNiVFNSU4RiU5MSVFNSVBNCU5NiVFOSU4MyVBOCVFOSU4NyU4RCVFNyVCRCVBRSVFRiVCQyU4OCVFOSU4MCU5QSVFOCVCRiU4NyVFNyVBMSVBQyVFNCVCQiVCNiVFRiVCQyU4OSVFRiVCQyU4QyVFNiU4OCU5NiVFOCU4MCU4NSVFNSU5QyVBOCVFNiU4MiVBOCVFNSVBNCVCMSVFNSU4RSVCQiVFNiU4RSVBNyVFNSU4OCVCNiVFNiVCNSU4MSVFNiU5NyVCNiVFNyU5QyU4QiVFOCVCNSVCNyVFNiU5RCVBNSVFNSU4MyU4RiVFOSU4NyU4RCVFNyVCRCVBRSVFMyU4MCU4MiUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJtZXRhRGF0YSUyMiUzQSU1QiU1RCUyQyUyMnRleHQlMjIlM0ElMjJCdXQlMjBpdCUyMGNhbiUyMGNyYXNoJTIwdGhlJTIwQ1BVJTIwaW4lMjBhJTIwd2F5JTIwdGhhdCUyMHRyaWdnZXJzJTIwYW4lMjBleHRlcm5hbCUyMHJlc2V0JTIwKHZpYSUyMGhhcmR3YXJlKSUyMG9yJTIwYXBwZWFycyUyMGxpa2UlMjBhJTIwcmVzZXQlMjB3aGVuJTIweW91JTIwbG9zZSUyMGNvbnRyb2wlMjBmbG93LiUyMiU3RCU1RCU3RCU1RA%3D%3D%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3EBR%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%3D%3D%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3EHarry%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
