RTOS and openSSL support for LPC43S67
5,433 次查看
zhouhaohua
what kind of RTOS has been test on LPC43S67, uC/OSII,FreeRTOS, any experience to share? where to get the A70CM Host API, so I can access A70CM for security related application, I have NXP-Cloud kits, which have A7001 and LPC43S67 on the board,
   any experience to Porting openSSL to LPC43S67 and work with A70CM?
标记 (1)
7 回复数
4,913 次查看
jeremyzhou
Hi Charlie,
Thank you for your interest  in NXP Semiconductor products and the opportunity tor serve you.
1) What kind of RTOS has been test on LPC43S67, uC/OSII,FreeRTOS, any experience to share?
   I'd like to recommend you to refer the LPCOpen library which contains some RTOS demos.
LPCOpen Software for LPC43XX|NXP
2) Where to get the A70CM Host API, so I can access A70CM for security related application?
   As I know, if customer want to get A70 security support, they need signed a special NDA with NXP. This need check with A70 product line. Customer can check this with the distributor and you can learn the contacting information through the link below:
Distributor Network|NXP
Ping
4,913 次查看
zhouhaohua
I mean some popular RTOS like freeRTOS, don't have too much time to spend
on RTOS, need some generic one, so I can easy ported the SW
4,913 次查看
jeremyzhou
Hi Charlie,
Thanks for your reply.
Let me clarify it, the LPCOpen Software for LPC43XX|NXP contains a FreeRTOS template demo.
It can help you to get start with the FreeRTOS.
Ping
4,913 次查看
zhouhaohua
Dear Ping:
How about SSL/TLS examples?
On Thu, Jan 19, 2017 at 10:03 PM, jeremyzhou <[email protected]>
4,913 次查看
jeremyzhou
Hi Charlie,
I haven't found these demos which is about SSL/TLS.
However you can go to Cypherbridge Systems Products & Services  to find the information you request.
Hope it helps.
Ping
4,913 次查看
zhouhaohua
I am interested in using ARM mbed OS and TLS to test https not http , so I
can use it to do some https access examples, do you have similar
examples,
but I don't know what is the step to make https work
LWIP FreeRTOS TCP Echo example
Example description
Welcome to the LWIP TCP Echo example with FreeRTOS using the 18xx/43xx LWIP
MAC and PHY drivers. The example demonstrates PHY link monitoring, DHCP
client, ICMP Echo (ping) and TCP Echo (RFC 862) operation.
4,913 次查看
rocketdawg2
i could be wrong, but I think it is included with the dev board
LPC43S67-A70CM Cloud Connectivity Kit|NXP
