RTOS Porting in LPC546xx
1,430 次查看
prasannanaik
I want to port Amazon Free RTOS in LPC546XX controller. Is there any documentation to refer for this as using referemce code could lead to some bug if not ported properly.
Thanks and best regards,
Prasanna
1,348 次查看
BlackNight
Hi Prasanna,
it might depend on what exactly you want to port. The LPC546xx is a Cortex-M4F, so any standard kernel port for M4 will work on it. You can get it directly from Amazon, from FreeRTOS Real Time Kernel (RTOS) download | SourceForge.net  or simpyl use the one in the MCUXpresso SDK.
I hope this helps,
Erich
