RTC PCF2131 example for LPC1857
5,208 次查看
rubensjunior
Hy friends!
I need to use an RTC (Real Time Clock) model PCF2131 (NXP) with LPC1857 microcontroller. Is there any example or SDK about it?
Thankyou very much.
Rubens Júnior
5 回复数
5,194 次查看
xiangjun_rong
pls refer to the attached code, which is based on SPI interface.
I get the code from the website:
https://community.nxp.com/t5/Other-NXP-Products-Knowledge/PCF2129-RTC-example-code/ta-p/1105024
Hope it can help you
XiangJun Rong
5,185 次查看
rubensjunior
Hi @xiangjun_rong!
Thanks a lot for your attention!
I will use PCF2131. Will the PCF2129 example work well with the PCF2131?
Thank you very much!
5,164 次查看
xiangjun_rong
I suppose they are similar from interface perspective and RTC registers.
XiangJun Rong
5,143 次查看
rubensjunior
Hi @xiangjun_rong,
Is there any example with i2c interface?
5,160 次查看
rubensjunior
Hi @xiangjun_rong ,
I will try to use this example with PCF2131.
Thanks a lot!
Rubens Júnior
