Question about RTC general purpose registers on LPC1857FET256
2,977 次查看
billsheng
We got a 8D quality urgent case, which we found caused by RTC general purpose registers on LPC1857.
It seems the data stored in REGFILE59 changed randomly in some condition.
For most boards, there had no problem, except 4PCS we found currently.
The MCU on the problem boards have 2 PCS with ESD15330A and ESD15370A separately.
We're struggling to find the root cause.
It's appreciated that someone could give us some hints for this problem.
标签 (1)
4 回复数
2,582 次查看
Hui_Ma
First of all, thank you for the patience.
I got the feedback from LPC product team:
The LPC1857 User Manual with incorrect description about RTC general purpose registers reset value.
The correct description is that: The register value is undefined after reset.
It's a document issue. Thank you for the attention.
Wish it helps.
Ma Hui
2,582 次查看
billsheng
Thanks a lot for the answer.
May I pop a suggestion that could NXP speed up the question post out?
I found that my question was postponed several weeks be it posted out.
2,582 次查看
Hui_Ma
Hi Bill
The NXP community had been maintained last month to add more products be supported.
So far, the NXP community should not with that delay posted issue.
Sorry for that may causing any inconveniences.
best regards,
Hui
2,582 次查看
Hui_Ma
I will check this issue with LPC Product team and check if there with similar issues.
I will let you know when there with any feedback.
Thank you for the patience.
Ma Hui
