Programing LPC-link2 using LPC-link1
2,994 次查看
christianm
I been trying to program the LPC-link2 (as a eval board to LPC4370) using a LPC-link (JTAG), but without much success. I'm able to debug to device, but not to program the device. I followed different threads such as https://community.nxp.com/message/630848  , but again nothing have worked so far. Does anyone have any advice?
Thank you all in advance,
Christian
标签 (2)
2,547 次查看
lpcxpresso_supp
You don't need to configure the LPC-Link. But your LPCXpresso IDE project does need to have the external memory of the LPC4370 on the LPC-Link2 defined in the memory configuration, along with the corrected flash driver associated with it.
For more details see the LPCXpresso IDE User Guide, along with https://community.nxp.com/thread/389076
LPCXpresso Support
2,547 次查看
christianm
Thank you for your reply. I've tried again, and is working fine now (probably I was failing at the configuration of the jumper JP1)
2,547 次查看
christianm
So, I couldn't find a way to configure my lpc-link to program the external flash of the lpc-link2, but I resolve the programming using the lpcScrypt.
