Program through ISP using Flash Magic.
4,502 次查看
emb02
Contributor V
I am using LPC54628J512 Development board and want to download and verify program through ISP using flash magic but I am unable to download hex file.
I am attaching image of error please kindly check and help me with resolve this problem.
Thank you.
4,476 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, in order to be sure, did you put the board in ISP mode? Could you elaborate further about the steps you are following? please.
Pavel
4,477 次查看
Pavel_Hernandez
Pavel
4,425 次查看
emb02
Contributor V
I put board in ISP mode, I can read security and even I can read device signature, I can erase chip successfully but I am unable to program and verify through ISP. Please help me with this problem.
