Problem with Flash Magic Bootlader
lpcware
Content originally posted in LPCWare by milind.mishra on Thu Apr 16 23:22:34 MST 2015
I have modified a sample bootloader code provided by flash magic to support firmware flashing using SPIFI interface.
I changed the code from supporting LPC18xx to supporting LPC43xx. I am using Keil uv4 for doing that.
Most of the files are getting compiled but towards the end the Linker throws an error which I am unable to comprehend.
Kindly look at the screenshot and provide some possible leads to fix this problem.
Milind.
