Power Consumption of a LPC4370(link-2)
1,899 次查看
lpcware
Content originally posted in LPCWare by jinnuudn on Mon Aug 18 00:00:58 MST 2014
can somebody give me a value for the Power Consumption of a LPC4370.
My code using M4 and M0 core.
  In M0 --> gpio,adc(12bit)@40Mhz,dma
  In M4 --> FFT processing
Thanks & Regards,
Jinesh
4 回复数
1,844 次查看
lpcware
Content originally posted in LPCWare by rocketdawg on Mon Aug 18 08:18:58 MST 2014
Quote: jinnuudn
Please help me out to get accurate numbers.
Jineshwar Nyamagoud
How are we suppose to know?  Are you an engineer or a management person?
1,844 次查看
lpcware
Content originally posted in LPCWare by jinnuudn on Mon Aug 18 04:15:00 MST 2014
Hi ,
I want to check how much current is drawn by my application.Please help me out to get accurate numbers.
Thanks in advance.
Jineshwar Nyamagoud
1,844 次查看
lpcware
Content originally posted in LPCWare by starblue on Mon Aug 18 03:22:53 MST 2014
For information see the data sheet "10.1 Power Consumption".
To measure it on an LPC-Link2, study the schematics from Embedded Artists:
http://www.embeddedartists.com/products/lpcxpresso/lpclink2.php
http://www.embeddedartists.com/sites/default/files/support/xpr/link2/LPC-Link-II_Rev_C.pdf
It seems you can remove R53 (0R) and add JP3, and then measure the complete 3.3V supply current via JP3.
Note that it supplies all parts on the board, not jut the LPC4370.
Jürgen
1,844 次查看
lpcware
Content originally posted in LPCWare by jinnuudn on Mon Aug 18 00:49:50 MST 2014
Quote: jinnuudn
can somebody give me how to measure the Power Consumption of a LPC4370.
Thanks & Regards,
Jinesh
