Pin compatiblity NXP MCUs
Tommy22
Hi, Is there a fast way way to check for pin compatibility between different NXP MCUs? Are there tools or compatibility lists avaible? The alternative is to check pin by pin in the datasheets which takes too much time. Thanks in advance.
Sorry, I'm afraid there isn't .
You can tell us the chip number, we can help you to compare.
Alice
