PLC communication betwee EV and simulated EVSE
1,289 次查看
mjadan
Hello NXP team,
I am interested in studying PLC and IPv6 communication between a vehicle and a charging station. To achieve this, I am simulating a charging station using the NXP EVSE-SIG-BRD2X board and the i.MX 93 Evaluation Kit, both flashed with EVSE software. The jumpers on the EVSE-SIG-BRD2X are configured for EVSE mode according to the user manual.
The CP, PP, and GND pins from the EVSE-SIG-BRD2X are connected to the corresponding pins on the charging cable. The i.MX 93 Evaluation Kit runs Linux and executes the stx_evse_eth program.
When running the program, execution stops at “APL: Listen Port 7” and resumes only after the cable is connected to the vehicle.
My questions are:
Why does it disconnect from AVLN?
What does “FIRMWARE RUNNING” mean?
Why is there no successful SLAC pairing?
Here is the execution log.
root@imx93evk-easyevse:~# ./stx_evse_eth
SEVENSTAX OpenSTLinux Reference Application V_02_00_00
- Linux-RAW-Socket used with SEVENSTAX-TCP
INFO: Network Interface if0 = eth0
Welcome to sevenstax Debugging!
REFERENCE APPLICATION:
  Version:   V_02_00_00
  Build:     Apr  5 2024 14:41:09
  Customer:  NXP
  Target:    Linux
  CPU:       i.MX 93
SEVENSTAX PRODUCT VERSION:
  SEVENSTAX_LIB_V_11_02_00
PROTOCOLS CONFIGURATION:
 [x] IP-MULTI-DEVICE
 [x] IPv4/6: 5 instances
      [ ] IPv4
      [x] IPv6
      [x] IPv6 Fragmentation
          [x] Rx fragments (1x2000 bytes)
          [x] Tx fragments (1 instances )
 [x] Ethernet Interface
      [ ] DHCP client
      [ ] DHCP server
      [ ] BOOTP
      [ ] Auto-IP
      [ ] WLAN Driver/Service
 [ ] PPP
 [ ] ICMP
 [ ] IGMP
 [x] TCP (5 instances)
      [ ] HTTP server
      [ ] SOAP Client
      [ ] ReST Module
      [x] HTTP Client
      [ ] TELNET server
      [ ] NVT
      [ ] XMPP
      [ ] SMTP
      [ ] POP3
 [x] UDP (5 instances)
      [ ] NTP
      [ ] SNMP agent
      [ ] DNS client
      [ ] DNS client/server
      [ ] mDNS/DNS-SD
      [ ] MDNS-Service
      [ ] NBNS
      [ ] LLMNR
      [ ] TFTP client/server
      [ ] PTP
 [ ] RTOSWrapper
      [ ] CMX
      [ ] Segger embOS
      [ ] SCIOPTA
 [x] VFS (15 instances)
      [ ] Static ROM-Files
      [ ] STX-Filesystem
      [ ] Static Lookup-Table
      [ ] Dynamic FAT Access
SPECIAL TEST CONFIGURATION:
 [x] DebugOuts
 [ ] User Management
 [ ] RANDOM MAC address
 [ ] TCP-Echo
 [ ] TCP-Echo RTOS
 [ ] JavaGraph Applet (no TCP)
 [x] UDP-Echo (Port 7, 2000 bytes)
 [ ] UDP-Echo RTOS
 [ ] TFTP-Demo
 [ ] IGMP Testgroup
 [x] NameServices Wrapper
 [ ] WLAN-Test-Sequence enabled
 [ ] NameService-Test-Sequence enabled
APPLICATION RUNNING ...
[    0.003] [INFO  ] PLCV-HL: stxCG5317_HL_Init()
[    0.003] [INFO  ] PLCV-HL: stxCG5317_HL_Config()
[    0.003] SECCDP: stxSeccDPS_Init() called!
[    0.003] [DEBUG ] APL-ETH: stxRefApp_Eth_Init() called
[    0.003] [INFO  ] APL-ETH: ======================================================>
[    0.003] [INFO  ] APL-ETH:   RefApp Network Layer configurations
[    0.003] [INFO  ] APL-ETH:   L1->L2->L3 linkage:
[    0.003] [INFO  ] APL-ETH:   ----------------------------------------------------
[    0.003] [INFO  ] APL-ETH:   Interface Configuration[0]:
[    0.003] [INFO  ] PLC-HL: stxPLC_HL_SetMac()
[    0.003] [NOTICE] APL-ETH:   MAC of NIC[0]:  00:01:01:74:6b:30
[    0.003] [INFO  ] APL-ETH:   L1 Device Name: plc0
[    0.003] [INFO  ] APL-ETH:   L2 Type:                Ethernet
[    0.003] [INFO  ] APL-ETH:   L3 IPv6 Handle[0]:      0xfe00
[    0.003] [INFO  ] APL-ETH: <======================================================
[    0.003] [DEBUG ] APL-ETH:   stxRefApp_Eth_Init() finished
[    0.003] APL: UDP-Echo enabled:
[    0.003] APL:   Listen Port 7
[   29.909] [DEBUG ] V2GAPP: stxV2GAppl_Init()
[   29.909] [NOTICE] SLAC: stxSLAC_Init()
[   29.910] [DEBUG ] V2GAPP: stxV2GAppl_Start()
[   29.910] [DEBUG ] V2GAPP: STATE = X => APPLV2G_STATE_INIT
[   29.910] [DEBUG ] APL-ETH: stxRefApp_Eth_Start() called
[   29.910] [INFO  ] PLC-HL: stxPLC_HL_Start()
[   29.934] [INFO  ] PLCV-HL: stxCG5317_HL_Start()
[   29.934] [DEBUG ] APL-ETH: stxRefApp_Eth_Start() finished
[   29.934] [NOTICE] PLCV-HL: stxCG5317_HL_Tick(): Reset CG5317
[   29.934] [NOTICE] TLSLIB: DRBG initialized.
[   59.664] [NOTICE] SLAC: stxSLAC_Stop()
[   59.664] SECCDP: stxSeccDPS_Stop() called!
[   59.664] [DEBUG ] V2GAPP: STATE = APPLV2G_STATE_INIT => APPLV2G_STATE_INITIALIZED
[   89.662] [DEBUG ] V2GAPP: STATE = APPLV2G_STATE_INITIALIZED => APPLV2G_STATE_DETECT_MODE
[   89.662] [INFO  ] PLCV-HL: stxCG5317_HL_Tick(): Init
[  179.339] [DEBUG ] V2GAPP: EVSE STATE = APPLV2G_STATE_DETECT_MODE => APPLV2G_STATE_SLAC_START_PRE
[  209.256] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 257!
[  239.163] [WARN  ] PLCV-HL: stxCG5317_HL_Tick(): Modem did not confirm packet with sessionId 257! Resend packet!
[  269.073] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 257!
[  269.097] [NOTICE] PLCV-HL: ---------> FIRMWARE STOPPED
[  269.098] [NOTICE] PLCV-HL: ---------> FIRMWARE STOPPED
[  269.099] [INFO  ] PLCV-HL:   stxCG5317_HL_Tick_Boot(): device is in host loading mode
[  269.101] [INFO  ] PLCV-HL: EBL section data had been loaded
[  269.105] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 258!
[  269.112] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 259!
[  269.117] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 260!
[  269.122] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 261!
[  269.124] [NOTICE] V2GAPP: # V2GCPS_INFOTYPE_CP_STATE
[  269.126] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 262!
[  269.133] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 263!
[  269.140] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 264!
[  269.143] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 265!
[  269.144] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 266!
[  269.145] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 267!
[  269.147] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 268!
[  299.054] [WARN  ] PLCV-HL: stxCG5317_HL_Tick(): Modem did not confirm packet with sessionId 268! Resend packet!
[  328.959] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 268!
[  358.852] [WARN  ] PLCV-HL: stxCG5317_HL_Tick(): Modem did not confirm packet with sessionId 268! Resend packet!
[  358.852] [WARN  ] PLCV-HL: Got non zero status code from VSM response. Code 0x7
[  358.852] [ERROR ] PLCV-HL: Aborting Image Upload due to non-zero status code in VSM response. Code: 0x7
[  358.865] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 268!
[  358.877] [WARN  ] PLCV-HL: Got non zero status code from VSM response. Code 0x7
[  358.877] [ERROR ] PLCV-HL: Aborting Image Upload due to non-zero status code in VSM response. Code: 0x7
[  358.890] [ERROR ] PLCV-HL: stxCG5317_HL_FW_Tick_UploadCpuImage(): Got erronous response. Aborting upload process
[  358.890] [NOTICE] PLCV-HL: stxCG5317_HL_Tick(): Reset CG5317
[  359.405] [INFO  ] PLCV-HL: stxCG5317_HL_Tick(): Init
[  359.429] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 269!
[  359.430] [NOTICE] PLCV-HL: ---------> FIRMWARE STOPPED
[  359.430] [INFO  ] PLCV-HL:   stxCG5317_HL_Tick_Boot(): device is in host loading mode
[  359.430] [INFO  ] PLCV-HL: EBL section data had been loaded
[  359.431] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 270!
[  359.432] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 271!
[  359.433] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 272!
[  359.434] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 273!
[  359.508] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 274!
[  359.510] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 275!
[  359.511] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 276!
[  359.512] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 277!
[  359.514] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 278!
[  359.577] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 279!
[  359.578] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 280!
[  359.580] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 281!
[  359.581] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 282!
[  359.582] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 283!
[  359.656] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 284!
[  359.657] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 285!
[  359.658] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 286!
[  359.660] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 287!
[  359.661] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 288!
[  359.735] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 289!
[  359.736] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 290!
[  359.737] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 291!
[  359.739] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 292!
[  359.740] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 293!
[  359.803] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 294!
[  359.804] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 295!
[  359.805] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 296!
[  359.807] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 297!
[  359.808] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 298!
[  359.882] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 299!
[  359.883] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 300!
[  359.884] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 301!
[  359.886] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 302!
[  359.887] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 303!
[  359.961] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 304!
[  359.962] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 305!
[  359.963] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 306!
[  359.964] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 307!
[  359.966] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 308!
[  360.039] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 309!
[  360.041] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 310!
[  360.042] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 311!
[  360.043] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 312!
[  360.045] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 313!
[  360.118] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 314!
[  360.120] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 315!
[  360.121] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 316!
[  360.122] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 317!
[  360.124] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 318!
[  360.197] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 319!
[  360.199] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 320!
[  360.200] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 321!
[  360.201] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 322!
[  360.203] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 323!
[  360.276] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 324!
[  360.278] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 325!
[  360.279] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 326!
[  360.280] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 327!
[  360.282] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 328!
[  360.355] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 329!
[  360.357] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 330!
[  360.358] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 331!
[  360.359] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 332!
[  360.361] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 333!
[  360.434] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 334!
[  360.436] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 335!
[  360.437] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 336!
[  360.438] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 337!
[  360.440] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 338!
[  360.503] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 339!
[  360.504] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 340!
[  360.505] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 341!
[  360.506] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 342!
[  360.508] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 343!
[  360.557] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 344!
[  360.582] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 345!
[  360.583] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 346!
[  360.584] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 347!
[  360.586] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 348!
[  360.587] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 349!
[  360.660] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 350!
[  360.661] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 351!
[  360.663] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 352!
[  360.664] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 353!
[  360.738] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 354!
[  360.739] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 355!
[  360.741] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 356!
[  360.742] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 357!
[  360.816] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 358!
[  360.817] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 359!
[  360.819] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 360!
[  360.820] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 361!
[  360.894] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 362!
[  360.895] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 363!
[  360.897] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 364!
[  360.898] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 365!
[  360.972] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 366!
[  360.973] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 367!
[  360.975] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 368!
[  360.976] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 369!
[  361.050] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 370!
[  361.051] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 371!
[  361.053] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 372!
[  361.054] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 373!
[  361.128] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 374!
[  361.129] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 375!
[  361.131] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 376!
[  361.132] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 377!
[  361.133] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 378!
[  361.194] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 379!
[  361.207] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 380!
[  361.208] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 381!
[  361.209] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 382!
[  361.211] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 383!
[  361.274] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 384!
[  361.275] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 385!
[  361.276] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 386!
[  361.278] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 387!
[  361.352] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 388!
[  361.353] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 389!
[  361.354] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 390!
[  361.356] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 391!
[  361.419] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 392!
[  361.420] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 393!
[  361.422] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 394!
[  361.423] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 395!
[  361.497] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 396!
[  361.498] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 397!
[  361.500] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 398!
[  361.501] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 399!
[  361.575] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 400!
[  361.576] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 401!
[  361.578] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 402!
[  361.579] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 403!
[  361.653] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 404!
[  361.655] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 405!
[  361.656] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 406!
[  361.657] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 407!
[  361.731] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 408!
[  361.733] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 409!
[  361.734] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 410!
[  361.735] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 411!
[  361.809] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 412!
[  361.811] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 413!
[  361.812] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 414!
[  361.813] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 415!
[  361.887] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 416!
[  361.889] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 417!
[  361.890] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 418!
[  361.891] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 419!
[  361.965] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 420!
[  361.967] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 421!
[  361.968] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 422!
[  361.969] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 423!
[  361.970] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 424!
[  362.031] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 425!
[  362.044] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 426!
[  362.045] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 427!
[  362.046] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 428!
[  362.048] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 429!
[  362.122] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 430!
[  362.123] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 431!
[  362.124] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 432!
[  362.126] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 433!
[  362.189] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 434!
[  362.191] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 435!
[  362.192] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 436!
[  362.193] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 437!
[  362.267] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 438!
[  362.268] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 439!
[  362.270] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 440!
[  362.271] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 441!
[  362.345] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 442!
[  362.347] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 443!
[  362.348] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 444!
[  362.349] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 445!
[  362.423] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 446!
[  362.425] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 447!
[  362.426] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 448!
[  362.427] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 449!
[  362.501] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 450!
[  362.503] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 451!
[  362.504] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 452!
[  362.505] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 453!
[  362.579] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 454!
[  362.581] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 455!
[  362.582] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 456!
[  362.583] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 457!
[  362.657] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 458!
[  362.659] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 459!
[  362.660] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 460!
[  362.661] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 461!
[  362.735] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 462!
[  362.737] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 463!
[  362.738] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 464!
[  362.739] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 465!
[  362.813] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 466!
[  362.815] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 467!
[  362.816] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 468!
[  362.817] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 469!
[  362.819] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 470!
[  362.882] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 471!
[  362.883] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 472!
[  362.884] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 473!
[  362.886] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 474!
[  362.887] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 475!
[  362.961] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 476!
[  362.962] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 477!
[  362.963] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 478!
[  362.965] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 479!
[  363.028] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 480!
[  363.029] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 481!
[  363.031] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 482!
[  363.032] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 483!
[  363.106] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 484!
[  363.107] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 485!
[  363.109] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 486!
[  363.110] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 487!
[  363.184] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 488!
[  363.185] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 489!
[  363.187] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 490!
[  363.188] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 491!
[  363.262] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 492!
[  363.264] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 493!
[  363.265] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 494!
[  363.266] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 495!
[  363.340] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 496!
[  363.342] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 497!
[  363.343] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 498!
[  363.344] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 499!
[  363.418] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 500!
[  363.420] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 501!
[  363.421] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 502!
[  363.422] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 503!
[  363.496] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 504!
[  363.498] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 505!
[  363.499] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 506!
[  363.500] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 507!
[  363.574] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 508!
[  363.576] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 509!
[  363.577] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 510!
[  363.578] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 511!
[  363.652] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 512!
[  363.654] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 513!
[  363.655] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 514!
[  363.656] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 515!
[  363.730] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 516!
[  363.732] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 517!
[  363.733] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 518!
[  363.734] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 519!
[  363.798] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 520!
[  363.799] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 521!
[  363.800] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 522!
[  363.802] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 523!
[  363.876] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 524!
[  363.877] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 525!
[  363.878] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 526!
[  363.880] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 527!
[  363.954] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 528!
[  363.955] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 529!
[  363.956] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 530!
[  363.958] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 531!
[  364.032] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 532!
[  364.033] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 533!
[  364.034] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 534!
[  364.036] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 535!
[  364.110] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 536!
[  364.111] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 537!
[  364.112] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 538!
[  364.114] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 539!
[  364.188] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 540!
[  364.189] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 541!
[  364.190] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 542!
[  364.192] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 543!
[  364.266] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 544!
[  364.267] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 545!
[  364.269] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 546!
[  364.270] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 547!
[  364.344] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 548!
[  364.345] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 549!
[  364.347] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 550!
[  364.348] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 551!
[  364.422] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 552!
[  364.423] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 553!
[  364.425] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 554!
[  364.426] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 555!
[  364.489] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 556!
[  364.490] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 557!
[  364.492] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 558!
[  364.493] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 559!
[  364.494] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 560!
[  364.543] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 561!
[  364.568] [INFO  ] PLCV-HL: stxCG5317_HL_Tick_Boot() Sending shared Global parameters successfull
[  364.568] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 562!
[  364.569] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x880 bytes to target address 0x1243D0
[  364.569] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.569] [INFO  ] PLCV-HL: stxCG5317_HL_Tick_Boot() Sent global parameters successfull
[  364.569] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 563!
[  364.570] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x130000
[  364.570] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.570] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 564!
[  364.572] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x1305AC
[  364.572] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.572] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 565!
[  364.609] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x130B58
[  364.609] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.622] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 566!
[  364.646] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x131104
[  364.646] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.646] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 567!
[  364.648] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x1316B0
[  364.648] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.648] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 568!
[  364.649] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x131C5C
[  364.649] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.649] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 569!
[  364.650] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x132208
[  364.651] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.651] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 570!
[  364.677] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x1327B4
[  364.677] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.690] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 571!
[  364.714] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x132D60
[  364.714] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.714] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 572!
[  364.716] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13330C
[  364.716] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.716] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 573!
[  364.717] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x1338B8
[  364.717] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.717] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 574!
[  364.718] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x133E64
[  364.718] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.719] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 575!
[  364.756] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x134410
[  364.756] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.768] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 576!
[  364.793] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x1349BC
[  364.793] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.793] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 577!
[  364.794] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x134F68
[  364.794] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.794] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 578!
[  364.796] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x135514
[  364.796] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.796] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 579!
[  364.797] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x135AC0
[  364.797] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.797] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 580!
[  364.835] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13606C
[  364.835] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.847] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 581!
[  364.871] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x136618
[  364.872] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.872] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 582!
[  364.873] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x136BC4
[  364.873] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.873] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 583!
[  364.874] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x137170
[  364.874] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.875] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 584!
[  364.876] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13771C
[  364.876] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.876] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 585!
[  364.913] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x137CC8
[  364.913] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.926] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 586!
[  364.950] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x138274
[  364.950] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.950] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 587!
[  364.952] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x138820
[  364.952] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.952] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 588!
[  364.953] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x138DCC
[  364.953] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.953] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 589!
[  364.954] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x139378
[  364.954] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  364.955] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 590!
[  364.992] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x139924
[  364.992] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.004] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 591!
[  365.029] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x139ED0
[  365.029] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.029] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 592!
[  365.030] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13A47C
[  365.030] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.030] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 593!
[  365.032] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13AA28
[  365.032] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.032] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 594!
[  365.033] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13AFD4
[  365.033] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.033] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 595!
[  365.071] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13B580
[  365.071] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.083] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 596!
[  365.107] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13BB2C
[  365.108] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.108] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 597!
[  365.109] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13C0D8
[  365.109] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.109] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 598!
[  365.110] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13C684
[  365.110] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.111] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 599!
[  365.112] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13CC30
[  365.112] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.112] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 600!
[  365.149] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13D1DC
[  365.150] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.162] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 601!
[  365.186] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13D788
[  365.186] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.186] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 602!
[  365.188] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13DD34
[  365.188] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.188] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 603!
[  365.189] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13E2E0
[  365.189] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.189] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 604!
[  365.190] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13E88C
[  365.191] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.191] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 605!
[  365.228] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13EE38
[  365.228] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.240] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 606!
[  365.265] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13F3E4
[  365.265] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.265] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 607!
[  365.266] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13F990
[  365.266] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.267] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 608!
[  365.268] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x13FF3C
[  365.268] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.268] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 609!
[  365.269] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x1404E8
[  365.269] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.269] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 610!
[  365.307] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x140A94
[  365.307] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.319] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 611!
[  365.343] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x141040
[  365.344] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.344] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 612!
[  365.345] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x1415EC
[  365.345] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.345] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 613!
[  365.346] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x141B98
[  365.346] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.347] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 614!
[  365.348] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x142144
[  365.348] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.348] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 615!
[  365.385] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x1426F0
[  365.385] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.398] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 616!
[  365.411] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x142C9C
[  365.412] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.412] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 617!
[  365.413] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x143248
[  365.413] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.413] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 618!
[  365.414] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x604 bytes to target address 0x1437F4
[  365.414] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.414] [INFO  ] PLCV-HL: stxCG5317_HL_Tick_Boot() HW Vectors sent successfully
[  365.414] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 619!
[  365.416] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x14A000
[  365.416] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.416] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 620!
[  365.453] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x14A5AC
[  365.453] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.466] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 621!
[  365.490] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x1452 bytes to target address 0x14AB58
[  365.490] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.490] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 622!
[  365.492] [INFO  ] PLCV-HL: stxCG5317_HL_SendChunksTick() Sending 0x12 bytes to target address 0x14B104
[  365.492] [INFO  ] PLCV-HL: CG5317_HLSendChunksTick() Chunk data sent successfully
[  365.492] [INFO  ] PLCV-HL: stxCG5317_HL_Tick_Boot() User config sent successfully
[  365.492] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 623!
[  365.493] [INFO  ] PLCV-HL: stxCG5317_HL_Tick_Boot() Sent Bin file section header to CG5317
[  365.493] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 624!
[  365.494] [INFO  ] PLCV-HL: stxCG5317_HL_Tick_Boot() VSM_EXECUTE_COMMAND send to CP CPU
[  365.494] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 625!
[  365.495] [NOTICE] PLCV-HL: stxCG5317_HL_Tick_Boot() boot from host finished
[  365.495] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 626!
[  366.499] [WARN  ] PLCV-HL: stxCG5317_HL_Tick(): Modem did not confirm packet with sessionId 626! Resend packet!
[  366.511] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 626!
[  367.513] [WARN  ] PLCV-HL: stxCG5317_HL_Tick(): Modem did not confirm packet with sessionId 626! Resend packet!
[  367.525] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 626!
[  368.119] [NOTICE] PLCV-HL: ---------> DISCONNECTED
[  368.132] [NOTICE] PLCV-HL: ---------> DISCONNECTED FROM AVLN
[  368.533] [WARN  ] PLCV-HL: stxCG5317_HL_Tick(): Modem did not confirm packet with sessionId 626! Resend packet!
[  368.545] [INFO  ] PLCV-HL: stxCG5317_HL_Tick():      Success sending packet 626!
[  368.557] [NOTICE] PLCV-HL: ---------> FIRMWARE RUNNING
1,242 次查看
joanxie
what SW version do you download? do you mind testing other version SW? the FW should be CG5317 FW loding, where did you get this board?
1,120 次查看
mjadan
Regarding version on i.MX 93
./stx_evse_eth -v
  Version:     V_02_00_00
  Application: Easy EVSE
  Customer:    NXP
  Target:      Linux
  CPU:         i.MX 93
  Date/Time:   Apr  5 2024 14:41:09
  Product-ID:  SEVENSTAX_LIB_V_11_02_00
1,130 次查看
mjadan
Hi Joanxie,
Thank you for your response.
The EVSE-SIG-BRD board is flashed with the program from this GitHub repository
I can confirm that it is the latest release (v1.2.0). It was built using MCUXpresso IDE with SDK version 2.14.0 and then flashed onto the board.
For the i.MX 93 EVK board, I used a Docker environment to build the system image and then flashed it onto the eMMC, following the instructions from this repository
You mentioned CG5317—I can see it in the logs I provided, for example:
Since I have two boards, could you please clarify which one should be reflashed with a different version? It would also be very helpful if you could point me to the correct software version.
Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-2344687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%94%B5%E5%8A%A8%E6%B1%BD%E8%BD%A6%E4%B8%8E%E6%A8%A1%E6%8B%9F%20EVSE%20%E4%B9%8B%E9%97%B4%E7%9A%84%20PLC%20%E9%80%9A%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9B%A2%E9%98%9F%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E6%88%91%E5%AF%B9%E7%A0%94%E7%A9%B6%E8%BD%A6%E8%BE%86%E4%B8%8E%E5%85%85%E7%94%B5%E7%AB%99%E4%B9%8B%E9%97%B4%E7%9A%84%20PLC%20%E5%92%8C%20IPv6%20%E9%80%9A%E4%BF%A1%E5%BE%88%E6%84%9F%E5%85%B4%E8%B6%A3%E3%80%82%E4%B8%BA%E4%BA%86%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%9B%AE%E6%A0%87%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20EVSE-SIG-BRD2X%20%E6%9D%BF%E5%92%8C%20i.MX%2093%20%E8%AF%84%E4%BC%B0%E5%A5%97%E4%BB%B6%E6%9D%A5%E6%A8%A1%E6%8B%9F%E5%85%85%E7%94%B5%E7%AB%99%EF%BC%8C%E4%B8%A4%E8%80%85%E9%83%BD%E8%A3%85%E6%9C%89%20EVSE%20%E8%BD%AF%E4%BB%B6%E3%80%82EVSE-SIG-BRD2X%20%E4%B8%8A%E7%9A%84%E8%B7%B3%E7%BA%BF%E6%A0%B9%E6%8D%AE%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E9%85%8D%E7%BD%AE%E4%B8%BA%20EVSE%20%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EEVSE-SIG-BRD2X%20%E7%9A%84%20CP%E3%80%81PP%20%E5%92%8C%20GND%20%E5%BC%95%E8%84%9A%E4%B8%8E%E5%85%85%E7%94%B5%E7%94%B5%E7%BC%86%E4%B8%8A%E7%9A%84%E7%9B%B8%E5%BA%94%E5%BC%95%E8%84%9A%E7%9B%B8%E8%BF%9E%E3%80%82i.MX%2093%20%E8%AF%84%E4%BC%B0%E5%A5%97%E4%BB%B6%E8%BF%90%E8%A1%8C%20Linux%20%E5%B9%B6%E6%89%A7%E8%A1%8C%20stx_evse_eth%20%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ksnip_20260402-160048.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ksnip_20260402-160048.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ksnip_20260402-160048.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ksnip_20260402-160048.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381221i0DD250B5CA3AC536%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ksnip_20260402-160048.png%22%20alt%3D%22ksnip_20260402-160048.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E8%BF%90%E8%A1%8C%E7%A8%8B%E5%BA%8F%E6%97%B6%EF%BC%8C%E7%A8%8B%E5%BA%8F%E4%BC%9A%E5%9C%A8%20%22APL%EF%BC%9A%E7%9B%91%E5%90%AC%E7%AB%AF%E5%8F%A3%207%20%22%E5%A4%84%E5%81%9C%E6%AD%A2%E6%89%A7%E8%A1%8C%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%9C%A8%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%BD%A6%E8%BE%86%E5%90%8E%E6%89%8D%E4%BC%9A%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ksnip_20260402-160317.png%22%20style%3D%22width%3A%20774px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ksnip_20260402-160317.png%22%20style%3D%22width%3A%20774px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ksnip_20260402-160317.png%22%20style%3D%22width%3A%20774px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ksnip_20260402-160317.png%22%20style%3D%22width%3A%20774px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381222i34D236ADDDCCBCFC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ksnip_20260402-160317.png%22%20alt%3D%22ksnip_20260402-160317.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E6%96%AD%E5%BC%80%E4%B8%8E%20AVLN%20%E7%9A%84%E8%BF%9E%E6%8E%A5%EF%BC%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%BD%AF%E4%BB%B6%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%20%22%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E7%9A%84%20SLAC%20%E9%85%8D%E5%AF%B9%EF%BC%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%89%A7%E8%A1%8C%E6%97%A5%E5%BF%97%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx93evk-easyevse%3A~%23%20.%2Fstx_evse_eth%0A%0A%0ASEVENSTAX%20OpenSTLinux%20Reference%20Application%20V_02_00_00%0A--------------------------------------------------%0A-%20Linux-RAW-Socket%20used%20with%20SEVENSTAX-TCP%0A%0A%0AINFO%3A%20Network%20Interface%20if0%20%3D%20eth0%0A%0A%0A%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0AWelcome%20to%20sevenstax%20Debugging!%0A%20%0AREFERENCE%20APPLICATION%3A%0A%20%20Name%3A%20%20%20%20%20%20Easy%20EVSE%0A%20%20Version%3A%20%20%20V_02_00_00%0A%20%20Build%3A%20%20%20%20%20Apr%20%205%202024%2014%3A41%3A09%0A%20%20Customer%3A%20%20NXP%0A%20%20Target%3A%20%20%20%20Linux%0A%20%20CPU%3A%20%20%20%20%20%20%20i.MX%2093%0A%20%0ASEVENSTAX%20PRODUCT%20VERSION%3A%0A%20%20SEVENSTAX_LIB_V_11_02_00%0A%20%0APROTOCOLS%20CONFIGURATION%3A%0A%20%5Bx%5D%20IP-MULTI-DEVICE%0A%20%5Bx%5D%20IPv4%2F6%3A%205%20instances%0A%20%20%20%20%20%20%5B%20%5D%20IPv4%0A%20%20%20%20%20%20%5Bx%5D%20IPv6%0A%20%20%20%20%20%20%5Bx%5D%20IPv6%20Fragmentation%0A%20%20%20%20%20%20%20%20%20%20%5Bx%5D%20Rx%20fragments%20(1x2000%20bytes)%0A%20%20%20%20%20%20%20%20%20%20%5Bx%5D%20Tx%20fragments%20(1%20instances%20)%0A%20%5Bx%5D%20Ethernet%20Interface%0A%20%20%20%20%20%20%5B%20%5D%20DHCP%20client%0A%20%20%20%20%20%20%5B%20%5D%20DHCP%20server%0A%20%20%20%20%20%20%5B%20%5D%20BOOTP%0A%20%20%20%20%20%20%5B%20%5D%20Auto-IP%0A%20%20%20%20%20%20%5B%20%5D%20WLAN%20Driver%2FService%0A%20%5B%20%5D%20PPP%0A%20%5B%20%5D%20ICMP%0A%20%5B%20%5D%20IGMP%0A%20%5Bx%5D%20TCP%20(5%20instances)%0A%20%20%20%20%20%20%5B%20%5D%20HTTP%20server%0A%20%20%20%20%20%20%5B%20%5D%20SOAP%20Client%0A%20%20%20%20%20%20%5B%20%5D%20ReST%20Module%0A%20%20%20%20%20%20%5Bx%5D%20HTTP%20Client%0A%20%20%20%20%20%20%5B%20%5D%20TELNET%20server%0A%20%20%20%20%20%20%5B%20%5D%20NVT%0A%20%20%20%20%20%20%5B%20%5D%20XMPP%0A%20%20%20%20%20%20%5B%20%5D%20SMTP%0A%20%20%20%20%20%20%5B%20%5D%20POP3%0A%20%5Bx%5D%20UDP%20(5%20instances)%0A%20%20%20%20%20%20%5B%20%5D%20NTP%0A%20%20%20%20%20%20%5B%20%5D%20SNMP%20agent%0A%20%20%20%20%20%20%5B%20%5D%20DNS%20client%0A%20%20%20%20%20%20%5B%20%5D%20DNS%20client%2Fserver%0A%20%20%20%20%20%20%5B%20%5D%20mDNS%2FDNS-SD%0A%20%20%20%20%20%20%5B%20%5D%20MDNS-Service%0A%20%20%20%20%20%20%5B%20%5D%20NBNS%0A%20%20%20%20%20%20%5B%20%5D%20LLMNR%0A%20%20%20%20%20%20%5B%20%5D%20TFTP%20client%2Fserver%0A%20%20%20%20%20%20%5B%20%5D%20PTP%0A%20%5B%20%5D%20RTOSWrapper%0A%20%20%20%20%20%20%5B%20%5D%20CMX%0A%20%20%20%20%20%20%5B%20%5D%20Segger%20embOS%0A%20%20%20%20%20%20%5B%20%5D%20SCIOPTA%0A%20%5Bx%5D%20VFS%20(15%20instances)%0A%20%20%20%20%20%20%5B%20%5D%20Static%20ROM-Files%0A%20%20%20%20%20%20%5B%20%5D%20STX-Filesystem%0A%20%20%20%20%20%20%5B%20%5D%20Static%20Lookup-Table%0A%20%20%20%20%20%20%5B%20%5D%20Dynamic%20FAT%20Access%0A%20%0ASPECIAL%20TEST%20CONFIGURATION%3A%0A%20%5Bx%5D%20DebugOuts%0A%20%5B%20%5D%20User%20Management%0A%20%5B%20%5D%20RANDOM%20MAC%20address%0A%20%5B%20%5D%20TCP-Echo%0A%20%5B%20%5D%20TCP-Echo%20RTOS%0A%20%5B%20%5D%20JavaGraph%20Applet%20(no%20TCP)%0A%20%5Bx%5D%20UDP-Echo%20(Port%207%2C%202000%20bytes)%0A%20%5B%20%5D%20UDP-Echo%20RTOS%0A%20%5B%20%5D%20TFTP-Demo%0A%20%5B%20%5D%20IGMP%20Testgroup%0A%20%5Bx%5D%20NameServices%20Wrapper%0A%20%5B%20%5D%20WLAN-Test-Sequence%20enabled%0A%20%5B%20%5D%20NameService-Test-Sequence%20enabled%0A%20%0AAPPLICATION%20RUNNING%20...%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Init()%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Config()%0A%5B%20%20%20%200.003%5D%20SECCDP%3A%20stxSeccDPS_Init()%20called!%0A%5B%20%20%20%200.003%5D%20%5BDEBUG%20%5D%20APL-ETH%3A%20stxRefApp_Eth_Init()%20called%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%26gt%3B%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%20%20RefApp%20Network%20Layer%20configurations%20%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%20%20L1-%26gt%3BL2-%26gt%3BL3%20linkage%3A%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%20%20----------------------------------------------------%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%20%20Interface%20Configuration%5B0%5D%3A%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20PLC-HL%3A%20stxPLC_HL_SetMac()%0A%5B%20%20%20%200.003%5D%20%5BNOTICE%5D%20APL-ETH%3A%20%20%20MAC%20of%20NIC%5B0%5D%3A%20%2000%3A01%3A01%3A74%3A6b%3A30%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%20%20L1%20Device%20Name%3A%20plc0%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%20%20L2%20Type%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Ethernet%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%20%20L3%20IPv6%20Handle%5B0%5D%3A%20%20%20%20%20%200xfe00%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%20%20----------------------------------------------------%0A%5B%20%20%20%200.003%5D%20%5BINFO%20%20%5D%20APL-ETH%3A%20%26lt%3B%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%5B%20%20%20%200.003%5D%20%5BDEBUG%20%5D%20APL-ETH%3A%20%20%20stxRefApp_Eth_Init()%20finished%0A%5B%20%20%20%200.003%5D%20APL%3A%20UDP-Echo%20enabled%3A%0A%5B%20%20%20%200.003%5D%20APL%3A%20%20%20Listen%20Port%207%0A%5B%20%20%2029.909%5D%20%5BDEBUG%20%5D%20V2GAPP%3A%20stxV2GAppl_Init()%0A%5B%20%20%2029.909%5D%20%5BNOTICE%5D%20SLAC%3A%20stxSLAC_Init()%0A%5B%20%20%2029.910%5D%20%5BDEBUG%20%5D%20V2GAPP%3A%20stxV2GAppl_Start()%0A%5B%20%20%2029.910%5D%20%5BDEBUG%20%5D%20V2GAPP%3A%20STATE%20%3D%20X%20%3D%26gt%3B%20APPLV2G_STATE_INIT%0A%5B%20%20%2029.910%5D%20%5BDEBUG%20%5D%20APL-ETH%3A%20stxRefApp_Eth_Start()%20called%0A%5B%20%20%2029.910%5D%20%5BINFO%20%20%5D%20PLC-HL%3A%20stxPLC_HL_Start()%0A%5B%20%20%2029.934%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Start()%0A%5B%20%20%2029.934%5D%20%5BDEBUG%20%5D%20APL-ETH%3A%20stxRefApp_Eth_Start()%20finished%0A%5B%20%20%2029.934%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Reset%20CG5317%0A%5B%20%20%2029.934%5D%20%5BNOTICE%5D%20TLSLIB%3A%20DRBG%20initialized.%0A%5B%20%20%2059.664%5D%20%5BNOTICE%5D%20SLAC%3A%20stxSLAC_Stop()%0A%5B%20%20%2059.664%5D%20SECCDP%3A%20stxSeccDPS_Stop()%20called!%0A%5B%20%20%2059.664%5D%20%5BDEBUG%20%5D%20V2GAPP%3A%20STATE%20%3D%20APPLV2G_STATE_INIT%20%3D%26gt%3B%20APPLV2G_STATE_INITIALIZED%0A%5B%20%20%2089.662%5D%20%5BDEBUG%20%5D%20V2GAPP%3A%20STATE%20%3D%20APPLV2G_STATE_INITIALIZED%20%3D%26gt%3B%20APPLV2G_STATE_DETECT_MODE%0A%5B%20%20%2089.662%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Init%0A%5B%20%20179.339%5D%20%5BDEBUG%20%5D%20V2GAPP%3A%20EVSE%20STATE%20%3D%20APPLV2G_STATE_DETECT_MODE%20%3D%26gt%3B%20APPLV2G_STATE_SLAC_START_PRE%0A%5B%20%20209.256%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20257!%0A%5B%20%20239.163%5D%20%5BWARN%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Modem%20did%20not%20confirm%20packet%20with%20sessionId%20257!%20Resend%20packet!%0A%5B%20%20269.073%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20257!%0A%5B%20%20269.097%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20---------%26gt%3B%20FIRMWARE%20STOPPED%0A%5B%20%20269.098%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20---------%26gt%3B%20FIRMWARE%20STOPPED%0A%5B%20%20269.099%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20%20%20stxCG5317_HL_Tick_Boot()%3A%20device%20is%20in%20host%20loading%20mode%0A%5B%20%20269.101%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20EBL%20section%20data%20had%20been%20loaded%0A%5B%20%20269.105%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20258!%0A%5B%20%20269.112%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20259!%0A%5B%20%20269.117%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20260!%0A%5B%20%20269.122%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20261!%0A%5B%20%20269.124%5D%20%5BNOTICE%5D%20V2GAPP%3A%20%23%20V2GCPS_INFOTYPE_CP_STATE%0A%5B%20%20269.126%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20262!%0A%5B%20%20269.133%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20263!%0A%5B%20%20269.140%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20264!%0A%5B%20%20269.143%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20265!%0A%5B%20%20269.144%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20266!%0A%5B%20%20269.145%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20267!%0A%5B%20%20269.147%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20268!%0A%5B%20%20299.054%5D%20%5BWARN%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Modem%20did%20not%20confirm%20packet%20with%20sessionId%20268!%20Resend%20packet!%0A%5B%20%20328.959%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20268!%0A%5B%20%20358.852%5D%20%5BWARN%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Modem%20did%20not%20confirm%20packet%20with%20sessionId%20268!%20Resend%20packet!%0A%5B%20%20358.852%5D%20%5BWARN%20%20%5D%20PLCV-HL%3A%20Got%20non%20zero%20status%20code%20from%20VSM%20response.%20Code%200x7%0A%5B%20%20358.852%5D%20%5BERROR%20%5D%20PLCV-HL%3A%20Aborting%20Image%20Upload%20due%20to%20non-zero%20status%20code%20in%20VSM%20response.%20Code%3A%200x7%0A%5B%20%20358.865%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20268!%0A%5B%20%20358.877%5D%20%5BWARN%20%20%5D%20PLCV-HL%3A%20Got%20non%20zero%20status%20code%20from%20VSM%20response.%20Code%200x7%0A%5B%20%20358.877%5D%20%5BERROR%20%5D%20PLCV-HL%3A%20Aborting%20Image%20Upload%20due%20to%20non-zero%20status%20code%20in%20VSM%20response.%20Code%3A%200x7%0A%5B%20%20358.890%5D%20%5BERROR%20%5D%20PLCV-HL%3A%20stxCG5317_HL_FW_Tick_UploadCpuImage()%3A%20Got%20erronous%20response.%20Aborting%20upload%20process%0A%5B%20%20358.890%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Reset%20CG5317%0A%5B%20%20359.405%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Init%0A%5B%20%20359.429%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20269!%0A%5B%20%20359.430%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20---------%26gt%3B%20FIRMWARE%20STOPPED%0A%5B%20%20359.430%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20%20%20stxCG5317_HL_Tick_Boot()%3A%20device%20is%20in%20host%20loading%20mode%0A%5B%20%20359.430%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20EBL%20section%20data%20had%20been%20loaded%0A%5B%20%20359.431%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20270!%0A%5B%20%20359.432%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20271!%0A%5B%20%20359.433%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20272!%0A%5B%20%20359.434%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20273!%0A%5B%20%20359.508%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20274!%0A%5B%20%20359.510%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20275!%0A%5B%20%20359.511%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20276!%0A%5B%20%20359.512%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20277!%0A%5B%20%20359.514%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20278!%0A%5B%20%20359.577%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20279!%0A%5B%20%20359.578%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20280!%0A%5B%20%20359.580%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20281!%0A%5B%20%20359.581%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20282!%0A%5B%20%20359.582%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20283!%0A%5B%20%20359.656%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20284!%0A%5B%20%20359.657%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20285!%0A%5B%20%20359.658%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20286!%0A%5B%20%20359.660%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20287!%0A%5B%20%20359.661%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20288!%0A%5B%20%20359.735%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20289!%0A%5B%20%20359.736%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20290!%0A%5B%20%20359.737%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20291!%0A%5B%20%20359.739%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20292!%0A%5B%20%20359.740%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20293!%0A%5B%20%20359.803%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20294!%0A%5B%20%20359.804%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20295!%0A%5B%20%20359.805%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20296!%0A%5B%20%20359.807%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20297!%0A%5B%20%20359.808%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20298!%0A%5B%20%20359.882%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20299!%0A%5B%20%20359.883%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20300!%0A%5B%20%20359.884%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20301!%0A%5B%20%20359.886%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20302!%0A%5B%20%20359.887%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20303!%0A%5B%20%20359.961%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20304!%0A%5B%20%20359.962%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20305!%0A%5B%20%20359.963%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20306!%0A%5B%20%20359.964%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20307!%0A%5B%20%20359.966%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20308!%0A%5B%20%20360.039%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20309!%0A%5B%20%20360.041%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20310!%0A%5B%20%20360.042%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20311!%0A%5B%20%20360.043%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20312!%0A%5B%20%20360.045%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20313!%0A%5B%20%20360.118%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20314!%0A%5B%20%20360.120%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20315!%0A%5B%20%20360.121%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20316!%0A%5B%20%20360.122%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20317!%0A%5B%20%20360.124%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20318!%0A%5B%20%20360.197%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20319!%0A%5B%20%20360.199%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20320!%0A%5B%20%20360.200%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20321!%0A%5B%20%20360.201%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20322!%0A%5B%20%20360.203%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20323!%0A%5B%20%20360.276%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20324!%0A%5B%20%20360.278%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20325!%0A%5B%20%20360.279%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20326!%0A%5B%20%20360.280%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20327!%0A%5B%20%20360.282%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20328!%0A%5B%20%20360.355%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20329!%0A%5B%20%20360.357%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20330!%0A%5B%20%20360.358%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20331!%0A%5B%20%20360.359%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20332!%0A%5B%20%20360.361%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20333!%0A%5B%20%20360.434%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20334!%0A%5B%20%20360.436%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20335!%0A%5B%20%20360.437%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20336!%0A%5B%20%20360.438%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20337!%0A%5B%20%20360.440%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20338!%0A%5B%20%20360.503%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20339!%0A%5B%20%20360.504%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20340!%0A%5B%20%20360.505%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20341!%0A%5B%20%20360.506%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20342!%0A%5B%20%20360.508%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20343!%0A%5B%20%20360.557%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20344!%0A%5B%20%20360.582%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20345!%0A%5B%20%20360.583%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20346!%0A%5B%20%20360.584%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20347!%0A%5B%20%20360.586%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20348!%0A%5B%20%20360.587%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20349!%0A%5B%20%20360.660%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20350!%0A%5B%20%20360.661%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20351!%0A%5B%20%20360.663%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20352!%0A%5B%20%20360.664%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20353!%0A%5B%20%20360.738%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20354!%0A%5B%20%20360.739%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20355!%0A%5B%20%20360.741%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20356!%0A%5B%20%20360.742%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20357!%0A%5B%20%20360.816%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20358!%0A%5B%20%20360.817%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20359!%0A%5B%20%20360.819%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20360!%0A%5B%20%20360.820%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20361!%0A%5B%20%20360.894%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20362!%0A%5B%20%20360.895%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20363!%0A%5B%20%20360.897%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20364!%0A%5B%20%20360.898%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20365!%0A%5B%20%20360.972%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20366!%0A%5B%20%20360.973%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20367!%0A%5B%20%20360.975%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20368!%0A%5B%20%20360.976%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20369!%0A%5B%20%20361.050%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20370!%0A%5B%20%20361.051%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20371!%0A%5B%20%20361.053%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20372!%0A%5B%20%20361.054%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20373!%0A%5B%20%20361.128%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20374!%0A%5B%20%20361.129%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20375!%0A%5B%20%20361.131%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20376!%0A%5B%20%20361.132%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20377!%0A%5B%20%20361.133%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20378!%0A%5B%20%20361.194%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20379!%0A%5B%20%20361.207%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20380!%0A%5B%20%20361.208%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20381!%0A%5B%20%20361.209%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20382!%0A%5B%20%20361.211%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20383!%0A%5B%20%20361.274%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20384!%0A%5B%20%20361.275%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20385!%0A%5B%20%20361.276%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20386!%0A%5B%20%20361.278%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20387!%0A%5B%20%20361.352%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20388!%0A%5B%20%20361.353%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20389!%0A%5B%20%20361.354%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20390!%0A%5B%20%20361.356%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20391!%0A%5B%20%20361.419%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20392!%0A%5B%20%20361.420%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20393!%0A%5B%20%20361.422%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20394!%0A%5B%20%20361.423%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20395!%0A%5B%20%20361.497%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20396!%0A%5B%20%20361.498%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20397!%0A%5B%20%20361.500%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20398!%0A%5B%20%20361.501%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20399!%0A%5B%20%20361.575%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20400!%0A%5B%20%20361.576%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20401!%0A%5B%20%20361.578%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20402!%0A%5B%20%20361.579%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20403!%0A%5B%20%20361.653%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20404!%0A%5B%20%20361.655%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20405!%0A%5B%20%20361.656%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20406!%0A%5B%20%20361.657%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20407!%0A%5B%20%20361.731%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20408!%0A%5B%20%20361.733%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20409!%0A%5B%20%20361.734%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20410!%0A%5B%20%20361.735%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20411!%0A%5B%20%20361.809%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20412!%0A%5B%20%20361.811%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20413!%0A%5B%20%20361.812%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20414!%0A%5B%20%20361.813%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20415!%0A%5B%20%20361.887%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20416!%0A%5B%20%20361.889%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20417!%0A%5B%20%20361.890%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20418!%0A%5B%20%20361.891%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20419!%0A%5B%20%20361.965%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20420!%0A%5B%20%20361.967%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20421!%0A%5B%20%20361.968%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20422!%0A%5B%20%20361.969%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20423!%0A%5B%20%20361.970%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20424!%0A%5B%20%20362.031%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20425!%0A%5B%20%20362.044%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20426!%0A%5B%20%20362.045%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20427!%0A%5B%20%20362.046%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20428!%0A%5B%20%20362.048%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20429!%0A%5B%20%20362.122%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20430!%0A%5B%20%20362.123%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20431!%0A%5B%20%20362.124%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20432!%0A%5B%20%20362.126%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20433!%0A%5B%20%20362.189%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20434!%0A%5B%20%20362.191%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20435!%0A%5B%20%20362.192%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20436!%0A%5B%20%20362.193%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20437!%0A%5B%20%20362.267%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20438!%0A%5B%20%20362.268%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20439!%0A%5B%20%20362.270%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20440!%0A%5B%20%20362.271%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20441!%0A%5B%20%20362.345%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20442!%0A%5B%20%20362.347%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20443!%0A%5B%20%20362.348%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20444!%0A%5B%20%20362.349%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20445!%0A%5B%20%20362.423%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20446!%0A%5B%20%20362.425%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20447!%0A%5B%20%20362.426%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20448!%0A%5B%20%20362.427%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20449!%0A%5B%20%20362.501%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20450!%0A%5B%20%20362.503%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20451!%0A%5B%20%20362.504%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20452!%0A%5B%20%20362.505%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20453!%0A%5B%20%20362.579%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20454!%0A%5B%20%20362.581%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20455!%0A%5B%20%20362.582%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20456!%0A%5B%20%20362.583%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20457!%0A%5B%20%20362.657%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20458!%0A%5B%20%20362.659%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20459!%0A%5B%20%20362.660%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20460!%0A%5B%20%20362.661%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20461!%0A%5B%20%20362.735%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20462!%0A%5B%20%20362.737%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20463!%0A%5B%20%20362.738%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20464!%0A%5B%20%20362.739%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20465!%0A%5B%20%20362.813%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20466!%0A%5B%20%20362.815%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20467!%0A%5B%20%20362.816%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20468!%0A%5B%20%20362.817%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20469!%0A%5B%20%20362.819%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20470!%0A%5B%20%20362.882%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20471!%0A%5B%20%20362.883%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20472!%0A%5B%20%20362.884%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20473!%0A%5B%20%20362.886%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20474!%0A%5B%20%20362.887%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20475!%0A%5B%20%20362.961%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20476!%0A%5B%20%20362.962%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20477!%0A%5B%20%20362.963%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20478!%0A%5B%20%20362.965%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20479!%0A%5B%20%20363.028%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20480!%0A%5B%20%20363.029%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20481!%0A%5B%20%20363.031%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20482!%0A%5B%20%20363.032%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20483!%0A%5B%20%20363.106%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20484!%0A%5B%20%20363.107%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20485!%0A%5B%20%20363.109%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20486!%0A%5B%20%20363.110%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20487!%0A%5B%20%20363.184%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20488!%0A%5B%20%20363.185%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20489!%0A%5B%20%20363.187%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20490!%0A%5B%20%20363.188%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20491!%0A%5B%20%20363.262%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20492!%0A%5B%20%20363.264%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20493!%0A%5B%20%20363.265%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20494!%0A%5B%20%20363.266%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20495!%0A%5B%20%20363.340%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20496!%0A%5B%20%20363.342%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20497!%0A%5B%20%20363.343%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20498!%0A%5B%20%20363.344%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20499!%0A%5B%20%20363.418%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20500!%0A%5B%20%20363.420%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20501!%0A%5B%20%20363.421%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20502!%0A%5B%20%20363.422%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20503!%0A%5B%20%20363.496%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20504!%0A%5B%20%20363.498%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20505!%0A%5B%20%20363.499%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20506!%0A%5B%20%20363.500%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20507!%0A%5B%20%20363.574%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20508!%0A%5B%20%20363.576%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20509!%0A%5B%20%20363.577%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20510!%0A%5B%20%20363.578%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20511!%0A%5B%20%20363.652%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20512!%0A%5B%20%20363.654%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20513!%0A%5B%20%20363.655%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20514!%0A%5B%20%20363.656%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20515!%0A%5B%20%20363.730%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20516!%0A%5B%20%20363.732%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20517!%0A%5B%20%20363.733%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20518!%0A%5B%20%20363.734%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20519!%0A%5B%20%20363.798%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20520!%0A%5B%20%20363.799%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20521!%0A%5B%20%20363.800%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20522!%0A%5B%20%20363.802%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20523!%0A%5B%20%20363.876%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20524!%0A%5B%20%20363.877%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20525!%0A%5B%20%20363.878%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20526!%0A%5B%20%20363.880%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20527!%0A%5B%20%20363.954%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20528!%0A%5B%20%20363.955%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20529!%0A%5B%20%20363.956%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20530!%0A%5B%20%20363.958%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20531!%0A%5B%20%20364.032%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20532!%0A%5B%20%20364.033%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20533!%0A%5B%20%20364.034%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20534!%0A%5B%20%20364.036%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20535!%0A%5B%20%20364.110%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20536!%0A%5B%20%20364.111%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20537!%0A%5B%20%20364.112%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20538!%0A%5B%20%20364.114%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20539!%0A%5B%20%20364.188%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20540!%0A%5B%20%20364.189%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20541!%0A%5B%20%20364.190%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20542!%0A%5B%20%20364.192%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20543!%0A%5B%20%20364.266%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20544!%0A%5B%20%20364.267%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20545!%0A%5B%20%20364.269%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20546!%0A%5B%20%20364.270%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20547!%0A%5B%20%20364.344%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20548!%0A%5B%20%20364.345%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20549!%0A%5B%20%20364.347%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20550!%0A%5B%20%20364.348%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20551!%0A%5B%20%20364.422%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20552!%0A%5B%20%20364.423%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20553!%0A%5B%20%20364.425%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20554!%0A%5B%20%20364.426%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20555!%0A%5B%20%20364.489%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20556!%0A%5B%20%20364.490%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20557!%0A%5B%20%20364.492%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20558!%0A%5B%20%20364.493%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20559!%0A%5B%20%20364.494%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20560!%0A%5B%20%20364.543%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20561!%0A%5B%20%20364.568%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick_Boot()%20Sending%20shared%20Global%20parameters%20successfull%0A%5B%20%20364.568%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20562!%0A%5B%20%20364.569%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x880%20bytes%20to%20target%20address%200x1243D0%0A%5B%20%20364.569%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.569%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick_Boot()%20Sent%20global%20parameters%20successfull%0A%5B%20%20364.569%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20563!%0A%5B%20%20364.570%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x130000%0A%5B%20%20364.570%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.570%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20564!%0A%5B%20%20364.572%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x1305AC%0A%5B%20%20364.572%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.572%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20565!%0A%5B%20%20364.609%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x130B58%0A%5B%20%20364.609%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.622%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20566!%0A%5B%20%20364.646%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x131104%0A%5B%20%20364.646%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.646%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20567!%0A%5B%20%20364.648%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x1316B0%0A%5B%20%20364.648%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.648%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20568!%0A%5B%20%20364.649%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x131C5C%0A%5B%20%20364.649%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.649%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20569!%0A%5B%20%20364.650%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x132208%0A%5B%20%20364.651%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.651%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20570!%0A%5B%20%20364.677%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x1327B4%0A%5B%20%20364.677%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.690%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20571!%0A%5B%20%20364.714%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x132D60%0A%5B%20%20364.714%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.714%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20572!%0A%5B%20%20364.716%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13330C%0A%5B%20%20364.716%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.716%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20573!%0A%5B%20%20364.717%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x1338B8%0A%5B%20%20364.717%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.717%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20574!%0A%5B%20%20364.718%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x133E64%0A%5B%20%20364.718%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.719%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20575!%0A%5B%20%20364.756%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x134410%0A%5B%20%20364.756%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.768%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20576!%0A%5B%20%20364.793%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x1349BC%0A%5B%20%20364.793%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.793%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20577!%0A%5B%20%20364.794%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x134F68%0A%5B%20%20364.794%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.794%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20578!%0A%5B%20%20364.796%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x135514%0A%5B%20%20364.796%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.796%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20579!%0A%5B%20%20364.797%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x135AC0%0A%5B%20%20364.797%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.797%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20580!%0A%5B%20%20364.835%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13606C%0A%5B%20%20364.835%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.847%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20581!%0A%5B%20%20364.871%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x136618%0A%5B%20%20364.872%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.872%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20582!%0A%5B%20%20364.873%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x136BC4%0A%5B%20%20364.873%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.873%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20583!%0A%5B%20%20364.874%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x137170%0A%5B%20%20364.874%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.875%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20584!%0A%5B%20%20364.876%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13771C%0A%5B%20%20364.876%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.876%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20585!%0A%5B%20%20364.913%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x137CC8%0A%5B%20%20364.913%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.926%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20586!%0A%5B%20%20364.950%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x138274%0A%5B%20%20364.950%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.950%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20587!%0A%5B%20%20364.952%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x138820%0A%5B%20%20364.952%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.952%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20588!%0A%5B%20%20364.953%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x138DCC%0A%5B%20%20364.953%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.953%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20589!%0A%5B%20%20364.954%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x139378%0A%5B%20%20364.954%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20364.955%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20590!%0A%5B%20%20364.992%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x139924%0A%5B%20%20364.992%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.004%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20591!%0A%5B%20%20365.029%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x139ED0%0A%5B%20%20365.029%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.029%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20592!%0A%5B%20%20365.030%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13A47C%0A%5B%20%20365.030%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.030%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20593!%0A%5B%20%20365.032%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13AA28%0A%5B%20%20365.032%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.032%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20594!%0A%5B%20%20365.033%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13AFD4%0A%5B%20%20365.033%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.033%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20595!%0A%5B%20%20365.071%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13B580%0A%5B%20%20365.071%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.083%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20596!%0A%5B%20%20365.107%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13BB2C%0A%5B%20%20365.108%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.108%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20597!%0A%5B%20%20365.109%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13C0D8%0A%5B%20%20365.109%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.109%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20598!%0A%5B%20%20365.110%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13C684%0A%5B%20%20365.110%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.111%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20599!%0A%5B%20%20365.112%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13CC30%0A%5B%20%20365.112%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.112%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20600!%0A%5B%20%20365.149%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13D1DC%0A%5B%20%20365.150%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.162%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20601!%0A%5B%20%20365.186%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13D788%0A%5B%20%20365.186%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.186%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20602!%0A%5B%20%20365.188%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13DD34%0A%5B%20%20365.188%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.188%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20603!%0A%5B%20%20365.189%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13E2E0%0A%5B%20%20365.189%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.189%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20604!%0A%5B%20%20365.190%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13E88C%0A%5B%20%20365.191%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.191%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20605!%0A%5B%20%20365.228%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13EE38%0A%5B%20%20365.228%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.240%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20606!%0A%5B%20%20365.265%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13F3E4%0A%5B%20%20365.265%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.265%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20607!%0A%5B%20%20365.266%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13F990%0A%5B%20%20365.266%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.267%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20608!%0A%5B%20%20365.268%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x13FF3C%0A%5B%20%20365.268%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.268%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20609!%0A%5B%20%20365.269%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x1404E8%0A%5B%20%20365.269%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.269%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20610!%0A%5B%20%20365.307%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x140A94%0A%5B%20%20365.307%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.319%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20611!%0A%5B%20%20365.343%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x141040%0A%5B%20%20365.344%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.344%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20612!%0A%5B%20%20365.345%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x1415EC%0A%5B%20%20365.345%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.345%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20613!%0A%5B%20%20365.346%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x141B98%0A%5B%20%20365.346%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.347%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20614!%0A%5B%20%20365.348%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x142144%0A%5B%20%20365.348%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.348%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20615!%0A%5B%20%20365.385%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x1426F0%0A%5B%20%20365.385%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.398%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20616!%0A%5B%20%20365.411%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x142C9C%0A%5B%20%20365.412%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.412%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20617!%0A%5B%20%20365.413%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x143248%0A%5B%20%20365.413%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.413%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20618!%0A%5B%20%20365.414%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x604%20bytes%20to%20target%20address%200x1437F4%0A%5B%20%20365.414%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.414%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick_Boot()%20HW%20Vectors%20sent%20successfully%0A%5B%20%20365.414%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20619!%0A%5B%20%20365.416%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x14A000%0A%5B%20%20365.416%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.416%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20620!%0A%5B%20%20365.453%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x14A5AC%0A%5B%20%20365.453%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.466%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20621!%0A%5B%20%20365.490%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x1452%20bytes%20to%20target%20address%200x14AB58%0A%5B%20%20365.490%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.490%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20622!%0A%5B%20%20365.492%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_SendChunksTick()%20Sending%200x12%20bytes%20to%20target%20address%200x14B104%0A%5B%20%20365.492%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20CG5317_HLSendChunksTick()%20Chunk%20data%20sent%20successfully%0A%5B%20%20365.492%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick_Boot()%20User%20config%20sent%20successfully%0A%5B%20%20365.492%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20623!%0A%5B%20%20365.493%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick_Boot()%20Sent%20Bin%20file%20section%20header%20to%20CG5317%0A%5B%20%20365.493%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20624!%0A%5B%20%20365.494%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick_Boot()%20VSM_EXECUTE_COMMAND%20send%20to%20CP%20CPU%0A%5B%20%20365.494%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20625!%0A%5B%20%20365.495%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick_Boot()%20boot%20from%20host%20finished%0A%5B%20%20365.495%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20626!%0A%5B%20%20366.499%5D%20%5BWARN%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Modem%20did%20not%20confirm%20packet%20with%20sessionId%20626!%20Resend%20packet!%0A%5B%20%20366.511%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20626!%0A%5B%20%20367.513%5D%20%5BWARN%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Modem%20did%20not%20confirm%20packet%20with%20sessionId%20626!%20Resend%20packet!%0A%5B%20%20367.525%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20626!%0A%5B%20%20368.119%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20---------%26gt%3B%20DISCONNECTED%0A%5B%20%20368.132%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20---------%26gt%3B%20DISCONNECTED%20FROM%20AVLN%0A%5B%20%20368.533%5D%20%5BWARN%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20Modem%20did%20not%20confirm%20packet%20with%20sessionId%20626!%20Resend%20packet!%0A%5B%20%20368.545%5D%20%5BINFO%20%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Tick()%3A%20%20%20%20%20%20Success%20sending%20packet%20626!%0A%5B%20%20368.557%5D%20%5BNOTICE%5D%20PLCV-HL%3A%20---------%26gt%3B%20FIRMWARE%20RUNNING%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2344687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2345074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PLC%20communication%20betwee%20EV%20and%20simulated%20EVSE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E4%B8%8B%E8%BD%BD%E7%9A%84%20SW%20%E7%89%88%E6%9C%AC%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E4%BD%A0%E4%BB%8B%E6%84%8F%E6%B5%8B%E8%AF%95%E5%85%B6%E4%BB%96%E7%89%88%E6%9C%AC%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%90%97%EF%BC%9F%E5%9B%BA%E4%BB%B6%E5%BA%94%E8%AF%A5%E6%98%AF%20CG5317%20FW%20%E5%8A%A0%E8%BD%BD%EF%BC%8C%E4%BD%A0%E4%BB%8E%E5%93%AA%E9%87%8C%E5%BE%97%E5%88%B0%E8%BF%99%E4%B8%AA%E6%9D%BF%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PLC%20communication%20betwee%20EV%20and%20simulated%20EVSE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%B3%E4%BA%8E%20i.MX%2093%20%E7%9A%84%E7%89%88%E6%9C%AC%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E.%2Fstx_evse_eth%20-v%0A%0A%0ASEVENSTAX%20OpenSTLinux%20Reference%20Application%20V_02_00_00%0A--------------------------------------------------%0A-%20Linux-RAW-Socket%20used%20with%20SEVENSTAX-TCP%0A%0A%0A%20%20Version%3A%20%20%20%20%20V_02_00_00%0A%20%20Application%3A%20Easy%20EVSE%0A%20%20Customer%3A%20%20%20%20NXP%0A%20%20Target%3A%20%20%20%20%20%20Linux%0A%20%20CPU%3A%20%20%20%20%20%20%20%20%20i.MX%2093%0A%20%20Date%2FTime%3A%20%20%20Apr%20%205%202024%2014%3A41%3A09%0A%20%20Product-ID%3A%20%20SEVENSTAX_LIB_V_11_02_00%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PLC%20communication%20betwee%20EV%20and%20simulated%20EVSE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E5%97%A8%EF%BC%8C%E7%90%BC%E8%A5%BF%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%EF%BC%8C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EThe%20EVSE-SIG-BRD%20%E6%9D%BF%20is%20flashed%20with%20the%20program%20from%20this%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-appcodehub%2Fdm-lpc5536-evse-sigbrd%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGitHub%20%E5%AD%98%E5%82%A8%E5%BA%93%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EI%20can%20confirm%20that%20it%20is%20the%20latest%20%E7%89%88%E6%9C%AC%20(v1.2.0).%20It%20was%20built%20using%20MCUXpresso%20IDE%20with%20SDK%20version%202.14.0%20and%20then%20flashed%20onto%20the%20%E6%9D%BF.%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E5%AF%B9%E4%BA%8E%20i.MX%2093%20EVK%20%E6%9D%BF%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-docker%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%AE%B9%E5%99%A8%E7%8E%AF%E5%A2%83%3C%2FA%3E%20%E7%89%88%E6%9C%AC%E4%BA%86%E7%B3%BB%E7%BB%9F%E6%98%A0%E5%83%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E6%8C%89%E7%85%A7%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-nxp-easyevse-mpu%2Ftree%2Frelease%2Feasyevse-mpu-2.0%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E8%BF%99%E4%B8%AA%E5%AD%98%E5%82%A8%E5%BA%93%3C%2FA%3E%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E5%B0%86%E5%85%B6%E5%88%B7%E6%96%B0%E5%88%B0%20eMMC%20%E4%B8%8A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E4%BD%A0%E6%8F%90%E5%88%B0%E4%BA%86%20CG5317%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%88%91%E6%8F%90%E4%BE%9B%E7%9A%84%E6%97%A5%E5%BF%97%E4%B8%AD%E7%9C%8B%E5%88%B0%E5%AE%83%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EAPPLICATION%20RUNNING%20...%0A%5B%200.003%5D%20%5BINFO%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Init()%0A%5B%200.003%5D%20%5BINFO%20%5D%20PLCV-HL%3A%20stxCG5317_HL_Config()%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E6%97%A2%E7%84%B6%E6%88%91%E6%9C%89%E4%B8%A4%E5%9D%97%E6%9D%BF%EF%BC%8C%E4%BD%A0%E8%83%BD%E5%90%A6%E6%BE%84%E6%B8%85%E4%B8%80%E4%B8%8B%E5%BA%94%E8%AF%A5%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E7%89%88%E6%9C%AC%E9%87%8D%E6%96%B0%E5%88%B7%E6%96%B0%E5%93%AA%E4%B8%80%E5%9D%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%8C%E9%82%A3%E5%B0%86%E4%BC%9A%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
