PEG Lite Example for OM13092 (LPCXpresso54608)
2,508件の閲覧回数
mattschrader
I'm getting up and running with the OM13092 (LPCXpresso54608) and I've been through some of the SDK examples. Are there any examples for PEG running on this device? I'm attempting to evaluate PEG Lite as compared to TouchGFX, Embedded Wizard, and others.
ラベル(4)
タグ(4)
2,238件の閲覧回数
kerryzhou
Hi Matt Schrader,
    Unfortunately, we don't have the PEG lite example for LPC54608 board.
   Please check this PEG information:
I highly suggest you use the emwin instead of the PEG lite, because our OM13092 already have the according sample code for the customer's reference.
Wish it helps you!
If you still have question about it,  please kindly let me know!
Kerry
3 返答(返信)
2,239件の閲覧回数
kerryzhou
Hi Matt Schrader,
Wish it helps you!
Kerry
2,239件の閲覧回数
mattschrader
Thank you Kerry! I did indeed find the emWin examples as I got deeper into the documentation and SDK for this platform. So I am digging into those now.
Also, for those who may be following along, I found this presentation which appears to be from before the release of LPC546xx. It is helpful in that it gives a general overview of emWin:
https://elearning.nxp.com/course/view.php?id=162
2,239件の閲覧回数
kerryzhou
https://www.nxp.com/docs/en/supporting-information/SEGGER-emWin-with-NXP-LPC54600-MCUs.pdf
This document may also useful to you and other customer!
Kerry
