Optimisation of CMSIS constants for cortex M4
961件の閲覧回数
prasannanaik
I am using CMSIS library for FFT computation in LPC54607J256BD208E.
IDE: MCXpresso IDE v 10.3.1_2233
I am trying to optimize my code size to fit a bootloader along with application code.
On analysis of Map size, I found that cmsis fft constants take up a lot spcae.
ConstantsSize
twiddleCoef_204816384
twiddleCoef_rfft_409616384
twiddleCoef_rfft_20488192
twiddleCoef_10248192
armBitRevIndexTable20487616
twiddleCoef_5124096
twiddleCoef_rfft_10244096
armBitRevIndexTable10243600
twiddleCoef_2562048
twiddleCoef_rfft_5122048
Total72656
Is there any way to optimize these constants or is there any code optimized fft library for this microcontroller.
Thanks and best regards,
Prasanna
956件の閲覧回数
frank_m
Senior Contributor III
Optimize for what ? You can either optimize for speed, for size, or a mixture (=compromise) of both.
The usage of the named pre-calculated constants for FFT is a speed optimization of that algorithm.
You can try implementing any other FFT algorithm, if you wish. But be aware of the limitations of "float" versus "double".
