I created an application using the MCAN interrupt demo code as reference using Keil tools.
I can run it with the debugger, but I notice it stops at a memory location in the disassembly window that lists a breakpoint. I run from there and my application works just fine.
If I try to just flash the application and run it without the debugger, it does nothing...thinking it's stuck at that breakpoint.
The .map file says it is part of sys_command.o??? I searched the project for this and came up with nothing.
Anybody have any ideas on how to fix this?
Ken
