Not able to Boot from flash
1,461件の閲覧回数
lpcware
Content originally posted in LPCWare by sharvareedeo on Mon Apr 09 06:37:41 MST 2012
Small code boot from flash Hitex RevA4. But large application not booting from flash on power off-on cycle.
2 返答(返信)
1,450件の閲覧回数
lpcware
Content originally posted in LPCWare by PhilYoung on Tue Apr 10 16:39:06 MST 2012
duplicate deleted.
1,450件の閲覧回数
lpcware
Content originally posted in LPCWare by PhilYoung on Tue Apr 10 16:37:27 MST 2012
second try.
the boot loader does not enable all address bits for the flash, so you need to enable them before executing the ARM startup code, otherwise it may not be able to access all the parts of the image required for initializing data and relocating code.
regards
Phil.
