New update
New update
1,758 次查看
Nadia
Good afternoon, I've been using this programming platform for a while, and they've updated it and I'm a bit lost. I have the MUCXpresso IDE v 11.3.0_522 version, I am using the LPC54616J512 microcontroller, when I go to create a new program with the FREErtos operating system, in the source folder I don't see the FREErtosConfig file to access its configuration. I want to know if it happens to someone else and it is something of the update or is it me, and I would like to know how to do it now with this new update. Thank you very much for your help. Best regards
1,740 次查看
Omar_Anguiano
Hello
When you create a new project from the wizard, you can find the FreeRTOSConfig.h file in this location: Project->freertos->template->ARM_CM4F.
Let me know if this is helpful, if you have more questions do not hesitate to ask me.
Omar
1,741 次查看
Omar_Anguiano
Hello
Omar
