New feature: Collapsible sections
1,307 次查看
lpcware
Content originally posted in LPCWare by lpcadmin on Mon Dec 19 15:52:14 MST 2011
You can use the 'collapse' keyword inside square brackets to make a section collapsible.
Use the [ collapse ] identifier to start the section and the [ /collapse] identifier to finish the section.
Un-collapse the section below to see the text.
[collapse collapsed]
You have un-collapsed the section!
[/collapse]
You can use 'collapse collapsed' to make the section collapsed by default.
1,300 次查看
lpcware
Content originally posted in LPCWare by Pacman on Sat Oct 26 16:22:29 MST 2013
This would indeed be a good feature to get back.
Especially when posting log-output snippets from a console (they're only interesting while investigating problems).
1,300 次查看
lpcware
Content originally posted in LPCWare by lpcadmin on Mon Aug 26 14:20:25 MST 2013
Does collapse still work? Apparently not
[/collapse]
