NVIC accessing in LPCOpen
2,107 次查看
jeanvaljean
Ladies and Gentlemen,
I'd like to enable the SSP0 interrupt in the NVIC block.
Maybe, I'm completely blind, but I do not find a way, how to access the NVIC block in LPCOpen environment.
To be concrete, I'd like to set  NVIC_ISER0 bit 20.
How to do that?
LPC_NVIC->ISER0 |= 1<<20 ; to my best logic, but it doesn't compile, saying: " error: 'LPC_NVIC' undeclared (first use in this function) "
标记 (1)
1 回复
1,990 次查看
jeanvaljean
OK, I have found it using some example from stackoverflow.com:
NVIC->ISER[0] |= 1<<20 ; this compiles without error.
By the way: LPCOpen is a good platform, but the lack of documentation makes it very confusing to use.
What NXP calls documentation, it is worthless for a novice, and is not necessary for an expert. That's an automatically generated something, good for alibi, but useless.
