[NHS 3100] Error on debugging
1,489 次查看
rado__99
Hello, I face the following problem when I am in debugging mode and tap a NFC reader over the board.
Redlink interface error when debugging:255
I am using the dpu_templogger example with debug build downloaded on the board.
Thank you in advance.
1,423 次查看
IvanRuiz
Is it the dp_tlogger example or the one for UCODE? and which IDE are you working with?
Thank you.
Ivan.
