Microcontroller LPC32x0
justinvil1103
Hi All,
Would anyone help me identify the highlighted values below? I am assuming 0 = not supported and 1 = supported, am I correct?
Thank you,
Willer
Pavel_Hernandez
I checked out this MCU individually and confirm that your assumption is correct.
Pavel
frank_m
Senior Contributor III
I would interpret the 0/1 as the number of interfaces in the specific variant, which would amount to the same.
For serial interfaces like UART, SPI, I2C and CAN, these numbers are usually in the range 2..8.
Pavel_Hernandez
Pavel
Pavel_Hernandez
Could you tell me the name of the document or where did you find this? I need to review it.
Pavel
justinvil1103
Pavel_Hernandez
That means the quantity too.
Pavel
