Hi, thank you for your quick answer.
I have alredy tried the first option, getting the engine speed quite well, but the problem is that there is not way to get the speed direction, because I need it too, or I do not know how to get the direcction using the Capture function.
Talking about the converter, I discard that option, because we are trying to avoid the most hardware as is possible, but thank you for the idea.
Returning to first, if you know a way to get the direction of the speed using capture it will be very helpful.
Thanks for all,
Alessandro
