Max allowed function clock to MCAN module(s) in LPC5428
2,246 次查看
carstengroen
Senior Contributor II
What is the maximum allowed clock to the MCAN module in the LPC54628 devices ?
I can't seem to locate the actual number in UM/DS, the samples from SDK shows often 220MHz/11 => 20 MHz, but interested in knowing what the max allowed clock is.
2,162 次查看
Omar_Anguiano
In theory, the MCAN source clock supports higher frequency, it is limited by the mainclk.
MCAN functional clock for LPC546xx is 20 MHz, supports timing configurations for up to 5 Mbps data phase when using proper segment settings and prescalers. This limit is limited by the maximum supported CAN bit rate and protocol timings.
BR,
Omar
2,163 次查看
Omar_Anguiano
BR,
Omar
2,144 次查看
carstengroen
@Omar_Anguiano many thanks for your answer. I see from the SDK samples that 20 MHz is selected in all of them, but I was not able to find a number in either the DS or UM.
%3CLINGO-SUB%20id%3D%22lingo-sub-2200900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC5428%20%E4%B8%AD%20MCAN%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%9C%80%E5%A4%A7%E5%85%81%E8%AE%B8%E5%8A%9F%E8%83%BD%E6%97%B6%E9%92%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELPC54628%20%E8%AE%BE%E5%A4%87%E4%B8%AD%20MCAN%20%E6%A8%A1%E5%9D%97%E5%85%81%E8%AE%B8%E7%9A%84%E6%9C%80%E5%A4%A7%E6%97%B6%E9%92%9F%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BC%BC%E4%B9%8E%E6%89%BE%E4%B8%8D%E5%88%B0%20UM%2FDS%20%E4%B8%AD%E7%9A%84%E5%AE%9E%E9%99%85%E6%95%B0%E5%AD%97%EF%BC%8CSDK%20%E4%B8%AD%E7%9A%84%E6%A0%B7%E6%9C%AC%E6%98%BE%E7%A4%BA%E9%80%9A%E5%B8%B8%E4%B8%BA%20220MHz%2F11%20%3D%26gt%3B%2020MHz%EF%BC%8C%E4%BD%86%E6%88%91%E5%BE%88%E6%83%B3%E7%9F%A5%E9%81%93%E5%85%81%E8%AE%B8%E7%9A%84%E6%9C%80%E5%A4%A7%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E6%98%AF%E5%A4%9A%E5%B0%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204935%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Max%20allowed%20function%20clock%20to%20MCAN%20module(s)%20in%20LPC5428%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204935%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F169053%22%20target%3D%22_blank%22%3E%40Omar_Anguiano%3C%2FA%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%E6%88%91%E4%BB%8E%20SDK%20%E6%A0%B7%E6%9C%AC%E4%B8%AD%E7%9C%8B%E5%88%B0%EF%BC%8C%E5%AE%83%E4%BB%AC%E9%83%BD%E9%80%89%E6%8B%A9%E4%BA%86%2020%20MHz%EF%BC%8C%E4%BD%86%E6%88%91%E5%9C%A8%20DS%20%E6%88%96%20UM%20%E4%B8%AD%E9%83%BD%E6%89%BE%E4%B8%8D%E5%88%B0%E8%BF%99%E4%B8%AA%E6%95%B0%E5%AD%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Max%20allowed%20function%20clock%20to%20MCAN%20module(s)%20in%20LPC5428%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%90%86%E8%AE%BA%E4%B8%8A%EF%BC%8CMCAN%20%E6%BA%90%E6%97%B6%E9%92%9F%E6%94%AF%E6%8C%81%E6%9B%B4%E9%AB%98%E7%9A%84%E9%A2%91%E7%8E%87%EF%BC%8C%E5%AE%83%E5%8F%97%E5%88%B0%20mainclk%20%E7%9A%84%E9%99%90%E5%88%B6%E3%80%82%3CBR%20%2F%3ELPC546xx%20%E7%9A%84%20MCAN%20%E5%8A%9F%E8%83%BD%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E4%B8%BA%2020%20MHz%EF%BC%8C%E5%9C%A8%E4%BD%BF%E7%94%A8%E9%80%82%E5%BD%93%E7%9A%84%E5%88%86%E6%AE%B5%E8%AE%BE%E7%BD%AE%E5%92%8C%E9%A2%84%E5%88%86%E9%A2%91%E5%99%A8%E6%97%B6%EF%BC%8C%E6%94%AF%E6%8C%81%E9%AB%98%E8%BE%BE%205%20Mbps%20%E6%95%B0%E6%8D%AE%E7%9B%B8%E4%BD%8D%E7%9A%84%E6%97%B6%E5%BA%8F%E9%85%8D%E7%BD%AE%E3%80%82%E8%AF%A5%E9%99%90%E5%88%B6%E5%8F%97%20CAN%20%E6%9C%80%E5%A4%A7%E6%94%AF%E6%8C%81%E6%AF%94%E7%89%B9%E7%8E%87%E5%92%8C%E5%8D%8F%E8%AE%AE%E6%97%B6%E5%BA%8F%E7%9A%84%E9%99%90%E5%88%B6%E3%80%82%20%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EOmar%3C%2FP%3E%3C%2FLINGO-BODY%3E
