Mac OS X (M1 Chip) MCUXPresso LinkServer not working.
2,551 次查看
dhjeong
hello. I am using MCUXpresso tool on M1 Mac OS.
But when I start debugging the project I get an error because LinkServer cannot be started.
Attach a screenshot. Is there any workaround for this?
MCUXpresso uses version 11.5.1.
2,530 次查看
CarlosGarabito
Hi @dhjeong it looks a problem with a permission in linux, when you connect your board, what you have log?(dmesg using the terminal) I mean, if you connect the board, did you have all the information about the board that you connect? If not, in linux, you need to check the rules (/etc/dev/rules/) i think, is equal in mac.
But if you have all information, maybe is about permission, open the rules and change the permissions or open the MCUXpresso as a superuser
