MICROSD CARD
MICROSD CARD
2,011 次查看
schakoma
Hello.
I would like to interface a microsd card with the CLEV6630B or LPCXpresso845MAX evaluation boards to read and write data to the microSD card. I am still new to the arm microcontrollers and I would appreciate some demo code to start with.
Thank you.
2,003 次查看
frank_m
Senior Contributor III
I would suggest to start with an appropriate example from the SDK for your boards. SD card or FatFS examples should be appropriate.
I don't know both of your boards myself. But with an external SD card interface, there is likely some code to adapt, or to port. The lowest layer of this SD card /FatFS code is target specific. This is quite some task for a beginner.
The easiest route would be a board that comes with an SD card interface and slot, like my OM13098. The SDK example code for those usually works out of the box.
1,998 次查看
schakoma
Thank you very much. I will try that
