MCUXpresso Config Tools Version 4.1
1,307 次查看
vijo
Generation of the file clock_config.c has a bug when main clock is selected for SCTimer/PWMCLK.
The line:       CLOCK_AttachClk(kMCLK_to_SCT_CLK);                  /*!< Switch SCT_CLK to MAIN_CLK */
Should be:   CLOCK_AttachClk(kMAIN_CLK_to_SCT_CLK);                  /*!< Switch SCT_CLK to MAIN_CLK */
As: kMCLK_to_SCT_CLK is not defined in fsl_clock.h
Viggo
1,186 次查看
soledad
Thank you for your feedback, we will check this internally in order to fix the issue.
Sol
