MCUXpresso | Build Artifact | Executable type changes
Balaji_KG
  Currently, I am working on LPC1788 Open library package. I can't able to generate a hex file because of the static library option. I need to change the build artifact type from static library to executable method. Is there any possible?
Harry_Zhang
Hi @Balaji_KG
Yes, it is possible to change the build artifact type from static library to executable. You can do this by modifying the project settings in MCUXpresso.
Here are the steps:
1. Open your project in MCUXpresso.
2. Go to Project -> Properties.
3. In the Properties window, go to C/C++ Build -> Settings.
4. In the Settings tab, you will see a field called "Build Artifact".
5. Change the "Build Artifact" from "Static Library" to "Executable".
6. Click on "Apply" and then "OK" to save the changes.
7. Now, try to build your project again. It should generate a hex file instead of a static library.
Hope this will help you.
Hang
Harry_Zhang
Hi @Balaji_KG
Here are the steps:
Hang
%3CLINGO-SUB%20id%3D%22lingo-sub-1889991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXpresso%20%7C%20Build%20Artifact%20%7C%20Executable%20type%20changes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20Currently%2C%20I%20am%20working%20on%20LPC1788%20Open%20library%20package.%20I%20can't%20able%20to%20generate%20a%20hex%20file%20because%20of%20the%20static%20library%20option.%20I%20need%20to%20change%20the%20build%20artifact%20type%20from%20static%20library%20to%20executable%20method.%20Is%20there%20any%20possible%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1889991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC17xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20%7C%20Build%20Artifact%20%7C%20Executable%20type%20changes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F215923%22%20target%3D%22_blank%22%3E%40Balaji_KG%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes%2C%20it%20is%20possible%20to%20change%20the%20build%20artifact%20type%20from%20static%20library%20to%20executable.%20You%20can%20do%20this%20by%20modifying%20the%20project%20settings%20in%20MCUXpresso.%3C%2FP%3E%0A%3CP%3EHere%20are%20the%20steps%3A%3C%2FP%3E%0A%3CP%3E1.%20Open%20your%20project%20in%20MCUXpresso.%3CBR%20%2F%3E2.%20Go%20to%20Project%20-%26gt%3B%20Properties.%3CBR%20%2F%3E3.%20In%20the%20Properties%20window%2C%20go%20to%20C%2FC%2B%2B%20Build%20-%26gt%3B%20Settings.%3CBR%20%2F%3E4.%20In%20the%20Settings%20tab%2C%20you%20will%20see%20a%20field%20called%20%22Build%20Artifact%22.%3CBR%20%2F%3E5.%20Change%20the%20%22Build%20Artifact%22%20from%20%22Static%20Library%22%20to%20%22Executable%22.%3CBR%20%2F%3E6.%20Click%20on%20%22Apply%22%20and%20then%20%22OK%22%20to%20save%20the%20changes.%3CBR%20%2F%3E7.%20Now%2C%20try%20to%20build%20your%20project%20again.%20It%20should%20generate%20a%20hex%20file%20instead%20of%20a%20static%20library.%3C%2FP%3E%0A%3CP%3EHope%20this%20will%20help%20you.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHang%3C%2FP%3E%3C%2FLINGO-BODY%3E
