Lpc55s69 PUF fingerprint extraction
3,383 次查看
satsok_n
I am using lpc55s69 in order to get advantage of the PUF example which is given by the SDK. Is there any way to extract the complete available fingerpring of the PUF memory? I would like to use it in a different way than the one which is given in the example.
6 回复数
3,379 次查看
ZhangJennie
Hi satsok_n
I may not understand your question. Could you please specify what is " complete available fingerpring of the PUF memory"? Do you mean you want to extract all KC(key code)?
Jun Zhang
3,365 次查看
satsok_n
In order to be more specific I took this figure from PUF manual. I would like to have independent access to SRAM stable data and the final Digital fingerprint.
3,349 次查看
ZhangJennie
Hi satsok_n
PUF SRAM  s not constant.  Each new Enroll generates new data.
And there is no way to extract PUF SRAM data. If this can be done, the chip is not safe.
Have a nice day,
Jun Zhang
3,346 次查看
satsok_n
Hi Zhang
Thanks for the response. I have 2 more questions. First, If I use the same activation code after the enroll to start the PUF means that I would have same SRAM cells values. Secondly, how do I get the same intrinsic key to use after I restart the device?
3,340 次查看
ZhangJennie
Hi satsok_n
These questions are not related with the original question of fingerprint extraction. In order to seperate different subject, I would suggest you creating a new thread.  We will help you further.
Jun Zhang
3,373 次查看
satsok_n
Hi Zhang
By fingerprint I mean all the stable cells of memory which is used by PUF. I would like to create a stability map in order to use it in a different way.
