Lpc4357 lcd controller drive a 480x854 lcd
2,126件の閲覧回数
rqbh
Does the lpc4357 lcd controller can drive a 480x854 tft LCD?
ラベル(4)
2 返答(返信)
1,854件の閲覧回数
lpcware
bump
1,854件の閲覧回数
brendonslade
Hi Kevin,
The LPC4357 lines per panel is up to 1024; you would need to check exact timing requirements of your LCD details against the User Manual. See Chapter 28: http://www.nxp.com/documents/user_manual/UM10503.pdf?fpsp=1&WT_TYPE=Users Guides&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation&fileExt=.pdf
