Lpc1788 & SDRAM
Lpc1788 & SDRAM
5,843 次查看
TahmidToky
Hello everyone I have one lpc1788 evolution board. There is already an SDRAM connected on the board. I want to learn how can I write data to SDRAM and read when needed. I am a beginner so any doc or link which I can visit to begin with would be appreciated. Thanks in advance.
9 回复数
5,824 次查看
TahmidToky
Thanks for your reply. There is no SDK available for LPC1788 Evolution Board. Can you suggest me any other way that i can use to learn?
5,823 次查看
frank_m
Senior Contributor III
An EMC example in a SDK for the LPC1788 perhaps ?
Or a SDK for a similar board ?
As an embedded SW developer, you cannot always rely on ready-made examples. In the worst case, on the basis of the datasheets.
5,819 次查看
TahmidToky
There is no EMC examples as well. all I could find, is zipped in the attached file. You can have a look. Thanks again for you help.
5,807 次查看
frank_m
You can create a SDK for your MCU online on the NXP website, and download it. With plenty of options to include middleware components like communication protocols, or graphics. Have you tried that ?
Select you MCU on the NXP product page, and go to the Design Resources / Embedded Software page:
I don't really know the LPC1788.
5,805 次查看
frank_m
Trying to check that myself, I couldn't find my way through. Not sure if the LPC17xx is supported by the SDK generation tool (https://mcuxpresso.nxp.com/en/welcome).
Perhaps the NXP staff can chime in.
5,791 次查看
TahmidToky
yes i know. No problem at all. let me see. Hope i can figure it out some how. Thanks for you time & research.
5,799 次查看
Alexis_A
Hello @frank_m,
This MCU is not supported in the SDK, this has a library called LPCOpen where you can find examples for most of the peripherals (link), there's an example code called periph_memtest that use an external DRAM that you could take a look.
Alexis Andalon
5,792 次查看
TahmidToky
great. Thanks a lot. Let me see. Thanks again.
5,830 次查看
frank_m
SDK examples for your eval board ?
Worked for me, with a LPC54xxx board.
