Loading binary file 'LPC111x.bin' .What is it the start address?
2,202 次查看
annechen12
     I tried downloading the file from 'LPC1114.bin'.But I don't its start address.Please give me a answer.Thank you!
2,093 次查看
jeremyzhou
Hi  Anne Chen,
for the opportunity to serve you.
The executable file: BIN doesn't contain address information, you can program it to customize memory area freely.
TIC
2,093 次查看
annechen12
It might be the starting address of FLASH. The last thing I'm going to do is HEX files. Thank you very much!
2,093 次查看
lpcxpresso_supp
Unless you've changed the linker script, the address should be the start of Flash. You can deduce the address from the linker map file.
Thanks and regards,
MCUXpresso Support
