LX2080
LX2080
YY2410
The LX2080 automotive-grade chip fails to start at a low temperature of -35°C, with no serial port output and inability to enter Hard-code mode. Measurements indicate that the power supply, clock, and reset signals are all normal. What could be the possible reason?#LX2080CA72232B
Tags (2)
June_Lu
How do you identify the Power-up sequence is fine?
If you could boot in the room temperature, you don't configure anything.
You could input your question in Chinese.
June_Lu
Please check the signals of the LX2160A Reference Manual, page 138, 4.9.6 Power-On Reset Sequence Timing.
And then check the signals status per the stage of 4.9.5 Power-On Reset Sequence Detailed Description to check which stage is wrong.
YY2410
Power-up sequence is fine, signals status is not convenient for measurement; and there is one more question,Refer to the attached picture,I am using an automotive-grade chip. Do I need to configure anything in the hardware or software?
%3CLINGO-SUB%20id%3D%22lingo-sub-2165779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EThe%20LX2080%20automotive-grade%20chip%20fails%20to%20start%20at%20a%20low%20temperature%20of%20-35%C2%B0C%2C%20with%20no%20serial%20port%20output%20and%20inability%20to%20enter%20Hard-code%20mode.%20Measurements%20indicate%20that%20the%20power%20supply%2C%20clock%2C%20and%20reset%20signals%20are%20all%20normal.%20What%20could%20be%20the%20possible%20reason%3F%23LX2080CA72232B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3EHow%20do%20you%20identify%20the%20%3C%2FSPAN%3E%3CSPAN%3EPower-up%20sequence%20is%20fine%3C%2FSPAN%3E%3CSPAN%3E%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EIf%20you%20could%20boot%20in%20the%20room%20temperature%2C%20you%20don't%20configure%20anything.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EYou%20could%20input%20your%20question%20in%20Chinese.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EPower-up%20sequence%20is%20fine%2C%20signals%20status%20is%20not%20convenient%20for%20measurement%3B%20and%20there%20is%20one%20more%20question%2CRefer%20to%20the%20attached%20picture%2CI%20am%20using%20an%20automotive-grade%20chip.%20Do%20I%20need%20to%20configure%20anything%20in%20the%20hardware%20or%20software%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3EPlease%20check%20the%20signals%20of%20the%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DLX2160ARM%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3ELX2160A%20Reference%20Manual%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%2C%20page%20138%2C%20%3C%2FSPAN%3E%3CSPAN%3E4.9.6%20Power-On%20Reset%20Sequence%20Timing%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3EAnd%20then%20check%20the%20signals%20status%20per%20the%20stage%20of%20%3C%2FSPAN%3E%3CSPAN%3E4.9.5%20Power-On%20Reset%20Sequence%20Detailed%20Description%3C%2FSPAN%3E%3CSPAN%3E%20to%20check%20which%20stage%20is%20wrong.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E
