LPCXpresso 11U68 board: when put into ISP mode it appears as a USB mass storage
3,066 次查看
sharadanand
I have purchased a new LPCXpresso 11U68 board and I am able to put into ISP mode. But after putting it into ISP mode it is getting detected as a mass storage device with title "CRP DISABLED".
I tried to update its driver wot other driver but was not able to flash my application into it.
标签 (2)
标记 (3)
2,883 次查看
Hello @sharadanand
If you want to use the debugger for debugging, do not put the chip into ISP mode. Connect to the debug port (J5) without pressing the ISP button.
Thank you.
Alice
8 回复数
2,788 次查看
sharadanand
Hi @Alice_Yang ,
I was able to connect the debugger successfully. Thank you very much for the support,
Warm regards,
Sharadanand
3,017 次查看
Hello @sharadanand
Please provide detailed steps on how you put your board into ISP mode.
Also, please check the LPCXpresso11U68 schematic and the description below about entering ISP mode, and confirm.
Thank you.
Alice
2,997 次查看
sharadanand
Hi @al ,
Thank you very much for the reply I am refering following schematic file:
https://www.nxp.com/downloads/en/schematics/LPC11U68_Xpresso_v2_Schematic_RevC_1.pdf
I am setting JP2 pin 1 and 2 short and JP1 as open, I am pressing reset button and holding the ISP button while board is resetting. As per my understing of the schematic, this should automatically go into USB mode. I have not made any changes in the board and the board is brand new,
Warm regards,
Sharadanand Karanjkar
2,960 次查看
Hi @sharadanand
"I am setting JP2 pin 1 and 2 short and JP1 as open, I am pressing reset button and holding the ISP button while board is resetting. As per my understing of the schematic, this should automatically go into USB mode."
Yes, you are correct. In this mode, the bootloader connects the device to the PC host as an MSC USB device (CRP DISABLED). The device’s flash memory appears as a drive in the host operating system, allowing you to simply drag and drop your .bin file into the MSC device.
Thank you.
Alice
2,941 次查看
sharadanand
Hi @Alice_Yang ,
Thank you very much for your response, I want to flash and debug my firmware via the debugger provided on the board.
I am not able to do that, LPCXPresso IDE generates *.axf file not bin file. How to move further with this?
Warm regards,
Sharadanand
2,939 次查看
sharadanand
I found out the way to generate firmware.bin file but still unable to make the debugger working. Kindly let me know how to enable the debugger.
2,884 次查看
Hello @sharadanand
Thank you.
Alice
2,846 次查看
sharadanand
Hi @Alice_Yang ,
Thanks a lot for clarifying :). I was confused about the same, I have tried that before but I am not able to detect the debugger to my host machine.
This is what I see on MCUXpresso, I tried to find out the device details they are as follows:
vid:0x1fc9
pid:0x000c
Manufacturer: NXP
Serialnumber: ABCD
I tried using both windows and linux hosts, buit I was not successful.
I followed the steps mentioned in the link bellow:
https://community.nxp.com/t5/MCUXpresso-IDE/MCUExpresso-with-LPC-Link2/td-p/633989
But that also did not worked for me.
Warm regards,
Sharadanand
%3CLINGO-SUB%20id%3D%22lingo-sub-2270955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPCXpresso%2011U68%20%E6%9D%BF%EF%BC%9A%E8%BF%9B%E5%85%A5%20ISP%20%E6%A8%A1%E5%BC%8F%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E6%98%BE%E7%A4%BA%E4%B8%BA%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%B4%AD%E4%B9%B0%E4%BA%86%E6%96%B0%E7%9A%84%20LPCXpresso%2011U68%20%E6%9D%BF%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%BF%9B%E5%85%A5%E4%BA%92%E8%81%94%E7%BD%91%E6%9C%8D%E5%8A%A1%E6%8F%90%E4%BE%9B%E5%95%86%E6%A8%A1%E5%BC%8F%E3%80%82%E4%BD%86%E6%98%AF%E5%9C%A8%E5%B0%86%E5%85%B6%E7%BD%AE%E4%BA%8E%20ISP%20%E6%A8%A1%E5%BC%8F%E5%90%8E%EF%BC%8C%E5%AE%83%E8%A2%AB%E6%A3%80%E6%B5%8B%E4%B8%BA%E6%A0%87%E9%A2%98%E4%B8%BA%20%22%20CRP%20DISABLED%20%22%20%E7%9A%84%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E7%94%A8%E5%85%B6%E4%BB%96%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9B%B4%E6%96%B0%E5%AE%83%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E5%B0%86%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%97%AA%E5%AD%98%E5%88%B0%E5%AE%83%E9%87%8C%E9%9D%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2270955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC11xx%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELPCOpen%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2271060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPCXpresso%2011U68%20board%3A%20when%20put%20into%20ISP%20mode%20it%20appears%20as%20a%20USB%20mass%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2271060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258454%22%20target%3D%22_blank%22%3E%40sharadanand%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E5%B0%86%E6%9D%BF%E7%BD%AE%E4%BA%8E%20ISP%20%E6%A8%A1%E5%BC%8F%E7%9A%84%E8%AF%A6%E7%BB%86%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E8%AF%B7%E6%9F%A5%E7%9C%8B%20LPCXpresso11U68%20%E5%8E%9F%E7%90%86%E5%9B%BE%E5%92%8C%E4%B8%8B%E9%9D%A2%E5%85%B3%E4%BA%8E%E8%BF%9B%E5%85%A5%20ISP%20%E6%A8%A1%E5%BC%8F%E7%9A%84%E8%AF%B4%E6%98%8E%E5%B9%B6%E7%A1%AE%E8%AE%A4%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1767585499635.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1767585499635.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1767585499635.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1767585499635.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1767585499635.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1767585499635.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1767585499635.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1767585499635.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F371680iCEECA2773188F5DB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1767585499635.png%22%20alt%3D%22Alice_Yang_0-1767585499635.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2288924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPCXpresso%2011U68%20board%3A%20when%20put%20into%20ISP%20mode%20it%20appears%20as%20a%20USB%20mass%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2288924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E7%94%9F%E6%88%90%20firmware.bin%20%E6%96%87%E4%BB%B6%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E4%BD%86%E4%BB%8D%E6%97%A0%E6%B3%95%E4%BD%BF%E8%B0%83%E8%AF%95%E5%99%A8%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2288880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPCXpresso%2011U68%20board%3A%20when%20put%20into%20ISP%20mode%20it%20appears%20as%20a%20USB%20mass%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2288880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E6%83%B3%E9%80%9A%E8%BF%87%E6%9D%BF%E4%B8%8A%E6%8F%90%E4%BE%9B%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E5%88%B7%E6%96%B0%E5%92%8C%E8%B0%83%E8%AF%95%E6%88%91%E7%9A%84%E5%9B%BA%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8CLPCXPresso%20IDE%20%E7%94%9F%E6%88%90%E7%9A%84%E6%98%AF%20*.axf%20%E6%96%87%E4%BB%B6%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20bin%20%E6%96%87%E4%BB%B6%E3%80%82%E5%A6%82%E4%BD%95%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%8E%A8%E8%BF%9B%E8%BF%99%E9%A1%B9%E5%B7%A5%E4%BD%9C%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E6%B2%99%E6%8B%89%E8%BE%BE%E5%8D%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPCXpresso%2011U68%20board%3A%20when%20put%20into%20ISP%20mode%20it%20appears%20as%20a%20USB%20mass%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258454%22%20target%3D%22_blank%22%3E%40sharadanand%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%22%20%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%86%20JP2%20%E5%BC%95%E8%84%9A%201%20%E5%92%8C%202%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E7%9F%AD%E8%B7%AF%E5%B9%B6%E5%B0%86%20JP1%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%89%93%E5%BC%80%E7%8A%B6%E6%80%81%EF%BC%8C%E5%9C%A8%E6%9D%BF%E9%87%8D%E7%BD%AE%E6%97%B6%E6%88%91%E6%8C%89%E4%B8%8B%E9%87%8D%E7%BD%AE%E6%8C%89%E9%92%AE%E5%B9%B6%E6%8C%89%E4%BD%8F%20ISP%20%E6%8C%89%E9%92%AE%E3%80%82%E6%A0%B9%E6%8D%AE%E6%88%91%E5%AF%B9%E5%8E%9F%E7%90%86%E5%9B%BE%E7%9A%84%E4%BA%86%E8%A7%A3%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E4%BC%9A%E8%87%AA%E5%8A%A8%E8%BF%9B%E5%85%A5USB%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%E3%80%82%22%3C%2FP%3E%0A%3CP%3E-%26gt%3B%26gt%3B%20%3C%2FP%3E%0A%3CDIV%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AF%B9%E3%80%82%E5%9C%A8%E6%AD%A4%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%8C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%B0%86%E8%AE%BE%E5%A4%87%E4%BD%9C%E4%B8%BA%20MSC%20USB%20%E8%AE%BE%E5%A4%87%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%BB%E6%9C%BA%EF%BC%88%3CSPAN%3E%E7%A6%81%E7%94%A8%20CRP%3C%2FSPAN%3E%EF%BC%89%E3%80%82%E8%AF%A5%E8%AE%BE%E5%A4%87%E7%9A%84%E9%97%AA%E5%AD%98%E5%9C%A8%E4%B8%BB%E6%9C%BA%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%AD%E6%98%BE%E7%A4%BA%E4%B8%BA%E9%A9%B1%E5%8A%A8%E5%99%A8%EF%BC%8C%E6%82%A8%E5%8F%AA%E9%9C%80%E5%B0%86%20%3CCODE%20translate%3D%22no%22%3E.bin%3C%2FCODE%3E%20%E6%96%87%E4%BB%B6%E6%8B%96%E6%94%BE%E5%88%B0%20MSC%20%E8%AE%BE%E5%A4%87%E4%B8%AD%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPCXpresso%2011U68%20board%3A%20when%20put%20into%20ISP%20mode%20it%20appears%20as%20a%20USB%20mass%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E8%A7%A3%E9%87%8A%EF%BC%9A%EF%BC%89%E3%80%82%E6%88%91%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E5%9B%B0%E6%83%91%EF%BC%8C%E6%88%91%E4%BB%A5%E5%89%8D%E4%B9%9F%E8%AF%95%E8%BF%87%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E5%B0%86%E8%B0%83%E8%AF%95%E5%99%A8%E6%A3%80%E6%B5%8B%E5%88%B0%E4%B8%BB%E6%9C%BA%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sharadanand_0-1767782979763.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sharadanand_0-1767782979763.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sharadanand_0-1767782979763.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sharadanand_0-1767782979763.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F371986iDD0881931AD089F9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sharadanand_0-1767782979763.png%22%20alt%3D%22sharadanand_0-1767782979763.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E5%9C%A8%20mcuxPresso%20%E4%B8%8A%E7%9C%8B%E5%88%B0%E7%9A%84%EF%BC%8C%E6%88%91%E6%83%B3%E6%89%BE%E5%87%BA%E8%AE%BE%E5%A4%87%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E5%A6%82%E4%B8%8B%EF%BC%9Avid%3A%200x1fc9%20pid%3A%200x000c%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9ANXP%3CBR%20%2F%3E%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AABCD%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Windows%20%E5%92%8C%20Linux%20%E4%B8%BB%E6%9C%BA%EF%BC%8C%E4%BD%86%E9%83%BD%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%20%3CBR%20%2F%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%B8%8B%E9%9D%A2%E9%93%BE%E6%8E%A5%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2FMCUExpresso-with-LPC-Link2%2Ftd-p%2F633989%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2FMCUExpresso-with-LPC-Link2%2Ftd-p%2F633989%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E8%BF%99%E5%AF%B9%E6%88%91%E4%B9%9F%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E4%BB%A5%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E6%B2%99%E6%8B%89%E8%BE%BE%E5%8D%97%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPCXpresso%2011U68%20board%3A%20when%20put%20into%20ISP%20mode%20it%20appears%20as%20a%20USB%20mass%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258454%22%20target%3D%22_blank%22%3E%40sharadanand%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%E5%A6%82%E6%9E%9C%E8%A6%81%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E8%AF%B7%E4%B8%8D%E8%A6%81%E5%B0%86%E8%8A%AF%E7%89%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%20ISP%20%E6%A8%A1%E5%BC%8F%E3%80%82%E5%9C%A8%E4%B8%8D%E6%8C%89%20ISP%20%E6%8C%89%E9%92%AE%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%9E%E6%8E%A5%E8%B0%83%E8%AF%95%E7%AB%AF%E5%8F%A3%20(J5)%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPCXpresso%2011U68%20board%3A%20when%20put%20into%20ISP%20mode%20it%20appears%20as%20a%20USB%20mass%20storage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%88%90%E5%8A%9F%E8%BF%9E%E6%8E%A5%E4%BA%86%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%81%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E6%B2%99%E6%8B%89%E8%BE%BE%E5%8D%97%3C%2FP%3E%3C%2FLINGO-BODY%3E
