LPCOpen SD card 1769
1,632 次查看
lpcware
Content originally posted in LPCWare by artuan on Tue Feb 24 00:37:44 MST 2015
Hello to everyone,
I'm using LPCOpen(2.10) for my application and I need to write to the SD card(spi).
When I look around there is no example how to implement this with lpc 1769. In the sdmmc_17xx_40xx.h file the code is unavailable for lpc 1769(#if defined(CHIP_LPC177X_8X) || defined(CHIP_LPC40XX)).
Can you please help me?
Thank you
Artuan
1,487 次查看
lpcware
Content originally posted in LPCWare by mc on Mon Mar 30 11:17:38 MST 2015
Hi miha,
You may want to look below application note
http://www.lpcware.com/content/nxpfile/an11070-accessing-sdcmmc-card-using-spissp-lpc1700
1,487 次查看
lpcware
Content originally posted in LPCWare by miha on Mon Mar 30 01:23:34 MST 2015
Nobody to help on this?
Thank you
