LPC8n04 dev kit drivers not working?
1,506 次查看
ed_pataky
I just received the LPC8N04 eval board .. i have IAR 8.4.  I installed the drivers as noted on the website and manuals but IAR could not recognize it .. i noticed the device keeps constantly connecting and disconnecting from the windows machine .. i cannot even uninstall the driver because it only stays connected for a short time .. i saw the note that if IAR cannot connect to it, then try the mbed driver, so i installed that as well .. i updated the board firmware per the "getting started" guide ... it just goes crazy when connected to windows .. it is windows 10 pro
I cannot download a sample to the board, cannot debug
1,296 次查看
ed_pataky
i figured it out thank you
