LPC804 Github action sdk
1,224 次查看
MHMart
I'm trying to run a github action to do some basic linting checking (for starters).
However, I need to install the SDK.
Below is the current setup I have but I'm not so sure how to install the SDK, since I cannot find a direct downloader, only a configuration page to assemble the right downloader on the NXP site.
Any thoughts?
on: [push, pull_request]
jobs:
  cpp-linter:
    runs-on: ubuntu-latest
    steps:
      - uses: actions/checkout@v4
      - uses: cpp-linter/cpp-linter-action@main
        continue-on-error: true
        env:
          GITHUB_TOKEN: ${{ secrets.GITHUB_TOKEN }}
        with:
          style: file
          files-changed-only: false
          thread-comments: false
      - name: Fail fast?!
        if: steps.linter.outputs.checks-failed != 0
        run: |
          echo "some linter checks failed. ${{ steps.linter.outputs.checks-failed }}"
        # for actual deployment
        # run: exit 1
1,197 次查看
Hello @MHMart
You can find the SDK on github:
https://github.com/nxp-mcuxpresso/mcux-sdk
Alice
