LPC802 dev/evk board - where can I get the example application source code ?
paulw2
I'd like to work through the source code of the example application that the LPC802 dev kit has pre-installed.
This is the app that reads the temperature sensor, potentiometer, etc and lights LED's in a face pattern.
This source code would seem to be an excellent starting point as it's interfacing with most peripherals on the board.
I have the SDK installed but it doesn't seem to contain the source code for this example app.
Internet searches refer to example bundles, but I can't find one for LPC802 dev board.
Where can I get the LPC802 dev/evk board example application source code ?
Thanks in advance.
Harry_Zhang
Hi @paulw2
The LPC802 dev/evk board example application source code is in the attachment.
Please kindly check it.
Hope this will help you.
Hang
Harry_Zhang
Hi @paulw2
Hang
paulw2
Hi Hang,
Apologies for very late reply.
Thank you very much for providing this.
%3CLINGO-SUB%20id%3D%22lingo-sub-1862817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC802%20dev%2Fevk%20board%20-%20where%20can%20I%20get%20the%20example%20application%20source%20code%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'd%20like%20to%20work%20through%20the%20source%20code%20of%20the%20example%20application%20that%20the%20LPC802%20dev%20kit%20has%20pre-installed.%3C%2FP%3E%3CP%3EThis%20is%20the%20app%20that%20reads%20the%20temperature%20sensor%2C%20potentiometer%2C%20etc%20and%20lights%20LED's%20in%20a%20face%20pattern.%3C%2FP%3E%3CP%3EThis%20source%20code%20would%20seem%20to%20be%20an%20excellent%20starting%20point%20as%20it's%20interfacing%20with%20most%20peripherals%20on%20the%20board.%3C%2FP%3E%3CP%3EI%20have%20the%20SDK%20installed%20but%20it%20doesn't%20seem%20to%20contain%20the%20source%20code%20for%20this%20example%20app.%3C%2FP%3E%3CP%3EInternet%20searches%20refer%20to%20example%20bundles%2C%20but%20I%20can't%20find%20one%20for%20LPC802%20dev%20board.%3C%2FP%3E%3CP%3EWhere%20can%20I%20get%20the%20LPC802%20dev%2Fevk%20board%20example%20application%20source%20code%20%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1862817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC800%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1950026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC802%20dev%2Fevk%20board%20-%20where%20can%20I%20get%20the%20example%20application%20source%20code%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1950026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Hang%2C%3CBR%20%2F%3E%3CBR%20%2F%3EApologies%20for%20very%20late%20reply.%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20very%20much%20for%20providing%20this.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1879439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC802%20dev%2Fevk%20board%20-%20where%20can%20I%20get%20the%20example%20application%20source%20code%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1879439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F187779%22%20target%3D%22_blank%22%3E%40paulw2%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20LPC802%20dev%2Fevk%20board%20example%20application%20source%20code%20is%20in%26nbsp%3Bthe%20attachment.%3C%2FP%3E%0A%3CP%3EPlease%20kindly%20check%20it.%3C%2FP%3E%0A%3CP%3EHope%20this%20will%20help%20you.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHang%3C%2FP%3E%3C%2FLINGO-BODY%3E
