LPC55x16: Using Flash as Data storage
1,728 次查看
SSiddiqui
Hi looking for LPC55x16, example for storing configuration data in the flash.
1,698 次查看
SSiddiqui
Thanks @Pavel_Hernandez
I have tried the shared example, however i am not sure while writing to the flash data memory, are we disabling the other interrupts disable_irq();
I am not able to find interrupt disabling in the SDK example code.
1,641 次查看
Pavel_Hernandez
Hello, the example of flashiap does not have any IRQ but this are the function.
Pavel
1,714 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, I recommend download the SDK and there you will be find some examples about FATFS with USB or others like Flash IAP.
Select Board | MCUXpresso SDK Builder
Select the examples and finish to start the import.
Pavel
