LPC55x with 2x USB CDC's, one to each core
2,475 次查看
dav1
I'd like to run two different applications on the LPC55S6x, both needing its own USB CDC connection.
It needs to be the same physical USB PHY (HS/480mbit)
What would be the easiest and most efficient way to achieve this?
In AN12335 it briefly mentions Inter-CPU Mailbox and that shared resource can be claimed by both cores. But I can't find how to define so that one USB endpoint is tied to core0 vs another endpoint is tied to core1
标签 (3)
4 回复数
2,453 次查看
I think you can consider it as two separate projects, each with its own space and endpoint to config USB CDC .
2,450 次查看
dav1
can you please provide an example how you would configure two cores, both getting data from the same usb-phy (usb1). i.e. two cdc's one to each m33
2,443 次查看
Hello Dav,
Sorry I haven't find this example, there is demo Composite CDC_VCOM_CDC_VCOM under SDK.
Alice
2,441 次查看
dav1
that demo seem to run on a single core
my question is how to assign different usb endpoints to different arm core's
