LPC55s16 secure boot device recovery
xavier_es_developer
Dear nxp community,
i was testing LPC55s16-EVK for the secure boot features as follows and everything worked well as expected but in the i ended up with non-responsive baord.
I created a workspace for secure provisioning tool and
- generated a plain signed image from my built elf file, and flashed it. Application was running.
- Then in cmpa flash region i setup debug authentication for, with debug credentials and it worked as well.
- Then i created another test workspace and generated new ROTK and Image keys to sign the same elf file, in order to test ROM bootloader will reject this firmware as it has different hash stored in cmpa region.
- In the new work space i did not change anything in cmpa region, it used default settings, that in my opinion are with debug port enabled, but i ended up with non responsive device,
- In both case the life cycle was selected as development not sealed.
- nxpdebugmbox responds with timeout error.
-  when i try to bring the device in ISP mode by holding ISP pin low and pressing and releasing the reset pin then i cannot get any response of ping from BLHost tool.
-  I tried to use SPI and USB interfaces as well but the result is the same.
- i am attaching the cmpa.json file and the logfile of my 2nd workspace that is test workspace for the reference.
Is there a way, how can recover this device? Any help will be much appreciated. Thanks
xavier_es_developer
Hello @xavier_es_developer
Based on your test results, it seems that the board cannot be recovered.
For secure boot, I recommend using the MCUXpresso Secure Provisioning Tool (SEC). It is simple and easy to use, and can help reduce the risk of configuration errors.
Download it from:
Please refer to Section 6.5, "LPC55(S)0x/1x/2x/6x or NHS52Sxx or MCXW23x device workflow," in the MCUXpresso Secure Provisioning Tool User Guide.
Thank you.
Alice
xavier_es_developer
Hello @Alice_Yang
Thank you for your response. To me it looks like the debug interface is disabled permanently because of the 2nd cmpa region write that probably wrote all 0 in  CC_SOCU_PIN and CC_SOCU_DFLT, I have tried using debug mailbox tool that is nxpdebugmbox, but i get the same error as response timeout as in this case.
Thanks for your question.
Please use the DM-AP method in MCUXpresso Secure Provisioning Tool (SEC) to erase the device.
You can download and install SEC from MCUXpresso Secure Provisioning Tool | NXP Semiconductors.
Please check whether the device can be erased successfully using this method.
If the issue persists, please feel free to contact me.
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2425555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55s16%20secure%20boot%20device%20recovery%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2425555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20nxp%20community%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ei%20was%20testing%20LPC55s16-EVK%20for%20the%20secure%20boot%20features%20as%20follows%20and%20everything%20worked%20well%20as%20expected%20but%20in%20the%20i%20ended%20up%20with%20non-responsive%20baord.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20created%20a%20workspace%20for%20secure%20provisioning%20tool%20and%3C%2FP%3E%3CP%3E-%20generated%20a%20plain%20signed%20image%20from%20my%20built%20elf%20file%2C%20and%20flashed%20it.%20Application%20was%20running.%3C%2FP%3E%3CP%3E-%20Then%20in%20cmpa%20flash%20region%20i%20setup%20debug%20authentication%20for%2C%20with%20debug%20credentials%20and%20it%20worked%20as%20well.%3C%2FP%3E%3CP%3E-%20Then%20i%20created%20another%20test%20workspace%20and%20generated%20new%20ROTK%20and%20Image%20keys%20to%20sign%20the%20same%20elf%20file%2C%20in%20order%20to%20test%20ROM%20bootloader%20will%20reject%20this%20firmware%20as%20it%20has%20different%20hash%20stored%20in%20cmpa%20region.%26nbsp%3B%3C%2FP%3E%3CP%3E-%20In%20the%20new%20work%20space%20i%20did%20not%20change%20anything%20in%20cmpa%20region%2C%20it%20used%20default%20settings%2C%20that%20in%20my%20opinion%20are%20with%20debug%20port%20enabled%2C%20but%20i%20ended%20up%20with%20non%20responsive%20device%2C%26nbsp%3B%3C%2FP%3E%3CP%3E-%20In%20both%20case%20the%20life%20cycle%20was%20selected%20as%20development%20not%20sealed.%3C%2FP%3E%3CP%3E-%20nxpdebugmbox%20responds%20with%20timeout%20error.%26nbsp%3B%3C%2FP%3E%3CP%3E-%26nbsp%3B%20when%20i%20try%20to%20bring%20the%20device%20in%20ISP%20mode%20by%20holding%20ISP%20pin%20low%20and%20pressing%20and%20releasing%20the%20reset%20pin%20then%20i%20cannot%20get%20any%20response%20of%20ping%20from%20BLHost%20tool.%26nbsp%3B%3C%2FP%3E%3CP%3E-%26nbsp%3B%20I%20tried%20to%20use%20SPI%20and%20USB%20interfaces%20as%20well%20but%20the%20result%20is%20the%20same.%26nbsp%3B%3C%2FP%3E%3CP%3E-%20i%20am%20attaching%20the%20cmpa.json%20file%20and%20the%20logfile%20of%20my%202nd%20workspace%20that%20is%20test%20workspace%20for%20the%20reference.%3C%2FP%3E%3CP%3EIs%20there%20a%20way%2C%20how%20can%20recover%20this%20device%3F%20Any%20help%20will%20be%20much%20appreciated.%20Thanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2425849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55s16%20secure%20boot%20device%20recovery%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2425849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F267889%22%20target%3D%22_blank%22%3E%40xavier_es_developer%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3EThanks%20for%20your%20question.%3C%2FP%3E%0A%3CP%3EPlease%20use%20the%20DM-AP%20method%20in%20MCUXpresso%20Secure%20Provisioning%20Tool%20(SEC)%20to%20erase%20the%20device.%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1793790929936.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1793790929936.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1793790929936.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1793790929936.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F398834i7F3D77F0DD543D2F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1793790929936.png%22%20alt%3D%22Alice_Yang_0-1793790929936.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYou%20can%20download%20and%20install%20SEC%20from%20%3CA%20class%3D%22fui-Link%20fai-bebop%20___1myvvpj%20f2hkw1w%20f3rmtva%20f1ewtqcl%20f16muhyy%20f1k6fduh%20f1w7gpdv%20f1mo0ibp%20fjoy568%20ff5ikls%20f1s184ao%20f1mk8lai%20fnbmjn9%20f1o700av%20f13mvf36%20f33ey8m%20f9n3di6%20f1ids18y%20f1tx3yz7%20f1bwia3u%20f1eh06m1%20f1xeumsx%20fhgqx19%20f1olyrje%20f1p93eir%20f1nev41a%20f132whgj%20f1v74mp6%20f1tsf1ni%20fnq52rx%20f16zlvvm%22%20tabindex%3D%220%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-secure-provisioning-tool%3AMCUXPRESSO-SECURE-PROVISIONING%3Ftid%3DvanSEC%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%20data-tabster%3D%22%7B%22%20restorer%3D%22%22%20target%3D%22_blank%22%3EMCUXpresso%20Secure%20Provisioning%20Tool%20%7C%20NXP%20Semiconductors%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EPlease%20check%20whether%20the%20device%20can%20be%20erased%20successfully%20using%20this%20method.%3C%2FP%3E%0A%3CP%3EIf%20the%20issue%20persists%2C%20please%20feel%20free%20to%20contact%20me.%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2425877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55s16%20secure%20boot%20device%20recovery%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2425877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20your%20response.%20To%20me%20it%20looks%20like%20the%20debug%20interface%20is%20disabled%20permanently%20because%20of%20the%202nd%20cmpa%20region%20write%20that%20probably%20wrote%20all%200%20in%26nbsp%3B%20CC_SOCU_PIN%20and%20CC_SOCU_DFLT%2C%20I%20have%20tried%20using%20debug%20mailbox%20tool%20that%20is%26nbsp%3Bnxpdebugmbox%2C%20but%20i%20get%20the%20same%20error%20as%20response%20timeout%20as%20in%20this%20case.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2426055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55s16%20secure%20boot%20device%20recovery%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2426055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F267889%22%20target%3D%22_blank%22%3E%40xavier_es_developer%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3EBased%20on%20your%20test%20results%2C%20it%20seems%20that%20the%20board%20cannot%20be%20recovered.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3EFor%20secure%20boot%2C%20I%20recommend%20using%20the%20MCUXpresso%20Secure%20Provisioning%20Tool%20(SEC).%20It%20is%20simple%20and%20easy%20to%20use%2C%20and%20can%20help%20reduce%20the%20risk%20of%20configuration%20errors.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3EDownload%20it%20from%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3E%3CA%20class%3D%22fui-Link%20fai-bebop%20___1myvvpj%20f2hkw1w%20f3rmtva%20f1ewtqcl%20f16muhyy%20f1k6fduh%20f1w7gpdv%20f1mo0ibp%20fjoy568%20ff5ikls%20f1s184ao%20f1mk8lai%20fnbmjn9%20f1o700av%20f13mvf36%20f33ey8m%20f9n3di6%20f1ids18y%20f1tx3yz7%20f1bwia3u%20f1eh06m1%20f1xeumsx%20fhgqx19%20f1olyrje%20f1p93eir%20f1nev41a%20f132whgj%20f1v74mp6%20f1tsf1ni%20fnq52rx%20f16zlvvm%22%20tabindex%3D%220%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-secure-provisioning-tool%3AMCUXPRESSO-SECURE-PROVISIONING%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%20data-tabster%3D%22%7B%22%20restorer%3D%22%22%20target%3D%22_blank%22%3EMCUXpresso%20Secure%20Provisioning%20Tool%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3EPlease%20refer%20to%20Section%206.5%2C%20%22LPC55(S)0x%2F1x%2F2x%2F6x%20or%20NHS52Sxx%20or%20MCXW23x%20device%20workflow%2C%22%20in%20the%20MCUXpresso%20Secure%20Provisioning%20Tool%20User%20Guide.%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3EThank%20you.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3EAlice%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
