LPC55S6X User Manual DMA Ping Pong
andrew_lonsdale
Does Table 408 of the LPC55S6X User Manual (UM11126 Rev 1.0 24 Feb 2019) have an error?
It covers configuration of DMA for Ping Pong operation in section 23.5.4.
Should the third entry in column Descriptor A, read "Buffer A memory end address" ?
Charles
jeremyzhou
Hi Charles Lonsdale,
for the opportunity to serve you.
Q1) Should the third entry in column Descriptor A, read "Buffer A memory end address" ?
-- Yes, you're right, I'll report the typo to Document team for checking.
TIC
