LPC55S69JEV59: Is internal DCDC useable?
KostasH
Can someone confirm if LPC55S69 in the 59-VFBA package (LPC55S69JEV59) supports the use of its internal DC-DC that is firmware controllable?
Since pin FB is unbonded in the package — is FB is internally tied to VDD_PMU on the die or package substrate, to allow internal DC-DC converterLPC55S69JEV59 to be is fully operational in VFBGA59, using the external filtering components as described in the part's datasheet?
Thanks all in advance!
Hello @KostasH
Thanks for your question.
  1. Yes, LPC55S69JEV59 supports an internal DC‑DC converter.
  2. Yes, the FB node is internally connected to VDD_PMU.
Alice
KostasH
Thank you for confirming Alice
Hello @KostasH
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2359883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S69JEV59%3A%20Is%20internal%20DCDC%20useable%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2359883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20someone%20confirm%20if%20LPC55S69%20in%20the%2059-VFBA%20package%20(LPC55S69JEV59)%20supports%20the%20use%20of%20its%20internal%20DC-DC%20that%20is%20firmware%20controllable%3F%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3ESince%20pin%20FB%20is%20unbonded%20in%20the%20package%26nbsp%3B%3C%2FSTRONG%3E%E2%80%94%20is%20FB%20is%20internally%20tied%20to%20VDD_PMU%20on%20the%20die%20or%20package%20substrate%2C%20to%20allow%26nbsp%3B%3CSTRONG%3Einternal%20DC-DC%20converterLPC55S69JEV59%20to%20be%20is%20fully%20operational%20in%20VFBGA59%3C%2FSTRONG%3E%2C%20using%20the%20external%20filtering%20components%20as%20described%20in%20the%20part's%20datasheet%3F%3C%2FP%3E%3CP%3EThanks%20all%20in%20advance!%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S69JEV59%3A%20Is%20internal%20DCDC%20useable%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260693%22%20target%3D%22_blank%22%3E%40KostasH%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%0A%3CP%3EThanks%20for%20your%20question.%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3EYes%2C%20LPC55S69JEV59%20supports%20an%20internal%20DC%E2%80%91DC%20converter.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EYes%2C%20the%20FB%20node%20is%20internally%20connected%20to%20VDD_PMU.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2371533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S69JEV59%3A%20Is%20internal%20DCDC%20useable%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2371533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20confirming%20Alice%3C%2FP%3E%3C%2FLINGO-BODY%3E
