LPC55S69 : temperature settling time
1,295 次查看
EugeneHiihtaja
Senior Contributor I
Hello !
in DS is specified settling time of temperature sensor after power on in table 12.2.2
but what about settling time after Power-Down mode and actual conversion time ?
How fast after resuming from  Power-down mode I can get good measurement of temperature ?
Eugene
1,248 次查看
Alexis_A
Hi Eugene,
As you may notice, this measure is not characterized but I think it would be a good aproximation to use the same setting time as the one from power-up. Also, this is an analog sensor connected to the channel 26 in the ADC so check the chapter 39.7.6 in the reference manual for more information about it.
Alexis Andalon
