LPC55S69 Secondary Bootloader Reinvoke
1,593件の閲覧回数
henninjw1
I am running through the example in app note AN12327 using an LPC55S69-EVK.  I am able to flash the bootloader and then run the flash_program.bat tool the load the dsbl_app program.  The issue I am running into is trying to re-enter the bootloader from the app using the sbl_api as described on page 12 of the app note.  When I uncomment the sbl_api->reinvoke(); command in the app I get a hard fault failure. I am using the MCUXpresso example code in the app note.
Thanks.
1,525件の閲覧回数
RaRo
Hi  @henninjw1
I hope you're doing well.
Could you tell us the revision and date code of your chip?
Here is an example of where to find those in your chip.
Raul
858件の閲覧回数
brianhgw
I have the same issue by using LPC55S69-EVK.
Would you please share us how to solve it?
