LPC55S69: I2C registers all correct, but SDA/SCL never physically move
336件の閲覧回数
ryan714
LPC55S69: I2C4 (Flexcomm 4) master never physically drives SDA/SCL despite fully correct register configuration - I2C_MasterStart() hangs permanently in I2C_MasterCheckStartResponse()
Summary
On an LPC55S69-EVK, I2C_MasterTransferBlocking() hangs permanently (no timeout, confirmed via SDK source inspection) on the very first transaction attempted after I2C_MasterInit(). Every peripheral configuration register I can inspect - CFG, PSELID, CLKDIV, MSTTIME, IOCON pin function, and the Secure AHB Controller's peripheral access rules - reads back as correctly configured. However, a direct multimeter measurement of the physical SDA/SCL lines, taken while execution is frozen mid-hang inside the driver, shows both lines sitting at a clean, unchanged idle ~3.3V - meaning the I2C master's internal state machine never actually asserts a START condition onto the physical bus at all, despite software believing it did.
Environment
  • Board: LPCXpresso55S69-EVK, LPC55S69JBD100
  • IDE: MCUXpresso IDE v25.6 [Build 136]
  • I2C peripheral: I2C4 (Flexcomm 4), pins P1_20 (SCL) / P1_21 (SDA)
  • This is Core 1 (non-secure, no TrustZone - confirmed this chip's Core 1 has no TrustZone capability at all per AN12278) of a dual-core project. Core 1 is confirmed booting and executing correctly (proven via a working LED heartbeat and independent shared-memory diagnostics) - this report is specifically about the I2C peripheral, not the multicore boot sequence.
  • Sensor: Adafruit BME688 (STEMMA QT, onboard pull-ups), address 0x77, connected via genuine Adafruit STEMMA QT-to-header cable
The core evidence
1. The hang location, confirmed via SDK source inspection
Reading fsl_i2c.c directly: I2C_MasterTransferBlocking() calls I2C_MasterStart() then I2C_MasterCheckStartResponse(). The latter calls I2C_PendingStatusWait(), which polls kI2C_MasterPendingFlag in a loop with no timeout at all when I2C_RETRY_TIMES is 0/undefined (confirmed this is the active code path in this project - the #else branch with an unconditional while(...) and no exit condition). Execution never returns from this call, confirmed by a shared-memory diagnostic checkpoint written immediately before the call, which is reached, and one written immediately after, which is never reached, even after 5+ seconds of continuous execution.
2. Register state at the moment of the hang (read live via debugger, not assumed)
Register Address Value Meaning
I2C4->STAT0x5008A0000x00000000Idle. MSTPENDING=0, MSTSTATE=0, no error flags
I2C4->CFG0x5008A8000x00000001MSTEN=1 - master mode enabled
FLEXCOMM4->PSELID0x5008AFF80x1020F3PERSEL=3 (I2C personality genuinely selected), I2CPRESENT=1
I2C4->CLKDIV0x5008A81474Non-zero, plausible divider
I2C4->MSTTIME0x5008A824102Non-zero, plausible SCL timing
IOCON->PIO[1][20] (P1_20/SCL)0x500010D00x323FUNC=3 (Flexcomm alt-function), pull-up + open-drain enabled
IOCON->PIO[1][21] (P1_21/SDA)0x500010D40x323Same - correctly configured
AHB_SECURE_CTRL FLEXCOMM4_RULE0x500AC12400b00 = "Non-secure and Non-privilege user access allowed" (most permissive)
AHB_SECURE_CTRL IOCON_RULE0x500AC1300Same - fully open, non-secure access unrestricted
Every one of these is exactly what a correctly-configured, unrestricted, ready-to-transact I2C master should show.
3. Physical measurement (the decisive evidence)
With execution frozen mid-hang (confirmed via the checkpoint diagnostic, STAT still reading 0x00000000 at this exact moment):
  • SDA to GND: 3.299 V
  • SCL to GND: 3.299 V
Both lines are indistinguishable from a fully idle, untouched bus. The physical pins never moved at all, despite I2C_MasterStart() having already executed (it's called before I2C_MasterCheckStartResponse(), where we're actually hung) and despite every register above showing a fully configured, unrestricted master.
What has been ruled out
  • Sensor/cable/breadboard fault - wiring continuity confirmed with a multimeter across multiple different physical wire positions (5+ attempts); genuine Adafruit STEMMA QT cable; sensor address pad confirmed consistent with the documented 0x77 default; identical result reproduces regardless of which physical header pins are used
  • Clock source/frequency - explicitly re-asserted CLOCK_SetupFROClocking(12000000U) immediately before attaching Flexcomm4's clock; no change
  • Baud rate/timing miscalculation - reduced from 100 kHz to 10 kHz (10x); identical hang; CLKDIV/MSTTIME both confirmed non-zero and plausible
  • Pin mux - confirmed via IOCON_FUNC3 write and independently re-verified via direct register read at the exact moment of the hang
  • I2C personality selection - confirmed via PSELID
  • Sensor driver library - bypassed bme68x.c entirely; a raw, minimal zero-length address probe built directly with the SDK's i2c_master_transfer_t struct produces the identical hang
  • MasterEnable off/on toggle workaround (from a similar-sounding NXP community report for a different part) - no effect
  • TrustZone/Secure AHB Controller peripheral access restriction - confirmed both IOCON and FLEXCOMM4 are set to the most permissive non-secure access rule
Question
Given every software-visible register indicates a correctly configured, unrestricted I2C master, but the physical SDA/SCL pins provably never move (confirmed by direct voltage measurement while frozen inside the driver call), what remaining hardware-level step is required to get the I2C4 peripheral to actually drive its pads on this part?
Specifically:
  • Is there a known LPC55S69 errata affecting Flexcomm I2C pad drive that isn't captured by the CFG/PSELID/IOCON registers I've checked?
  • Is there an additional power-domain, pad-supply, or analog block that needs to be explicitly enabled for Flexcomm I2C physical output (something outside the digital peripheral configuration registers) that I may have missed?
  • Given this is Core 1 (bare-metal, no RTOS, no TrustZone) in a dual-core multicore project where Core 0 runs FreeRTOS - is there any known interaction between Core 0's own boot-time configuration and Core 1's ability to drive Flexcomm4's physical pads, beyond what a register-level snapshot would reveal (e.g., something in SYSCON clock-gating for the pad IO cell itself, distinct from CLOCK_AttachClk's peripheral function clock)?
Happy to provide the full project, a logic analyzer capture, or any additional register dump on request.
291件の閲覧回数
ryan714
Resolved - root cause was an incorrect IOCON alternate function number
Posting the resolution in case anyone finds this thread later with a similar symptom.
The actual root cause
IOCON_PIO_FUNC3 does not route P1_20/P1_21 to FC4 I2C on this board. The correct alternate function is FUNC5, with open-drain disabled at the IOCON level (the I2C peripheral's own CFG register handles open-drain behavior internally - enabling it again at the IOCON pad level was also wrong).
I had derived FUNC3 by reading the pin_signal ordering in a comment (PIO1_20/FC7_RTS_SCL_SSEL1/CT_INP14/FC4_TXD_SCL_MISO_WS/PLU_OUT2) and assuming 0-indexed position = function number. That assumption was incorrect for this pin.
Why this produced such a confusing symptom
With the wrong alternate function selected, every I2C-internal register still read back as perfectly configured:
  • I2C4->CFG.MSTEN = 1 (master enabled)
  • FLEXCOMM4->PSELID showed I2C personality genuinely selected
  • CLKDIV/MSTTIME were valid, non-zero
  • Even IOCON->PIO[1][20/21] showed a function selected (just the wrong one) - nothing about this register's value alone signals "wrong function," only "some function is selected"
None of that depends on the physical pin actually being connected to the I2C block - PSELID and CFG are entirely internal to the Flexcomm/I2C logic, independent of which alternate function the IOCON mux happens to route to. So the peripheral was internally fully configured and "ready," while the physical SDA/SCL pins were never actually wired to it at all. This produced a permanent hang in I2C_MasterTransferBlocking() (confirmed via SDK source: no timeout when I2C_RETRY_TIMES is 0) with zero error flags ever raised, and - the piece that finally proved it - a multimeter measurement showing the physical bus completely unchanged at idle voltage even while frozen mid-transaction, since the pins genuinely were never driven.
How it was found
Created a fresh, separate single-core test project for the same board and used the MCUXpresso wizard's own auto-generated BOARD_InitACCELPins() function (this board has an onboard accelerometer wired to the same I2C4 bus, so the wizard ships a working, verified pin mux for these exact pins). Reading that function's actual generated source showed IOCON_PIO_FUNC5 with open-drain disabled - directly contradicting my own hand-derived FUNC3/open-drain-enabled configuration. Switching to match NXP's own verified values immediately resolved the permanent hang; a subsequent, unrelated address-NAK (0x77 not acknowledging) turned out to just be a loose header-pin contact, resolved by moving the connection to different header pins.
Lesson for anyone else hitting an identical symptom
If a Flexcomm peripheral's own registers (PSELID, CFG, CLKDIV, etc.) all read back as correctly configured but the physical bus never shows any activity (confirmed via multimeter/scope) - don't trust a hand-derived alternate function number from reading the pin_signal comment ordering. Cross-check against any wizard-auto-generated pin mux function this SDK ships for the same physical pins on the same board (peripherals the eval board itself uses - accelerometers, codecs, etc. - are a good source of a genuinely verified reference), or regenerate the pin mux via the MCUXpresso Pins tool directly rather than hand-writing IOCON_PinMuxSet() calls from an assumed function index.
Thanks again to everyone who engaged with the earlier posts in this thread and the original multicore boot thread - the register-level verification work across both investigations is what eventually made this contradiction (everything configured correctly, yet nothing on the bus) visible enough to chase down.
292件の閲覧回数
ryan714
How it was found
%3CLINGO-SUB%20id%3D%22lingo-sub-2406827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S69%3A%20I2C%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E5%85%A8%E3%81%A6%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8C%E3%80%81SDA%2FSCL%E3%81%AF%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E5%8B%95%E3%81%8B%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-1354062612%22%20id%3D%22toc-hId-1354087782%22%3ELPC55S69%3A%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81I2C4%20(Flexcomm%204)%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%81%8C%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%20SDA%2FSCL%20%E3%82%92%E9%A7%86%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%20-%20I2C_MasterStart()%20%E3%81%8C%20I2C_MasterCheckStartResponse()%20%E3%81%A7%E6%B0%B8%E4%B9%85%E3%81%AB%E3%83%8F%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-2044624086%22%20id%3D%22toc-hId-2044649256%22%3E%E6%A6%82%E8%A6%81%3C%2FH2%3E%3CP%3ELPC55S69-EVK%E3%81%A7%E3%81%AF%E3%80%81I2C_MasterTransferBlocking()%E3%81%AFI2C_MasterInit()%E3%81%AE%E7%9B%B4%E5%BE%8C%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AA%E3%81%97%E3%81%AB%E6%B0%B8%E4%B9%85%E3%81%AB%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99(%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AA%E3%81%97%E3%80%81SDK%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E6%A4%9C%E6%9F%BB%E3%81%A7%E7%A2%BA%E8%AA%8D%E6%B8%88%E3%81%BF)%E3%80%82%E6%A4%9C%E6%9F%BB%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E2%80%94CFG%E3%80%81PSELID%E3%80%81CLKDIV%E3%80%81MSTTIME%E3%80%81IOCON%E3%83%94%E3%83%B3%E6%A9%9F%E8%83%BD%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6Secure%20AHB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%AB%E2%80%94%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%AA%AD%E3%81%BF%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%8C%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%86%85%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%9F%E7%8A%B6%E6%85%8B%E3%81%A7%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AASDA%2FSCL%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E7%9B%B4%E6%8E%A5%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%B8%A1%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E5%A4%89%E5%8C%96%E3%81%AE%E3%81%AA%E3%81%84%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB~3.3V%E3%81%A7%E4%BD%8D%E7%BD%AE%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81I2C%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AE%E5%86%85%E9%83%A8%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AF%E7%89%A9%E7%90%86%E3%83%90%E3%82%B9%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6START%E6%9D%A1%E4%BB%B6%E3%82%92%E4%B8%BB%E5%BC%B5%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%81%9D%E3%81%86%E8%AA%8D%E8%AD%98%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-237169623%22%20id%3D%22toc-hId-237194793%22%3E%E7%92%B0%E5%A2%83%3C%2FH2%3E%3CUL%3E%3CLI%3E%E5%9F%BA%E6%9D%BF%EF%BC%9ALPCXpresso55S69-EVK%E3%80%81LPC55S69JBD100%3C%2FLI%3E%3CLI%3EIDE%3A%20MCUXpresso%20IDE%20v25.6%20%5B%E3%83%93%E3%83%AB%E3%83%89136%5D%3C%2FLI%3E%3CLI%3EI2C%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%3AI2C4(Flexcomm%204)%E3%80%81%E3%83%94%E3%83%B3P1_20(SCL)%2FP1_21%20SDA(SDA))%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B3%E3%82%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%82%B3%E3%82%A21%E3%81%A7%E3%81%99%EF%BC%88%E9%9D%9E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%80%81TrustZone%E3%81%AA%E3%81%97%20-%20AN12278%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E3%82%B3%E3%82%A21%E3%81%AB%E3%81%AFTrustZone%E6%A9%9F%E8%83%BD%E3%81%8C%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82Core%201%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E8%B5%B7%E5%8B%95%E3%83%BB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BLED%E5%BF%83%E6%8B%8D%E3%81%A8%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%E8%A8%BA%E6%96%AD%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A8%BC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%E3%81%93%E3%81%AE%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%81%AE%E8%B5%B7%E5%8B%95%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E7%89%B9%E3%81%ABI2C%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3AAdafruit%20BME688(STEMMA%20QT%E3%80%81%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97)%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x77%E3%80%81%E6%AD%A3%E8%A6%8F%E3%81%AEAdafruit%20STEMMA%20QT%E3%81%8B%E3%82%89%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%B8%E3%81%AE%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E6%8E%A5%E7%B6%9A%3C%2FLI%3E%3C%2FUL%3E%3CH2%20id%3D%22toc-hId--1570284840%22%20id%3D%22toc-hId--1570259670%22%3E%E4%B8%AD%E6%A0%B8%E3%81%A8%E3%81%AA%E3%82%8B%E8%A8%BC%E6%8B%A0%3C%2FH2%3E%3CH3%20id%3D%22toc-hId--879723366%22%20id%3D%22toc-hId--879698196%22%3E1.SDK%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E6%A4%9C%E6%9F%BB%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%9F%E3%83%8F%E3%83%B3%E3%82%B0%E5%A0%B4%E6%89%80%3C%2FH3%3E%3CP%3Efsl_i2c.c%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81I2C_MasterTransferBlocking()%20%E3%81%8C%20I2C_MasterStart()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%20I2C_MasterCheckStartResponse()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BE%8C%E8%80%85%E3%81%AF%20I2C_PendingStatusWait()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%80%81I2C_RETRY_TIMES%20%E3%81%8C%200%2Fundefined%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AA%E3%81%97%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A7%20kI2C_MasterPendingFlag%20%E3%82%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%20(%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E3%81%93%E3%82%8C%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%20%E3%83%91%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E7%84%A1%E6%9D%A1%E4%BB%B6%E3%81%AE%20while(...)%20%E3%81%A8%E7%B5%82%E4%BA%86%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%81%AA%E3%81%84%20%23else%20%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81)%E3%80%82%E3%81%93%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8B%E3%82%89%E5%AE%9F%E8%A1%8C%E3%81%8C%E6%88%BB%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AE%E7%9B%B4%E5%89%8D%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%E8%A8%BA%E6%96%AD%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AB%E3%81%AF%E5%88%B0%E9%81%94%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AE%E7%9B%B4%E5%BE%8C%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AB%E3%81%AF5%E7%A7%92%E4%BB%A5%E4%B8%8A%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%82%E5%88%B0%E9%81%94%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1607789467%22%20id%3D%22toc-hId-1607814637%22%3E2.%20%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E6%99%82%E7%82%B9%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%99%E3%82%8B%EF%BC%88%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%A7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81%E4%BB%AE%E5%AE%9A%E5%80%A4%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%EF%BC%89%3C%2FH3%3E%3CP%3E%E7%99%BB%E9%8C%B2%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E5%80%A4%E3%81%AE%E6%84%8F%E5%91%B3%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3EI2C4-%26gt%3BSTAT%3C%2FTD%3E%3CTD%3E0x5008A000%3C%2FTD%3E%3CTD%3E0x00000000%3C%2FTD%3E%3CTD%3E%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E7%8A%B6%E6%85%8B%E3%80%82MSTPENDING%3D0%E3%80%81MSTSTATE%3D0%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AA%E3%81%97%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EI2C4-%26gt%3BCFG%3C%2FTD%3E%3CTD%3E0x5008A800%3C%2FTD%3E%3CTD%3E0x00000001%3C%2FTD%3E%3CTD%3EMSTEN%3D1%20-%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E6%9C%89%E5%8A%B9%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EFLEXCOMM4-%26gt%3BPSELID%3C%2FTD%3E%3CTD%3E0x5008AFF8%3C%2FTD%3E%3CTD%3E0x1020F3%3C%2FTD%3E%3CTD%3EPERSEL%3D3%EF%BC%88I2C%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%AA%E3%83%86%E3%82%A3%E3%81%8C%E7%9C%9F%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%EF%BC%89%E3%80%81I2CPRESENT%3D1%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EI2C4-%26gt%3BCLKDIV%3C%2FTD%3E%3CTD%3E0x5008A814%3C%2FTD%3E%3CTD%3E74%3C%2FTD%3E%3CTD%3E%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%AA%E3%81%84%E3%80%81%E5%A6%A5%E5%BD%93%E3%81%AA%E9%99%A4%E6%95%B0%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EI2C4-%26gt%3BMSTTIME%3C%2FTD%3E%3CTD%3E0x5008A824%3C%2FTD%3E%3CTD%3E102%3C%2FTD%3E%3CTD%3E%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%80%81%E5%A6%A5%E5%BD%93%E3%81%AASCL%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EIOCON-%26gt%3BPIO%5B1%5D%5B20%5D%20(P1_20%2FSCL)%3C%2FTD%3E%3CTD%3E0x500010D0%3C%2FTD%3E%3CTD%3E0x323%3C%2FTD%3E%3CTD%3EFUNC%3D3%20(Flexcomm%E4%BB%A3%E6%9B%BF%E6%A9%9F%E8%83%BD)%E3%80%81%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%EF%BC%8B%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%83%89%E3%83%AC%E3%82%A4%E3%83%B3%E6%9C%89%E5%8A%B9%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EIOCON-%26gt%3BPIO%5B1%5D%5B21%5D%20(P1_21%2FSDA)%3C%2FTD%3E%3CTD%3E0x500010D4%3C%2FTD%3E%3CTD%3E0x323%3C%2FTD%3E%3CTD%3E%E5%90%8C%E3%81%98%20-%20%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EAHB_SECURE_CTRL%20FLEXCOMM4_RULE%3C%2FTD%3E%3CTD%3E0x500AC124%3C%2FTD%3E%3CTD%3E0%3C%2FTD%3E%3CTD%3E0b00%20%3D%20%E3%80%8C%E9%9D%9E%E5%AE%89%E5%85%A8%E3%81%8B%E3%81%A4%E9%9D%9E%E7%89%B9%E6%A8%A9%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E8%A8%B1%E5%8F%AF%E3%80%8D(%E6%9C%80%E3%82%82%E5%AF%9B%E5%AE%B9)%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EAHB_SECURE_CTRL%20IOCON_RULE%3C%2FTD%3E%3CTD%3E0x500AC130%3C%2FTD%3E%3CTD%3E0%3C%2FTD%3E%3CTD%3E%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%20-%20%E5%AE%8C%E5%85%A8%E3%81%AB%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%81%A7%E3%80%81%E9%9D%9E%E5%AE%89%E5%85%A8%E3%81%AA%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E5%88%B6%E9%99%90%E3%81%AA%E3%81%8F%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E5%88%B6%E9%99%90%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%A3%E3%81%9FI2C%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%99%E3%81%B9%E3%81%8D%E5%86%85%E5%AE%B9%E3%81%9D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--199664996%22%20id%3D%22toc-hId--199639826%22%3E3%EF%BC%8E%E7%89%A9%E7%90%86%E7%9A%84%E6%B8%AC%E5%AE%9A%EF%BC%88%E6%B1%BA%E5%AE%9A%E7%9A%84%E3%81%AA%E8%A8%BC%E6%8B%A0%EF%BC%89%3C%2FH3%3E%3CP%3E%E5%AE%9F%E8%A1%8C%E3%81%8C%E9%80%94%E4%B8%AD%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%9F%E7%8A%B6%E6%85%8B%EF%BC%88%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E8%A8%BA%E6%96%AD%E3%81%A7%E7%A2%BA%E8%AA%8D%E6%B8%88%E3%81%BF%E3%80%81STAT%E3%81%AF%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%82%820x00000000%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3ESDA-GND%E9%96%93%E9%9B%BB%E5%9C%A7%EF%BC%9A3.299V%3C%2FLI%3E%3CLI%3ESCL-GND%E9%96%93%E9%9B%BB%E5%9C%A7%EF%BC%9A3.299V%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E8%B7%AF%E7%B7%9A%E3%82%82%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%A6%E4%BD%95%E3%82%82%E6%89%8B%E3%82%92%E5%8A%A0%E3%81%88%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%83%90%E3%82%B9%E3%81%A8%E8%A6%8B%E5%88%86%E3%81%91%E3%81%8C%E3%81%A4%E3%81%8B%E3%81%AA%E3%81%84%E3%80%82I2C_MasterStart()%20%E3%81%AF%E6%97%A2%E3%81%AB%E5%AE%9F%E8%A1%8C%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%20(%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%83%8F%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20I2C_MasterCheckStartResponse()%20%E3%81%AE%E5%89%8D%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99)%E3%80%81%E3%81%BE%E3%81%9F%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E5%88%B6%E9%99%90%E3%81%AE%E3%81%AA%E3%81%84%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AA%E3%83%94%E3%83%B3%E3%81%AF%E5%85%A8%E3%81%8F%E5%8B%95%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId--210168100%22%20id%3D%22toc-hId--210142930%22%3E%E9%99%A4%E5%A4%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%3C%2FH2%3E%3CUL%3E%3CLI%3E%E3%82%BB%E3%83%B3%E3%82%B5%2F%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%2F%E3%83%96%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%95%85%E9%9A%9C%20-%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%A7%E8%A4%87%E6%95%B0%E3%81%AE%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AA%E9%85%8D%E7%B7%9A%E4%BD%8D%E7%BD%AE%E3%81%A7%E9%80%A3%E7%B6%9A%E6%80%A7%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B(5%2B%E5%9B%9E%E3%81%AE%E8%A9%A6%E3%81%BF)%3B%E6%9C%AC%E7%89%A9%E3%81%AEAdafruit%20STEMMA%20QT%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%3B%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%91%E3%83%83%E3%83%89%E3%81%AF%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F0x77%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AA%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%94%E3%83%B3%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%2F%E5%91%A8%E6%B3%A2%E6%95%B0%20-%20Flexcomm4%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E7%9B%B4%E5%89%8D%E3%81%ABCLOCK_SetupFROClocking(12000000U)%E3%82%92%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E5%86%8D%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%2F%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E8%A8%88%E7%AE%97%E3%83%9F%E3%82%B9%20-%20100%20kHz%20%E3%81%8B%E3%82%89%2010%20kHz%20(10%20%E5%80%8D)%20%E3%81%AB%E6%B8%9B%E5%B0%91%3B%20%E5%90%8C%E3%81%98%E3%83%8F%E3%83%B3%E3%82%B0%3B%20CLKDIV%2FMSTTIME%20%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%A8%E3%82%82%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%A7%E5%A6%A5%E5%BD%93%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%83%94%E3%83%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%20-%20IOCON_FUNC3%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%80%81%E3%83%8F%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E3%81%BE%E3%81%95%E3%81%AB%E3%81%9D%E3%81%AE%E7%9E%AC%E9%96%93%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E5%86%8D%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLI%3E%3CLI%3EI2C%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%AA%E3%83%86%E3%82%A3%E9%81%B8%E6%8A%9E%20-%20PSELID%E3%81%A7%E7%A2%BA%E8%AA%8D%E6%B8%88%E3%81%BF%3C%2FLI%3E%3CLI%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20-%20%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9FBME68x.c%E5%AE%8C%E5%85%A8%E3%81%AB%3BSDK%E3%81%AE%20i2c_master_transfer_t%20struct%20%E3%81%A7%E7%9B%B4%E6%8E%A5%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%9F%E7%94%9F%E3%81%AE%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E3%82%BC%E3%83%AD%E9%95%B7%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3EMasterEnable%20%E3%82%AA%E3%83%B3%2F%E3%82%AA%E3%83%B3%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E5%9B%9E%E9%81%BF%E7%AD%96(%E4%BC%BC%E3%81%9F%E3%82%88%E3%81%86%E3%81%AA%E9%9F%B3%E3%81%AENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E5%88%A5%E3%81%AE%E9%83%A8%E5%88%86)-%20%E5%8A%B9%E6%9E%9C%E3%81%AA%E3%81%97%3C%2FLI%3E%3CLI%3ETrustZone%2FSecure%20AHB%20Controller%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E5%88%B6%E9%99%90%20-%20IOCON%E3%81%A8FLEXCOMM4%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E6%9C%80%E3%82%82%E8%A8%B1%E5%AE%B9%E7%9A%84%E3%81%AA%E9%9D%9E%E5%AE%89%E5%85%A8%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLI%3E%3C%2FUL%3E%3CH2%20id%3D%22toc-hId--2017622563%22%20id%3D%22toc-hId--2017597393%22%3E%E8%B3%AA%E5%95%8F%3C%2FH2%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E8%A6%8B%E3%81%88%E3%82%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%88%B6%E9%99%90%E3%81%AE%E3%81%AA%E3%81%84I2C%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%81%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AASDA%2FSCL%E3%83%94%E3%83%B3%E3%81%AF%E6%B1%BA%E3%81%97%E3%81%A6%E5%8B%95%E3%81%8B%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E8%A8%BC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B(%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%B3%E3%83%BC%E3%83%AB%E5%86%85%E3%81%A7%E5%87%8D%E7%B5%90%E3%81%95%E3%82%8C%E3%81%9F%E7%9B%B4%E9%9B%BB%E5%9C%A7%E6%B8%AC%E5%AE%9A%E3%81%A7%E7%A2%BA%E8%AA%8D)%E5%A0%B4%E5%90%88%E3%80%81I2C4%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%8C%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%81%A7%E3%83%91%E3%83%83%E3%83%89%E3%82%92%E9%A7%86%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%AE%8B%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%A7%81%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9FCFG%2FPSELID%2FIOCON%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%80%81Flexcomm%20I2C%E3%83%91%E3%83%83%E3%83%89%E9%A7%86%E5%8B%95%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E6%97%A2%E7%9F%A5%E3%81%AELPC55S69%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3CLI%3EFlexcomm%20I2C%E3%81%AE%E7%89%A9%E7%90%86%E5%87%BA%E5%8A%9B(%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E8%A8%AD%E5%AE%9A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%A4%96%E3%81%AE%E4%BD%95%E3%81%8B)%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%91%E3%83%AF%E3%83%BC%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%80%81%E3%83%91%E3%83%83%E3%83%89%E3%82%B5%E3%83%97%E3%83%A9%E3%82%A4%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E3%81%82%E3%81%A3%E3%81%A6%E3%80%81%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%82%8C%E3%81%AFCore%201(%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%80%81RTOS%E3%81%AA%E3%81%97%E3%80%81TrustZone%E3%81%AA%E3%81%97)%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81Core%200%E3%81%8CFreeRTOS%E3%82%92%E5%8B%95%E3%81%8B%E3%81%99%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B3%E3%82%A2%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%B8%8F%E3%81%BE%E3%81%88%E3%80%81Core%200%E8%87%AA%E8%BA%AB%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E6%99%82%E6%A7%8B%E6%88%90%E3%81%A8Core%201%E3%81%8CFlexcomm4%E3%81%AE%E7%89%A9%E7%90%86%E3%83%91%E3%83%83%E3%83%89%E3%82%92%E9%A7%86%E5%8B%95%E3%81%99%E3%82%8B%E8%83%BD%E5%8A%9B%E3%81%A8%E3%81%AE%E9%96%93%E3%81%AB%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%82%B9%E3%83%8A%E3%83%83%E3%83%97%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88(%E4%BE%8B%3A%E3%83%91%E3%83%83%E3%83%89IO%E3%82%BB%E3%83%AB%E8%87%AA%E4%BD%93%E3%81%AESYSCON%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AA%E3%81%A9)%E4%BB%A5%E5%A4%96%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%9B%B8%E4%BA%92%E4%BD%9C%E7%94%A8%E3%81%8C%E6%97%A2%E7%9F%A5%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20CLOCK_AttachClk%E3%81%AE%E5%91%A8%E8%BE%BA%E6%A9%9F%E8%83%BD%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%94%E8%A6%81%E6%9C%9B%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%85%A8%E4%BD%93%E3%80%81%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%81%AB%E3%82%88%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E5%8F%96%E5%BE%97%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%80%E3%83%B3%E3%83%97%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2406827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S69%3A%20I2C%20registers%20all%20correct%2C%20but%20SDA%2FSCL%20never%20physically%20move%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--442866463%22%20id%3D%22toc-hId-469915440%22%3E%E8%A7%A3%E6%B1%BA%E6%B8%88%E3%81%BF%20-%20%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%81%AFIOCON%E4%BB%A3%E6%9B%BF%E6%A9%9F%E8%83%BD%E7%95%AA%E5%8F%B7%E3%81%AE%E8%AA%A4%E3%82%8A%E3%81%A7%E3%81%97%E3%81%9F%3C%2FH2%3E%3CP%3E%E5%BE%8C%E3%81%A7%E5%90%8C%E3%81%98%E7%97%87%E7%8A%B6%E3%81%AEThread%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E6%96%B9%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-247695011%22%20id%3D%22toc-hId-465313435%22%3E%E5%AE%9F%E9%9A%9B%E3%81%AE%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%3C%2FH3%3E%3CP%3E%3CSTRONG%3EIOCON_PIO_FUNC3%20%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%20P1_20%2FP1_21%20%E3%82%92%20FC4%20I2C%20%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%E6%AD%A3%E3%81%97%E3%81%84%E4%BB%A3%E6%9B%BF%E6%A9%9F%E8%83%BD%E3%81%AF%20%3CSTRONG%3EFUNC5%3C%2FSTRONG%3E%E3%81%A7%E3%80%81IOCON%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%83%89%E3%83%AC%E3%82%A4%E3%83%B3%E3%81%AF%20%3CSTRONG%3E%E7%84%A1%E5%8A%B9%3C%2FSTRONG%3E%20%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(I2C%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AECFG%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E5%86%85%E9%83%A8%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%83%89%E3%83%AC%E3%82%A4%E3%83%B3%E5%8B%95%E4%BD%9C%E3%82%92%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81IOCON%E3%83%91%E3%83%83%E3%83%89%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%9F%E3%81%AE%E3%82%82%E8%AA%A4%E3%82%8A%E3%81%A7%E3%81%97%E3%81%9F)%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AEpin_signal%E9%A0%86%E5%BA%8F(PIO1_20%2FFC7_RTS_SCL_SSEL1%2FCT_INP14%2FFC4_TXD_SCL_MISO_WS%2FPLU_OUT2)%E3%82%92%E8%AA%AD%E3%81%BF%E3%80%810%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E4%BD%8D%E7%BD%AE%3D%E9%96%A2%E6%95%B0%E7%95%AA%E5%8F%B7%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%A6FUNC3%E3%82%92%E5%B0%8E%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E6%83%B3%E5%AE%9A%E3%81%AF%E3%81%93%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1559759452%22%20id%3D%22toc-hId--1342141028%22%3E%E3%81%AA%E3%81%9C%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%B8%8D%E5%8F%AF%E8%A7%A3%E3%81%AA%E7%97%87%E7%8A%B6%E3%81%8C%E7%94%9F%E3%81%98%E3%81%9F%E3%81%AE%E3%81%8B%3C%2FH3%3E%3CP%3E%E8%AA%A4%E3%81%A3%E3%81%9F%E4%BB%A3%E6%9B%BF%E6%A9%9F%E8%83%BD%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81I2C%E5%86%85%E9%83%A8%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E5%AE%8C%E5%85%A8%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EI2C4-%26gt%3BCFG.MSTEN%20%3D%201%20(%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E6%9C%89%E5%8A%B9)%3C%2FLI%3E%3CLI%3EFLEXCOMM4-%26gt%3BPSELID%E3%81%AF%E3%80%81%E7%9C%9F%E3%81%AB%E9%81%B8%E3%81%B0%E3%82%8C%E3%81%9FI2C%E7%89%B9%E6%80%A7%E3%82%92%E7%A4%BA%E3%81%97%E3%81%9F%3C%2FLI%3E%3CLI%3ECLKDIV%2FMSTTIME%20%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%A7%E3%80%81%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3EIOCON-%26gt%3BPIO%5B1%5D%5B20%2F21%5D%E3%81%A7%E3%82%82%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%3CEM%3E%E9%96%A2%E6%95%B0%3C%2FEM%3E%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%EF%BC%88%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E9%96%A2%E6%95%B0%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%EF%BC%89%E3%80%81%E3%81%93%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%80%A4%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AF%E3%80%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E9%96%A2%E6%95%B0%E3%80%8D%E3%82%92%E7%A4%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%80%8C%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%97%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AA%E3%83%94%E3%83%B3%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%ABI2C%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82PSELID%E3%81%A8CFG%E3%81%AFFlexcomm%2FI2C%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%81%AE%E5%86%85%E9%83%A8%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81IOCON%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E4%BB%A3%E6%9B%BF%E6%A9%9F%E8%83%BD%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AF%E5%86%85%E9%83%A8%E7%9A%84%E3%81%AB%E5%AE%8C%E5%85%A8%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%80%8C%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%8D%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AASDA%2FSCL%E3%83%94%E3%83%B3%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E9%85%8D%E7%B7%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81I2C_MasterTransferBlocking()%E3%81%A7%E6%B0%B8%E4%B9%85%E7%9A%84%E3%81%AA%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(SDK%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E7%A2%BA%E8%AA%8D%3AI2C_RETRY_TIMES%E3%81%8C0%E3%81%AA%E3%82%89%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AA%E3%81%97)%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AF%E4%B8%80%E5%88%87%E7%99%BA%E7%94%9F%E3%81%9B%E3%81%9A%E3%80%81%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E8%A8%BC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%AF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%80%81%E5%8F%96%E5%BC%95%E4%B8%AD%E3%81%AB%E5%87%8D%E7%B5%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E7%89%A9%E7%90%86%E3%83%90%E3%82%B9%E3%81%8C%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%81%A7%E5%85%A8%E3%81%8F%E5%A4%89%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%94%E3%83%B3%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E4%B8%80%E5%BA%A6%E3%82%82%E9%A7%86%E5%8B%95%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-927753381%22%20id%3D%22toc-hId-1145371805%22%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E7%99%BA%E8%A6%8B%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%3C%2FH3%3E%3CP%3E%E5%90%8C%E3%81%98%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AB%E6%96%B0%E3%81%97%E3%81%8F%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B3%E3%82%A2%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81MCUXpresso%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E7%8B%AC%E8%87%AA%E3%81%AE%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90BOARD_InitACCELPins()%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E5%90%8C%E3%81%98I2C4%E3%83%90%E3%82%B9%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%97%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E5%87%BA%E8%8D%B7%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%E3%81%9D%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E7%94%9F%E6%88%90%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%BF%E3%82%8B%E3%81%A8%E3%80%81IOCON_PIO_FUNC5%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%83%89%E3%83%AC%E3%82%A4%E3%83%B3%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E6%89%8B%E5%8B%95%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9FFUNC3%2F%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%83%89%E3%83%AC%E3%82%A4%E3%83%B3%E6%9C%89%E5%8A%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E7%9C%9F%E3%81%A3%E5%90%91%E3%81%8B%E3%82%89%E7%9F%9B%E7%9B%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82NXP%E8%87%AA%E8%BA%AB%E3%81%AE%E6%A4%9C%E8%A8%BC%E5%80%A4%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%82%8B%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A7%E3%80%81%E6%B0%B8%E4%B9%85%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%AF%E5%8D%B3%E5%BA%A7%E3%81%AB%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E7%84%A1%E9%96%A2%E4%BF%82%E3%81%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9NAK(0x77%E5%BF%9C%E7%AD%94%E3%81%AA%E3%81%97)%E3%81%AF%E5%8D%98%E3%81%AA%E3%82%8B%E7%B7%A9%E3%82%93%E3%81%A0%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%A8%E3%83%94%E3%83%B3%E3%81%AE%E6%8E%A5%E8%A7%A6%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%8E%A5%E7%B6%9A%E3%82%92%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%94%E3%83%B3%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--879701082%22%20id%3D%22toc-hId--662082658%22%3E%E5%90%8C%E3%81%98%E7%97%87%E7%8A%B6%E3%81%AB%E6%82%A9%E3%82%80%E4%BA%BA%E3%81%B8%E3%81%AE%E6%95%99%E8%A8%93%3C%2FH3%3E%3CP%3EFlexcomm%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF(PSELID%E3%80%81CFG%E3%80%81CLKDIV%E3%81%AA%E3%81%A9)%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%AA%AD%E3%81%BF%E8%BF%94%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E7%89%A9%E7%90%86%E3%83%90%E3%82%B9%E3%81%AB%E3%81%AF(%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%84%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A7%E7%A2%BA%E8%AA%8D)%E6%B4%BB%E5%8B%95%E3%81%8C%E5%85%A8%E3%81%8F%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E6%89%8B%E4%BD%9C%E6%A5%AD%E3%81%A7%E5%B0%8E%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E4%BB%A3%E6%9B%BF%E6%A9%9F%E8%83%BD%E7%95%AA%E5%8F%B7%E3%82%92pin_signal%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E9%A0%86%E5%BA%8F%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%AE%E3%81%AF%E4%BF%A1%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AESDK%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%81%AE%E3%83%94%E3%83%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%91%E3%82%AF%E3%82%B5%E9%96%A2%E6%95%B0%E3%81%A8%E7%85%A7%E5%90%88%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E7%89%A9%E7%90%86%E3%83%94%E3%83%B3%E3%82%92%E5%90%8C%E3%81%98%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%85%B1%E6%9C%89%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE(%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E8%87%AA%E4%BD%93%E3%81%8C%E4%BD%BF%E3%81%86%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%80%81%E4%BE%8B%E3%81%88%E3%81%B0%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%84%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AA%E3%81%A9%E3%81%AF%E3%80%81%E7%9C%9F%E3%81%AB%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%9F%E5%8F%82%E8%80%83%E3%81%AE%E8%89%AF%E3%81%84%E6%83%85%E5%A0%B1%E6%BA%90%E3%81%A7%E3%81%99)%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E4%BB%AE%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E9%96%A2%E6%95%B0%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8B%E3%82%89%E6%89%8B%E6%9B%B8%E3%81%8DIOCON_PinMuxSet()%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E6%9B%B8%E3%81%8F%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81MCUXpresso%20Pins%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%83%94%E3%83%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E7%9B%B4%E6%8E%A5%E5%86%8D%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%94%B9%E3%82%81%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AE%E4%BB%A5%E5%89%8D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%84%E5%85%83%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AB%E9%96%A2%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%A3%E3%81%9F%E7%9A%86%E3%81%95%E3%82%93%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%A1%E6%96%B9%E3%81%AE%E8%AA%BF%E6%9F%BB%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E6%A4%9C%E8%A8%BC%E4%BD%9C%E6%A5%AD%E3%81%8C%E3%80%81%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%81%93%E3%81%AE%E7%9F%9B%E7%9B%BE(%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AB%E3%83%90%E3%82%B9%E4%B8%8A%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E3%81%AA%E3%81%84)%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E8%BF%BD%E8%B7%A1%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
