LPC55S36-EVK: Cannot detect MCU-LINK debugger - "0 available SWD Devices detected"
RajasekarArumaidurai
Problem Summary:
I cannot flash or debug any application on my LPC55S36-EVK board. The IDE cannot detect the on-board MCU-LINK debugger when attempting to launch a debug session.
Hardware:
Board: EVK-LPC55S36 (LPC55S36-EVK)
Debugger: MCU-LINK on-board (r0C3) CMSIS-DAP V3.167
Software Environment:IDE:
MCUXpresso IDE v25.6 [Build 136] [2025-06-27]
SDK: SDK_2.x_LPC55S36, version 25.09.00, manifest version 3.15.0
Project: hello_world example (imported from SDK)
OS: Windows
Problem Description:
I am unable to debug the hello_world example project on my LPC55S36-EVK board. When attempting to launch a debug session, I receive the following errors:
Initial error: "Target reported errors - 02: Failed on connect - Could not connect to core - 31: No connection to chip's debug port"
Debugging context: hello_hello_world_check LinkServer Release (1)
When checking SWD Configuration: "0 available SWD Devices detected. Connect a device and try again."
The SWD Configuration dialog shows an empty device list
What I've Checked:
USB cable is connected and the board appears powered (LEDs visible if any)
Windows Device Manager shows:
MCU-LINK on-board (r0C3) CMSIS-DAP V3.167 with "OK" status
Multiple MCU-Link VCom Ports with "Unknown" status
MCU-Link Trace & Power Data Port with "Unknown" status
Steps That Have NOT Resolved the Issue:
Rebooting the IDE
Recreating debug configuration
Changing USB ports
updated the link server and firmware update in isp mode.
Questions:
Should I reinstall LinkServer drivers? If so, what's the recommended procedure for MCUXpresso IDE v25.6?
Do the "Unknown" status devices in Device Manager indicate a driver conflict that needs resolution?
Are there known issues with MCUXpresso IDE v25.6 and LPC55S36 debug connectivity?
Hello @RajasekarArumaidurai
Please enter ISP mode and use Flash Magic to perform a mass erase.
Then create a new MCUXpresso IDE workspace, import an SDK demo project, build it, and try debugging again.
If the issue still persists, please take a photo of your board and share it with us.
Thank you.
Alice
I have followed your step; it starts working again.
Hi guys, kindly find the attachment screen shot to enable ISP Mode.
Thank you.
Alice
Nilsson
I have the same setup besides that my target is a FRDM-MCXN947. This worked fine until the MCU-Link Pro firmware update. Now it only reports 0 SWD targets all the time and I have tried the solution with no luck.
Mats Nilsson
%3CLINGO-SUB%20id%3D%22lingo-sub-2321171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S36-EVK%3A%20Cannot%20detect%20MCU-LINK%20debugger%20-%20%220%20available%20SWD%20Devices%20detected%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EProblem%20Summary%3A%3C%2FSTRONG%3E%3CBR%20%2F%3EI%20cannot%20flash%20or%20debug%20any%20application%20on%20my%20LPC55S36-EVK%20board.%20The%20IDE%20cannot%20detect%20the%20on-board%20MCU-LINK%20debugger%20when%20attempting%20to%20launch%20a%20debug%20session.%3C%2FP%3E%3CP%3E%3CSTRONG%3EHardware%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EBoard%3A%20EVK-LPC55S36%20(LPC55S36-EVK)%3CBR%20%2F%3EDebugger%3A%20MCU-LINK%20on-board%20(r0C3)%20CMSIS-DAP%20V3.167%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3ESoftware%20Environment%3AIDE%3A%3C%2FSTRONG%3E%3CBR%20%2F%3EMCUXpresso%20IDE%20v25.6%20%5BBuild%20136%5D%20%5B2025-06-27%5D%3CBR%20%2F%3ESDK%3A%20SDK_2.x_LPC55S36%2C%20version%2025.09.00%2C%20manifest%20version%203.15.0%3CBR%20%2F%3EProject%3A%20hello_world%20example%20(imported%20from%20SDK)%3CBR%20%2F%3EOS%3A%20Windows%3CBR%20%2F%3E%3CSTRONG%3EProblem%20Description%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EI%20am%20unable%20to%20debug%20the%20hello_world%20example%20project%20on%20my%20LPC55S36-EVK%20board.%20When%20attempting%20to%20launch%20a%20debug%20session%2C%20I%20receive%20the%20following%20errors%3A%3C%2FP%3E%3CP%3EInitial%20error%3A%26nbsp%3B%22Target%20reported%20errors%20-%2002%3A%20Failed%20on%20connect%20-%20Could%20not%20connect%20to%20core%20-%2031%3A%20No%20connection%20to%20chip's%20debug%20port%22%3C%2FP%3E%3CP%3EDebugging%20context%3A%20hello_hello_world_check%20LinkServer%20Release%20(1)%3CBR%20%2F%3EWhen%20checking%20SWD%20Configuration%3A%26nbsp%3B%220%20available%20SWD%20Devices%20detected.%20Connect%20a%20device%20and%20try%20again.%22%3C%2FP%3E%3CP%3EThe%20SWD%20Configuration%20dialog%20shows%20an%20empty%20device%20list%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3EWhat%20I've%20Checked%3A%3C%2FSTRONG%3E%3CBR%20%2F%3EUSB%20cable%20is%20connected%20and%20the%20board%20appears%20powered%20(LEDs%20visible%20if%20any)%3CBR%20%2F%3EWindows%20Device%20Manager%20shows%3A%3CBR%20%2F%3EMCU-LINK%20on-board%20(r0C3)%20CMSIS-DAP%20V3.167%20with%20%22OK%22%20status%3CBR%20%2F%3EMultiple%20MCU-Link%20VCom%20Ports%20with%20%22Unknown%22%20status%3CBR%20%2F%3EMCU-Link%20Trace%20%26amp%3B%20Power%20Data%20Port%20with%20%22Unknown%22%20status%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3ESteps%20That%20Have%20NOT%20Resolved%20the%20Issue%3A%3C%2FSTRONG%3E%3CBR%20%2F%3ERebooting%20the%20IDE%3CBR%20%2F%3ERecreating%20debug%20configuration%3CBR%20%2F%3EChanging%20USB%20ports%3CBR%20%2F%3Eupdated%20the%20link%20server%20and%20firmware%20update%20in%20isp%20mode.%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuestions%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EShould%20I%20reinstall%20LinkServer%20drivers%3F%20If%20so%2C%20what's%20the%20recommended%20procedure%20for%20MCUXpresso%20IDE%20v25.6%3F%3CBR%20%2F%3EDo%20the%20%22Unknown%22%20status%20devices%20in%20Device%20Manager%20indicate%20a%20driver%20conflict%20that%20needs%20resolution%3F%3CBR%20%2F%3EAre%20there%20known%20issues%20with%20MCUXpresso%20IDE%20v25.6%20and%20LPC55S36%20debug%20connectivity%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-02-23%20140111.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-02-23%20140111.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-02-23%20140111.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377520i5A792F1AC0842FB2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-02-23%20140111.png%22%20alt%3D%22Screenshot%202026-02-23%20140111.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-02-23%20140637.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-02-23%20140637.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-02-23%20140637.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377521i357AC32DC363F4A1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-02-23%20140637.png%22%20alt%3D%22Screenshot%202026-02-23%20140637.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-02-23%20140926.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-02-23%20140926.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-02-23%20140926.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377522i7F01B79F9D37C9FE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-02-23%20140926.png%22%20alt%3D%22Screenshot%202026-02-23%20140926.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36-EVK%3A%20Cannot%20detect%20MCU-LINK%20debugger%20-%20%220%20available%20SWD%20Devices%20detected%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%3CP%3EI%20have%20followed%20your%20step%3B%20it%20starts%20working%20again.%3C%2FP%3E%3CP%3EHi%20guys%2C%20kindly%20find%20the%20attachment%20screen%20shot%20to%20enable%20ISP%20Mode.%3C%2FP%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36-EVK%3A%20Cannot%20detect%20MCU-LINK%20debugger%20-%20%220%20available%20SWD%20Devices%20detected%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260128%22%20target%3D%22_blank%22%3E%40RajasekarArumaidurai%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3EPlease%20enter%20ISP%20mode%20and%20use%20Flash%20Magic%20to%20perform%20a%20mass%20erase.%3CBR%20%2F%3EThen%20create%20a%20new%20MCUXpresso%20IDE%20workspace%2C%20import%20an%20SDK%20demo%20project%2C%20build%20it%2C%20and%20try%20debugging%20again.%3C%2FP%3E%0A%3CP%3EIf%20the%20issue%20still%20persists%2C%20please%20take%20a%20photo%20of%20your%20board%20and%20share%20it%20with%20us.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EThank%20you.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2329966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36-EVK%3A%20Cannot%20detect%20MCU-LINK%20debugger%20-%20%220%20available%20SWD%20Devices%20detected%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2329966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20have%20the%20same%20setup%20besides%20that%20my%20target%20is%20a%20FRDM-MCXN947.%20This%20worked%20fine%20until%20the%20MCU-Link%20Pro%20firmware%20update.%20Now%20it%20only%20reports%200%20SWD%20targets%20all%20the%20time%20and%20I%20have%20tried%20the%20solution%20with%20no%20luck.%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EMats%20Nilsson%3C%2FP%3E%3C%2FLINGO-BODY%3E
